PDA
View Full Version : 12 Valve 2nd Gen Dodge Cummins 94-98
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 [29]
  1. Few Auto Questions.
  2. 1997 CTD Problem
  3. 91 & 94 4x4 Cummins
  4. 1994 Cummins Farm Truck That Has A Few Problems...Please Help
  5. Steering Gears And Shafts
  6. Coolant Temp Sensor Location
  7. 47RE Trans /Converter Question
  8. Surging Around 1200rpm
  9. Fuel Filter Replacement
  10. Auto Trans Question
  11. 3rd Gen Track Bar
  12. Im Bummed
  13. 97 Automatic, Converter Lock-Up Switch
  14. NV4500 Rebuild Questions
  15. What Do You Guys Think About This Truck?
  16. I Think I Know Whats Wrong, Help Me Confirm It Please
  17. Part Number
  18. Best Place To Get Transmission Parts For NV4500?
  19. Oil Leak Help
  20. Injector Pump Needs Rebuilding
  21. AC/Vent Fan Doesn't Work
  22. NV4500 Problem
  23. Hey Everyone
  24. When To Advance Timing
  25. Axle Seal
  26. How Hot Is Too Hot
  27. Tranny/Transfer Case Questions
  28. Shuddering Noise From Tranny?
  29. Gettin Time For A Tranny
  30. Rear Main Seal
  31. Just Installed #10 Plate. What A Waste...
  32. I Want To Ditch My Cat But Not My Muffler. Bad Idea???
  33. Good Source for quality Valve Cover Gaskets
  34. EGR valve removal '97 12 valve
  35. 4.5 GSK
  36. 60lb Valve Springs
  37. i got problems
  38. NV4500 Troubles
  39. 1st Gen.. Tranny
  40. cam gear and power steering pump gear
  41. 12v oil amount
  42. pump leak
  43. Cab and chassis 2x4
  44. Differences between 94 and 96?
  45. low, lopey idle
  46. 95' 3/4 to 1 ton
  47. Injector and DV advice needed
  48. headliner removal
  49. WOT stop adjustment
  50. transmission how much?
  51. P7100 Fuel Plate Profiles
  52. UGH!
  53. 1997 12 valve problem please help
  54. what to do,i have air in clutch system?
  55. Wastegate
  56. 12 Valve Head
  57. Oil Pressure Sender
  58. Helpful Links
  59. overhead temp/compass
  60. 12V fuel pressure?
  61. Drop in milage, where to look?
  62. 47rh T/C
  63. Hi
