PDA
View Full Version : 12 Valve 2nd Gen Dodge Cummins 94-98
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18] 19 20 21 22 23 24 25 26 27 28 29
  1. decking the block??
  2. headlight help
  3. Truck is losing power
  4. Auto to manual conversion
  5. Engine wants to stall
  6. Need Some Help Popping/Miss When Warm
  7. motor mounts
  8. 60# Valve spring ?
  9. dieselsite.com
  10. why is my truck the only truck ive seen with no cargo light?
  11. TRAN REBUILD
  12. 94 12 valve fuel guage not working
  13. gas pedal sticking
  14. dana 80
  15. Looking at buying a 98 12v--lots of blue smoke
  16. knoxville tn, craigslist
  17. no heat
  18. fuel shut off solenoid screw
  19. dodge emblem help!!!
  20. INSTALLING 60LB VALVE SPRINGS
  21. MY TURBO
  22. 96 cummins 12v turbo upgrade
  23. 1995 No charge, no tach
  24. 12v with a hard hitting cylinder
  25. who here runs home made bio?
  26. 97 with a 160hp pump??????
  27. new 97
  28. cleaning injectors
  29. oil in coolant on 97 5.9 cummins
  30. turning up 12valve injection pump
  31. 97 3500 DUALLY MOSTLY STOCK
  32. smoke or haze?
  33. bad valve seat
  34. Power lag
  35. 12 valve won't start
  36. tranny problems
  37. difference in pumps
  38. 97 track bar problem
  39. cargo lighting
  40. timing on stock trans
  41. power steering and abs light?
  42. kdp
  43. 241 dhd to getrag
  44. slippage
  45. squeek
  46. engine rebuild
  47. what else can go worng and what r ur thoughts on what i should do
  48. 12v to 24v head?
  49. tc lockup switch wiring ?
  50. blowin oil quick need help
  51. 2001 recall for 95 dodged
  52. my gauge cluster is freakin out in my 98
  53. Running Cold
  54. dana 80 leak
  55. Ford cummins. 96 crew cab short bed 12 valve
  56. engine stand
  57. Oil cooler?
  58. Well that didn't help.....
  59. major problems
  60. leak in diesel primer pump
  61. help with timming SE missouri
  62. found this on another website
  63. Cold start issue
  64. high rpm stop screw????
  65. Oil pressure drop and wont start.
  66. 96 12v
  67. gear oil
  68. Problems with shifting
  69. front axle wrap
  70. In Tank Pump????
  71. New 98 Dodge diesel owner
  72. Cliffs Drag Truck Thread
  73. diesel in engine oil
  74. Timing???
  75. 96 4*4 front end help
  76. hey
  77. bumber alignment help
  78. throtle sticking
  79. white smoke sometimes
  80. Pros and cons
  81. turbo??
  82. smoke from tube under cummins
  83. 12 Valve with schwitzer s300
  84. water meth
  85. turbo upgrade
  86. more MPG???
  87. Well, time for a new truck
  88. 4bt swap
  89. Freeze plugs
  90. Loss of power?
  91. Exhaust housing
  92. Brakes?
  93. turbo
  94. block heater?
  95. aftermarket cup holder
  96. fuel plate?
  97. help
  98. Best tranny for 12v
  99. 5th gear vibrations
  100. engine
  101. no 5th gear speeds
  102. NV4500 input shaft
  103. 02 vs 95 intercooler?
  104. timing=more power?
  105. 3rd Gen charger on a 2nd gen truck?
  106. throttle linkage???
  107. mystery turbo
  108. fuel plate 96 5 speed
  109. gray smoke
  110. new 97 12valve
  111. Power??
  112. grid heater relay question
  113. need help pleASE
  114. new 12v : )
  115. hard starting
  116. o-ringing heads ?
  117. Starting issues driving me crazy
  118. Batteries
  119. Upgrades
  120. Leaky injector, or line?
  121. 5th gear
  122. question bout engine heating
  123. 2 wheel drive converting to 4x4 97 cummins
  124. Fuel plate for 97 cummins
  125. LOL, what's the purpose of this ??? 3x HX35s ?
  126. Downpipe
  127. Help Please
  128. Big Oil leak/ Tappet cover
  129. increase fuel mileage???
  130. oil temp gauge install 12 valve
  131. how much to have it rebuilt?
  132. d/d clutch wont disengage completely?
  133. White smoke rough running untill warm
  134. p-pump info
  135. broke another dam input shaft
  136. #6 leaking coolant and burning oil
  137. Just Bought a 97 12v :)
  138. Fuel line leaking...
  139. Pulling
  140. tran swap?
  141. where to get new battery cables
  142. lower heater fans not blowing
  143. Timing to 17,5°
  144. fuel milage
  145. not good
  146. Increase In Fuel Mileage
  147. 96 dodge 2500 abs braking problems
  148. 94 cummins 12 valve
  149. Gear ratio change "Help"
  150. Anyone know much about this part?
  151. tons of white smoke and runs rough cold
  152. Auto tranny help!!!!
  153. bad starter?
  154. transmission problem!!!!
  155. injector pumps
  156. NEED HELP FAST
  157. how to install running lights
  158. truck dies
  159. anybody else ever had this issue?
  160. timeing or injectors?
  161. help with high mileage 96 cummins
  162. 12V CTD had starting when parked on a hill. Fuel pump probem???
  163. 94 8.3L Cummins 12V (the 5.9's Big Brother)
  164. steering sucks
  165. Auto trans rebuild time?
  166. fuel shut off getting stuck
  167. Drivers side front tire noise!
  168. 12 valve timing
  169. Broken springs.....need help pls
  170. Fuel Leak
  171. Is my NEW lift pump failing on me?!
  172. looking to get truck hauled in vt???
  173. Door Hinge
  174. Question for a P-pump pro
  175. posi 355
  176. Modifying my AFC
  177. 94 12 valve for 3k!!!!!!!!!!
  178. swappin auto to manual
  179. Plastic Cover on drivers side???? What is it??
  180. bent frame
  181. sloppy steering
  182. 95 12 valve throttle position sensor
  183. oil leak
  184. heater grid relay
  185. Cheap cold weather tips
  186. dropping trans
  187. Steering Wobble.
  188. milage problems
  189. Rear Disc on a 95 Cummins
  190. my first 12v. help?
  191. oil leak!!!
  192. Thermostat HELP Please!!!!!!!!!!!
  193. tranny swap
  194. HELP!!
  195. KDP??
  196. steering is messed up
  197. center drive shaft bearing wtf
  198. new transmission actin up?
  199. 98 12 valve pump
  200. nv4500 shifter.
  201. Blue Valve Springs?
  202. low fuel pressure
  203. Need More Power
  204. Injector Lines leaking
  205. auxilary speedsensor???
  206. 97 brake issue
  207. Exhaust vs Performance chip
  208. TPS
  209. PCU PROBLEMS!!!
  210. trans problem
  211. hydro boost issue?
  212. How heavy is the flywheel on these babies ?
  213. 2nd Gen Cab w/ Newer Style Fenders???
  214. truck kits
  215. Transmission Line leak
  216. exhaust manifold
  217. front driveshaft
  218. no ac or heat
  219. Fuel shut off relay
  220. no power
  221. Converter issues
  222. 4 to 5 speed tranny
  223. boost?
  224. flatbed stacks help please
  225. Emmission test went bad
  226. trans leak from pan?
  227. Help Please
  228. Where is my antifreeze going?!
  229. Smoke Screw
  230. Radio issue please help!
  231. truck is fixed
  232. governer spring
  233. whys my truck so clunky
  234. Engine, or Block Heater
  235. AFC help
  236. he 351vgt on a 12v
  237. Quick Question
  238. 1994 cummins
  239. Crankcase Breather tube
  240. 4x4 help
  241. braking issue
  242. truck problems
  243. Busted Hubs
  244. fuel mileage
  245. starter problem?
  246. Pinion nut removal
  247. 84 Bosch pump, adjustment issues
  248. Front seal
  249. hard start
  250. swapping nv4500 to auto
