PDA
View Full Version : 12 Valve 2nd Gen Dodge Cummins 94-98
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 [24] 25 26 27 28 29
  1. What size turbo?
  2. HOLE in return line in TANK
  3. Fuel Lift Pump Troubleshooting
  4. Black diesel?
  5. Trans Temp Gauge Help
  6. intake heater working or not?
  7. speed sensor wires testing? also alt pulley size?
  8. Initial 1 – 2 shift delay with 47RE
  9. Home Made Twins
  10. Plugging Waste Gate Pros and Cons
  11. afc screw?
  12. who has done it? 47re to nv4500 swap
  13. tow power
  14. new starter for 1996 cummins- $120 free shipping
  15. 12V Head Gasket Blown?
  16. TOURQUE CONVERTER HELP--96 12V AUTO
  17. Lag
  18. cruise control
  19. Vacuum pump gasket
  20. Update on starter
  21. biggest tires with 2" level kit?
  22. Dissapearing Oil
  23. Billet input shaft
  24. new to here and to diesels for the most part
  25. AFC
  26. oops!
  27. whats the be atf?
  28. Input Shaft
  29. harmonic balancer
  30. whats the differnce in the trannys?
  31. timing cover bolts
  32. Starter not engaging
  33. Is This A Factory Recall??
  34. help
  35. How to bleed at injectors
  36. KDP
  37. Making a 47RE work in a Swap Situation
  38. 4x4 disengages.
  39. changed overflow valve,lines,STILL HARDSTARTING!!
  40. comp button
  41. Intake Horn
  42. ** POSTING THREADS - READ THIS BEFORE POSTING ! **
  43. Heater grid issues?
  44. Steering issues
  45. water in my dash?
  46. Just killed the KDP - Problem with speed sensor
  47. 4wd noise
  48. nv4500 swap?
  49. purchasing a 4x4 12 v,WHAT to look for?
  50. hx35/40 hybrid exhaust housing.
  51. 4X4
  52. mpg average
  53. new truck
  54. bump timing or wait?
  55. wierd code???
  56. timing?
  57. modifying my 12 valve
  58. what you think of this
  59. Truck porn
  60. sun cracked dash cover
  61. P Pumping a 92
  62. emissions
  63. Crankshaft help
  64. heres a thought
  65. ? of the day
  66. KDP
  67. hp
  68. 12v gauge readings, power for towing etc...
  69. turbo question???
  70. diff between 8 and 5 plate?
  71. Wheel Bearings
  72. boost line T
  73. fuel heater
  74. blower motor and wheel
  75. plungers and barrels
  76. valve adjustment
  77. wat to grind fuel plate with?
  78. after market head studs?
  79. Crankshaft Position Sensor Round 2
  80. Grinding Fuel Plate
  81. all the crap in front of the intercooler
  82. NOOB question i know
  83. 2 Piece Fuel Plate
  84. recall question
  85. Transmission Swap
  86. How To Set Your Truck Back To Stock Timing?
  87. fog light wiring
  88. Silencer Ring
  89. KDP
  90. home built head studs
  91. is this possible?
  92. 3k gsk
  93. would this work on my truck?
  94. breakdown
  95. 215 INJECTORS
  96. Cummins power pricings...
  97. Hard starting ,already changed fuel filter....crack line?
  98. fog lights
  99. where to get a boost elbow adjust screw?
  100. what is the best Valve Body
  101. slower after gsk
  102. heater grid delete
  103. steering & a/c clutch
  104. Torque converter?
  105. cruise control
  106. Steering Issues
  107. A/C pulley
  108. low speed jump.
  109. lag
  110. exhaust
  111. painting the bumper and the grill?
  112. Starting Problems
  113. New tranny or buildup?
  114. no overdrive?
  115. #0 plate vs grindin vs guttin
  116. stack makin a mess
  117. clutch slipping
  118. High idle?
  119. glad it happened on the farm
  120. somethins wrong
  121. Whats the difference?
  122. what is my hp
  123. Low Boost High EGTS
  124. 7-inch stack
  125. Brake Light!
  126. Electrical Problems
  127. billet parts
  128. torque specs
  129. infamous death wobble
  130. gauges not quite right
  131. mirror help?
  132. Need rocker arm pedistals
  133. 3k gsk
  134. How much boost can a stock cummins turbo handle
  135. how much boost can a stock cummins turbo handle
  136. pump timing geat help.......!!!!!!
  137. turbos turbos...
  138. 95 cummins 4x4 5speed should i buy?
  139. timing suggestions?
  140. afc trouble
  141. Dodge Trans Issue
  142. CHRISTMAS IN SEPTEMBER!!!
  143. stuck throttle
  144. Automatic Transmission Controller
  145. Noob with a question...
  146. Stock RPMs?
  147. HELP ME!!!
  148. G56 6speed tranny swap
  149. 400 HP?
  150. Straight Pipe?
  151. WD-40 + NV4500
  152. water in fuel light
  153. bogged down
  154. 4th gear lockup issues
  155. injectors
  156. no wait to start light
  157. need help plz tranny issue
  158. pump timing
  159. 1994 dodge ram 12 valve cummins acceleration
  160. Wipers come on when honking horn?
  161. Injector
  162. nv4500 output shaft
  163. help!!
  164. Help on a 95 12 valve
  165. Transmission cooling lines
  166. Blue Point Timing Sets
  167. Turbo Info--Craigslist
  168. 4 wheel drive..hubs wont lock
  169. delivery Valves?
  170. question
  171. NEED HELP
  172. truck jerking
  173. moving fuel plate
  174. Banjo bolt replacement
  175. lookin for p7100
  176. Cold start problem
  177. Skyjacker, or Fabtect
  178. 0-60mph
  179. starter
  180. Smoke screw
  181. star wheel adjustment
  182. 95 dodge 2500 5.9 cummins
  183. i need help!
  184. Smoke screw
  185. 1st cummins,, good deal?
  186. fuel plate question
  187. fuel plate
  188. fixin KDP damage
  189. Intercooler boots
  190. o/d while pulling a load
  191. pump timing
  192. Anyone have a stock turbo exhaust housing??
  193. clutch failure
  194. neutral start safety switch
  195. gauges...
  196. p3000
  197. Need a Clutch
  198. 2065 rack plug
  199. 1996 dodge diesel code 77 ?
  200. hate automatic
  201. heartbroken
  202. p7100 pump tuning
  203. 96 12 valve brake pedal goes to the floor
  204. Slow Starting
  205. tranny smell/ cooler
  206. stock tranny coolers
  207. programmer
  208. new convertor no lock up
  209. SOMEONE TELL ME WHAT PUMP TUNNING CONSIST OF?
  210. tranny smell
  211. speedo quit
  212. check list of things to do before storing truck
  213. rough start
  214. odometer fraud
  215. 47re line fittings?
  216. 97 12v dually $$$
  217. front main seal install
  218. 47rh cracking od housing
  219. MY TRIP FROM PHX TO SANFRANCISCO
  220. hp and torque estiment
  221. Why is my truck missing still?
  222. Any Bombers in Vegas that can help with the timing on my truck???
  223. clutches
  224. radiator cap bad?
  225. adjustable wastgate elbow
  226. Jumps in RPM at Hwy speeds
  227. another fuel plate post
  228. fuel filters?
  229. yes another mpg problem!
  230. 97 12 valve sputters on cold start
  231. 8.3 , 5.9 family
  232. how much boost with a stock motor
  233. 12v dies only SOMETIMES?
  234. tranny or convertor?
  235. what controls the PCM?
  236. Is my boost gauge working
  237. 95 auto, What's the best mpg I can get??
  238. speedometer
  239. band adjustment screw replacement question
  240. how much is it worth??
  241. oil leak
  242. fuel leak
  243. alternator problems
  244. lookin to buy
  245. check it out!!
  246. return line leak
  247. shifter removal
  248. first gear shift fumbles
  249. gauges
  250. clutch urgent.
