PDA
View Full Version : 12 Valve 2nd Gen Dodge Cummins 94-98
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 [25] 26 27 28 29
  1. over speed hx35
  2. buying a 95 pros and cons?
  3. transmission/transfer case question
  4. how to take off towing mirrors??
  5. How to find"dead nuts" Top Dead center on a 12v?
  6. Need some newbie questions answered
  7. Horse Power???
  8. high rpm stumble.
  9. KDP pin issue..
  10. p pump fuel shuttoff smoking
  11. passenger light not working...
  12. Harmonic Balancer Position..
  13. Lift pump tick or not?
  14. hx 35/40 ugrades
  15. Need Some Help
  16. people that have bypassed the fuel heater
  17. tranny shops
  18. power steering help!
  19. HX40 on 94 cummins?
  20. rpm sensor problems
  21. star screw
  22. missing!!!
  23. shift points??
  24. 47RH OD/TPS Issue... HELP!!
  25. Need to remove washer fluid bottle...
  26. 95 tranny?
  27. high EGT's!
  28. overheating or not?
  29. prefilter
  30. reving motor in neutral/park more wear??
  31. loosing coolant
  32. 47re Fluid questions..
  33. valve sticking maybe
  34. Pump "settings" for towing and mileage
  35. tranny issues
  36. tranny ?
  37. KDP
  38. Looking @ Buying a 12v
  39. rpm vs mph
  40. what are the tubes?
  41. help diagnosing a miss
  42. what are dv's
  43. timing tool kit for pump timing
  44. wobble in front end
  45. coolant leak
  46. turbo porting.
  47. sending feul line from spin on to injection pump bolt stripped
  48. need pump help
  49. torque spec on stub axel
  50. power steering leak
  51. biggy b how can u tell if you have slipped timing on ur pump ?
  52. tranny whine?
  53. 12v surges off idle BAD!
  54. intake piping
  55. pump timing
  56. altenator
  57. PCM issue
  58. 96 cummins dieing when reved
  59. doubts after sligth tunning
  60. where to buy
  61. 01 TRANSFER CASE ON A 96 SPEEDO HELP
  62. Fuel Plate
  63. ever heard of it?
  64. adjusting the bands
  65. Roof liner
  66. Need Help... No Power!!!
  67. star wheel.
  68. help
  69. Whats it worth?
  70. fuel gauge
  71. FUEL FILTER OFF
  72. bypass oil filtration drain?
  73. steering box
  74. hmmm oil pressure?
  75. water in passenger floor board
  76. How often do you adjust your valves
  77. Valve Spring Retainers
  78. how much hp
  79. 96 tranny line upgrade ideas
  80. hx 35 turbo rebuild
  81. HX 50 EGTS
  82. white smoke under compression
  83. clutch
  84. starting issue
  85. exit off highway ramp lose RMP dies,wont start running again
  86. egts
  87. AFC Spring and Govenor Spring
  88. stock numbers
  89. replacing head light bulbs
  90. pump plug
  91. 4x4?
  92. NEW TO THE DIESEL GAME
  93. 47RE shift troubleshooting
  94. 95 auto trans
  95. turbo mapping
  96. death wobble
  97. damn pedals wont come out
  98. Rear dana need help
  99. makin my 12v lope
  100. valve springs
  101. Need some advice
  102. tq vs. hp
  103. more boost bc the star wheel?
  104. Lift kits???
  105. what convertor
  106. Confused :(
  107. oil in plug for 4k kit install
  108. tc lockup on a relay?
  109. new guy needs help
  110. wtf HELLLLLLP!!!
  111. fuel plate suggestion
  112. Oil pressure
  113. Idle RPM's
  114. valve spring install
  115. pre boost screw
  116. Exhaust Change
  117. Fuel Plate
  118. Stock tranny questions
  119. EXHAUST LEAK,gasket replacement?
  120. 95...easy hp + ?...
  121. 85 dodge prospector 1/2 ton 4bt swap
  122. Lift Pump
  123. wat to do
  124. hx35/40 urgent help!!
  125. hx35/40 waste gate
  126. Oil Drinking
  127. engine temp changes
  128. return line leak
  129. how to fix the cruise control? 1997 12v 5speed
  130. throttle sticking
  131. oiled filters
  132. turbo here advice!
  133. Exhaust
  134. A/C Not working :(
  135. HELP ASAP!
  136. Steering Problems
  137. Injection pump start solenoid wiring
  138. 12V heating and air question
  139. cleaning out the guts of an NV4500
  140. NV4500 Stuck in 5th
  141. how do i pull the 5speed leather boot off?
  142. EGT Temp?
  143. Fuel mileage
  144. white smoke
  145. valve springs...
  146. questions on parts
  147. diesel shop to set 12v pump timing, near mississippi.
  148. 1997 12v 5speed perfect setup
  149. Curious?
  150. what to buy next?
  151. How To Adjust The Timing On My 12v
  152. 12V Power
  153. doing kdp tab, need advice
  154. how much can i do without hurting stock trans
  155. hx35/40 hybrid and no difference!
  156. First diesel newb with lots of questions
  157. leaky injector
  158. new turbo and more upgrades.
  159. how do i gut the afc housing?
  160. getting the compressor wheel off
  161. shift boots
  162. IC surface temp?
  163. what does the star wheel affect?
  164. advance timming with out the dial indicator method
  165. 95 4x4 207,000 miles?
  166. budget turbo upgrade?
  167. gov spring question
  168. 60lb valve springs
  169. nv4500 tranny fluid
  170. frankenstien my 12v
  171. things i have done and the problems im having
  172. put the new rack plug in tonite
  173. Killer dowel pin
  174. its the gauge, not the turbo...Help please
  175. louder turbo whistle
  176. Speedometer problems
  177. im having turbo problems
  178. Over flow valve
  179. Transmisson Trouble
  180. balancing my turbo?
  181. How does the fuel plate work
  182. boost leak?
  183. Turbo problem??
  184. what to do next
  185. Turning my exhaust manifold 180 degree
  186. 3rd guage
  187. what is a cummins m11 H55 turbo?
  188. holstet vgt
  189. max boost 27ish?
  190. security system??? wtf??
  191. Dash Pod?
  192. Ram Service Pub 81-370-6108
  193. frankenstien my motors turbo
  194. Electric fan clutch
  195. head removal
  196. hx35/40 hybrid
  197. cummins on a budget
  198. 47rh?
  199. VACUUM PUMP 911
  200. water issue
  201. I'm wanting to convert my 95 with a 47rh to a nv4500
  202. timeing effect shift point?
  203. hx 55 urgent!!
  204. dampener
  205. throwout fork
  206. injector lines
  207. Transmission cooling and the heat exchanger
  208. somebody help
  209. grinding the fuel plate
  210. painting under the hood
  211. paint or polish?
  212. brakes???????
  213. Exhaust Brake ?
  214. more power
  215. boost psi?
  216. waste-gate cut-away
  217. best turbo?
  218. water in fuel lt after filter change
  219. Steering Box?
  220. sluggish off line
  221. Water/Methanol Injection
  222. tc?
  223. Injection Pumps
  224. fuel leak
  225. intake gaskets
  226. rattling noise
  227. wat are the temps.
  228. a/c only on the floor
  229. gota wack my starter
  230. optima red top
  231. kdp
  232. whistle
  233. lock up vs suncoast TC
  234. Torque Convertor Lock Up
  235. allison in dodge?
  236. i have a goal and need help!
  237. Turn up pump?
  238. vin D or 6
  239. torque converter lock switch
  240. fuel filters
  241. negative camber
  242. is my intake as good as AEM?
  243. injector leakin on my 12 valve
  244. fuel plate and throttle
  245. Motors Almost Complete Rebuild.
  246. tuning the pump
  247. new exhaust
  248. Overdrive Switch
  249. fuel guage problem
  250. Flippin death wobble!!
