PDA
View Full Version : 12 Valve 2nd Gen Dodge Cummins 94-98
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29
  1. 97 Ram 3500
  2. gasser conversion
  3. power steering leak
  4. New here
  5. First Time Diesel Owner, Have a Few Questions (No, not "how do I roll coal?")
  6. boost differents
  7. Twin turbo ?'s
  8. Few problems
  9. need egts lower help!!!!
  10. best headlights
  11. new bumper
  12. Front end rebuild
  13. Newbie with a 12 valve.....
  14. Melting headlight switches, relays, and HIDs
  15. 12 Valve Build questions?
  16. southbend dual disk making nosie?
  17. Fuel shutoff solenoid...$$$
  18. help oil leak
  19. Fuel tank swap from gas to diesel
  20. REBUILD P7100 BAD??
  21. 98 Ram5.9 Cummins
  22. any pics of a leveling kit with 35s please.?
  23. 94 cummins HELP
  24. 97 3500 5.9
  25. New Turbo
  26. Lowering my Cummins
  27. connot get over 2k rpm
  28. Should I buy this 94' 12 Valve??! HELPP!!
  29. multiple issues
  30. Tire selection
  31. Looking at 97 Single Cab - Opinions?
  32. Fuel leak diagnose
  33. 2nd gen wheels with big tires question
  34. Oil in my intake tube?
  35. stock turbo change
  36. Power numbers?
  37. delivery valves
  38. 47 RH transmission problems!!
  39. Dually to SRW
  40. Blow by out of dip stick??
  41. need a word of advice , my truck died at the worst time
  42. injectors!?!?!
  43. Stuck in lock up
  44. weird hiss noise
  45. Cummins Newb need advice on first truck
  46. Looking forward to another Cummins
  47. My , new to me Cummins !!!!
  48. Manual To Auto swap???
  49. driveshaft vibrations??
  50. thinking of buying this 96 cummins
  51. Vibrating and "jingle" at stop in drive
  52. Wheel weight capacity? anyone know?
  53. over heating
  54. cummins dog ?
  55. Frankenpod gauge pod
  56. intercooler?
  57. 5x.018's?
  58. Would you buy this 2nd gen cummins?
  59. Power!!?
  60. list of summer mods.... opinions??
  61. Cummins transfer case issues
  62. tail light electrical help!
  63. Fuel pump?
  64. 12V making a noise at idle
  65. Building my P7100
  66. Intercooler hose popped off
  67. no smoke
  68. How heavy is a 8' SRW bed?
  69. Auto Trans questions
  70. A/C air only comming out of defroster and floor
  71. 1995 dodge 12 valve cummings 0 fuel plate
  72. 96 Recall Throttle Control Cable & Linkage Package
  73. fuel pressure and miss
  74. need some info on buying a 2nd gen
  75. strange transmission sounds.
  76. stock+injectors for mpg
  77. Sudden Loss of Power after shifting in 4WD
  78. 12 valve blue smoke
  79. Truck Dies
  80. P-Pump leaking oil
  81. Tranny bands?
  82. 94 problems, help appreciated!
  83. Interesting find during boost elbow install.
  84. 47re wont downshift to 1st
  85. advice on 95 cummins please
  86. Advice on an upcoming 95 12 valve build???????
  87. 47re filler tube leak?..
  88. 1996 dodge diesel transver case
  89. upgrades
  90. 94-96...12V Help....
  91. Injectors 12 Valve Cummins
  92. 3rd gen wheels
  93. Cold Weather Starts
  94. 96 missing
  95. phatshaft 62 turbo
  96. trans pressure adjustments
  97. mac plug on 12v
  98. Govener spring kit change
  99. GMC cummins 12v swap question
  100. 12 valve knock
  101. My latest project!
  102. Just getting Started 98 12V
  103. please help 1997 cummins wont start
  104. redding ,ca diesel drags and pulls
  105. eye burning exhaust
  106. wont shift in O/D
  107. thoughts on 370 marine injectors
  108. about to tackel head gasket
  109. Dual disk south bend
  110. O/D button acting up
  111. 12v misfiring after DV leak fix?
  112. How to better my fuel milage?
  113. oil pressure
  114. gutted afc not much smoke
  115. Shifting problem with 1998 dodge auto
  116. hx 35 question
  117. PLEASE PLEASE PLEASE HELP!!!!!!!!
  118. How bad are the auto transmissions?
  119. Head gasket?
  120. turbo hose question
  121. noise isolater and new negative battery connections...
  122. 12 won't start.
  123. fuel shutoff solenoid
  124. im very new and looking for knowledge please
  125. Weird fuel leak
  126. K.D.P ?
  127. nozzles
  128. pump timing
  129. how much power
  130. oil coming out of dipstick
  131. how can I tell what gen my 5.9 liter 6Bt is?
  132. Interior help?
  133. how much of a difference?
  134. Rear Main
  135. Cummins E brake or "Jacobs brake"
  136. 98-99 HD steering upgrade pitman arm part #
  137. is this a good idea
  138. Breatherless tappet cover??!?
  139. truck starts then dies
  140. Which tire size to get?
  141. Wont shift outta 3rd 1997 2500 cummins
  142. injector help
  143. 4x4 issue?
  144. delivery valve question
  145. Timing and cam gear
  146. Grrrr.. Oil Leaks and other miseries
  147. Torque converter locking up too early, tranny ?'s
  148. HX 40
  149. few ?s
  150. terrible MPG!! :(
  151. Need a harmonic balancer
  152. breaking point
  153. whats the catch..?
  154. 1997 12 valve good towing turbo?
  155. borge warner s300
  156. Running hot
  157. egts
  158. fuel pressure
  159. FUEL ISSUE, HELP!!
  160. 47rh lock up
  161. no fuel from pump
  162. injector nozzle quesion
  163. Won't start in park
  164. 47re brand of converter recomended
  165. Transmission cooler lines, ive just about had it..
  166. help ! i need all throttal linkage from a p pump
  167. Noob questions about fuel lines
  168. trans cooler
  169. gauge cluster not working
  170. few issues with my new 12v
  171. trying to get 600 horse what cam should i get?
  172. delivery valves
  173. sputtering 12v
  174. Dana 70 rear end
  175. oil pressure is only gauge workibg
  176. removed trans now Won't start
  177. 97 dodge
  178. Head Studs
  179. LOWERING 4X4 12V
  180. Transmission fluid leak question
  181. 24v long block in a 12v truck
  182. 99 24v to 97 12v swap?
  183. the real 5th gear fix
  184. I need opinions on timing***!
  185. Axels
  186. Alternative fuel filter
  187. Need a sensible solution on my trucks gearing.
  188. NEED HELP WITH VALVE SPRINGS 60#
  189. who else runs nos?
  190. still not getting enough fuel :/
  191. Why is it so hard to find new motor mounts?
  192. southbend, stock hydrolics
  193. "Slop" in 5 speed and cruise control
  194. New to me 1996 CUmmins
  195. Help! Auto to NV 4500 swap question
  196. Which Brake Fluid ?
  197. 12v 1998 Club Cab LWB worth $3000?
  198. 94 cummins motor problems
  199. HX35w or wh1c turbo
  200. temp guage pegged at 230?
  201. No overdrive, please help!
  202. Gearing too SLOW!!!!!
  203. Longevity Question
  204. found this... might help someone somewhere
  205. Ats exhaust manifold question
  206. 95 12v 319k miles. Worth getting?
  207. Broken Exhaust Bolts in head
  208. Stalling
  209. What should Tranny temps be?
  210. 47re 3rd to 4th + overdrive issues
  211. 1997 auto with a primeloc upgraded fuel transfer pump question
  212. Spyder Halos
  213. Glow shift boost hose and boost question
  214. Wiring harness?
  215. 1995 cummins engine removal?s
  216. Any idea what this connects to?
  217. need wire diagram for 1997 cummins
  218. TPI
  219. Transmission Options
  220. 4x4 light won't come on, 98 12v
  221. DVs and injectors?
  222. Speedometer problem(NOT TIRE SIZE), ideas?
  223. Glowshift boost gauge hose
  224. pro 52 turbo
  225. 12 valve swap??
  226. ARP torque specs?
  227. Tire and rims
  228. Slight miss and hard start
  229. 1997 3500 with a Rambrake, need help
  230. I want to make my 12 valve run better!!
  231. Torque converter and valve body (shift kit)
  232. loping
  233. 24V Head on a 2nd Gen 12V Block?
  234. Miss?? Injectors??
  235. 47rh Valve Body
  236. Fulcrum lever llinkage adjustment
  237. Starting issues
  238. 95 tow capacity gcvwr
  239. New 95, smoke question
  240. Which way do connecting rods face?
  241. Fuel filter relocate kit
  242. injectors
  243. injection pump timing
  244. want to make a 1997 puller
  245. Fuel filter water/fuel separator question??
  246. Torque converter
  247. Death Wobble
  248. Oil leak drivers side! Please help.
  249. Shock Upgrade Questions
  250. A few questions about increased hp/tq cummins
