PDA
View Full Version : 12 Valve 2nd Gen Dodge Cummins 94-98
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29
  1. fuel shut off soleniod
  2. Hard start
  3. New Cheap Turbo
  4. 96 programer, fuel economy gauge?
  5. 97 oil leak
  6. New converter!
  7. STARTED WITH BARRING TOOL IN
  8. truck wont shift into overdrive
  9. Whats a rolling chassis worth?
  10. Transfer case input shaft
  11. Flywheel bolt washers
  12. put extended cab on reg cab long bed frame?
  13. instrument cluster
  14. Good cheap clutch
  15. New truck!
  16. 95 cummins
  17. 241dhd shifter rod
  18. 96 12ver rebuild
  19. Head stud installation help
  20. AFC Modifying Precision Questions??
  21. Electric Fuel Pump Mod Questions
  22. Looking to buy first Cummins! Q's?
  23. w.t.h....
  24. What Yall Think?
  25. 97 2500 4x4 new owner, what to look for?
  26. Banks twin ram
  27. 5 speed trans for Cummins
  28. 1996 cummins cracked block
  29. Nv4500 swap tranny mount
  30. cummins nv4500 swap/nv4500 for sale
  31. 94 12 valve motor mounts??
  32. Intercooler boots question
  33. parts for 5spd conversion?
  34. 500hp project
  35. Interior Parts
  36. swapping cabs
  37. can someone go check a coupple wires for me? and new pics of 2wd to 4wd swap
  38. 94 dodge build thread
  39. anybody ever heard of these?
  40. NEED HELP ASAP!!!!!!!!!!!!!!!!!!!!
  41. Clutch bolts
  42. Injector washer thickness
  43. Coasting on Deseleration and E Brake
  44. how much horsepower can i make with a shift kit
  45. Water and crap in the cowl?
  46. a/c keep or lose?
  47. poof. white smoke
  48. just lost power brakes and power stering
  49. Most fuel mileage
  50. Nozzle identification
  51. Help with manual transmission oil.
  52. 4k govonor springs?
  53. 95 dodge ram brush guard mounting points
  54. dana 70 3.73 gears?
  55. Can anyone tell if these are 60lb Valve Springs?
  56. Want to swap: 2wd 5 speed for 2wd auto OD
  57. 97 12v questions
  58. why can i spin my front drive line and tires dont move?
  59. 47RH wont shift into forward gears
  60. low fuel pressure. spikes then drops.
  61. Transmission or T-case grinding
  62. P7100 Governing Arm, Rack Travel Help...
  63. injector lines
  64. Swapping
  65. 95 cummins help!!!!
  66. Heater core questions??
  67. ways to lighten my truck ?
  68. auto to manual parts?
  69. blow by
  70. boost
  71. 2 speed rearend?
  72. anyone selling a 47re overdrive unit?
  73. death wobble
  74. big power
  75. tq converter
  76. make my trans stronger, and get more power.
  77. Tappet Cover, Foam??
  78. Crank Sensor
  79. valve covers leaking?
  80. All rmp's no go
  81. htt hx40/35 upgrade
  82. lookin to get some new injectors
  83. 2 temp sensors?
  84. timing?
  85. 12 valve head gasket?
  86. lift pump
  87. interior swap?
  88. anyone selling a 47re overdrive unit?
  89. Need help making more power
  90. BIG PROBLEMS overheat
  91. 89 Chevy Dually 6pack Exhuast with 12v cummins
  92. New Idea...Whats everybody think?
  93. FASS 150
  94. Timing how to and how much should it cost.
  95. 241DHD question
  96. citydiesel 370 injectors
  97. 4bt ???
  98. cold place
  99. lookin 4 a truck 4 around 6,000
  100. Mod questions
  101. Power differences between 94-98
  102. INSTRUMENT CLUSTER
  103. Copper Trans Line wtf?!
  104. afc arm...
  105. Help me please
  106. 241DHD question fast please
  107. Front rotors.
  108. which injectors are the best?
  109. engine coolant
  110. Any help in advancing my timing??
  111. wont move
  112. Gauge install help
  113. 4bt or 6bt?
  114. Pop testing injectors
  115. do our trucks need oil in fuel?
  116. 95 12V CAM FOLLOWER COVER??
  117. New transmisson has a problem?
  118. Nv4500 help
  119. GMT800 swap
  120. Mirror questions??
  121. new stacks!
  122. a new pic, of how she sits now...
  123. cylinder head help
  124. phantom dually
  125. what transfercase do i need?
  126. stuck at 25
  127. full cut delivery valves
  128. 98 12 vavle miss. HELP!
  129. New stacks!
  130. Doin kdp
  131. banks stuff
  132. Diesel Additives
  133. Less smoke more power
  134. Nv4500 swap question
  135. Starting problems
  136. starwheel help
  137. Possible Links to TSB?
  138. 97 problems starting
  139. 96' front axle leaking
  140. Transmission Issue
  141. NV4500
  142. loping idle
  143. 4wd vaccuum
  144. Manual to Auto questions?
  145. Is bypassing fuel heater bad?
  146. passing gear adjustment
  147. 241 DLD problem
  148. 96 cummins?
  149. Boost gauge quite!
  150. 93 rear end in a 98
  151. any ideas?
  152. Fuel system help
  153. Truck won't run
  154. Belt problem.
  155. is the truck worth it?
  156. Stuck in 4wd, front driveshaft turns in 2wd
  157. new to forum
  158. transfer case
  159. 12v doggy after homemade twin turbo kit
  160. Quick afc question
  161. COMPUTER PROBLEM
  162. OIL LEAK!!!
  163. 47re overdrive housing question
  164. Oil Leaking
  165. Arp head stud ?
  166. 97 fuel shut off seleniod electical
  167. fuel pump issues
  168. 5,000$ budget
  169. borg warner turbo size?
  170. borg warner turbo
  171. OEM Turbo Size ?
  172. want my speedo back
  173. #0 Fuel Plate and boost elbow Question
  174. fuel pressure drop
  175. Aftermarket Import Heads
  176. twin turbo fummins
  177. sources for high torque starters
  178. what are my options, tranny related.
  179. Is there a electric fuel milage unit.
  180. Performance Versus Mileage
  181. 47re switching overdrive to make it 4wd
  182. External crack in head leaking antifreeze
  183. glowshift gauges ???
  184. 4.10 to 3.54 swap questions
  185. pyrometer
  186. wastegate rod
  187. ac low presure switch??
  188. quick ? Turbo outlet ID/OD wh1c
  189. Head Gasket leak???Fixes itself overnight???
  190. NV4500 vs 47RE vs G56 vs NV5600
  191. cummins kdp issue
  192. highest rpm with 4gsk
  193. Upgrading engine
  194. new member new truck cummins
  195. SPEAKER WIRING
  196. Brakes
  197. diesel melting nylon tubing?
  198. shifting problems. need help im lost
  199. new guy
  200. Fuel line leak
  201. 2wd to 4wd swap
  202. dodge 3500 transfercase question
  203. ford same as dodge stacks?
  204. dana 70
  205. Vacuum Problems!
  206. tranny acting funny (slipping?)
  207. No Speedometer! HELP
  208. Trailer brake questions???
  209. How much to paint truck?
  210. What's this truck worth?
  211. power? whats holding me back?
  212. trans case
  213. U joints?
  214. truck wont start
  215. LETS SEE SOME 12v WITH NO FUEL PLATES!!!!
  216. bigger turbo
  217. Cracked HEad?! help
  218. Is my tranny filter the same?
  219. tranny slips and doesent shift after rebuild
  220. Plate or no Plate
  221. nv4500 fill
  222. The Next step....?
  223. ecm/pcm
  224. turn off headlights
  225. no start 12 Valve (Timing I think..)
  226. putting my darn engine back in
  227. push button start?
  228. Exhaust
  229. Fuel pressure
  230. ABS problems
  231. how would you make a nv4500 bullet proof
  232. driving with boost leak
  233. Video of fuel heater delete, pre-filter cleaning
  234. Help Buying A 2nd gen 4wd
  235. 12v cummins thermostat
  236. this might be a stupid question....
  237. help looking for a FASS fuel system
  238. white smoke at 2300 rpm
  239. No power on hills
  240. 2wd to 4wd swap
  241. engine stalls sometimes...
  242. Big hp and fuel milage question
  243. Gear ratio for 37's?
  244. intermitent down shifting problem
  245. turbo question
  246. p7100 fuel plate
  247. Pump timing....again
  248. Need opinions on stock springs
  249. New Injectors
  250. im in need of fuel knowledge
