- PART NUMBER CHECK IT OUT!!! IT HELP ME OUT. MAYBE IT WILL YOU TOO
- Holset hx40 wheel and housing p/n's , if you care
- Bad Injector?????
- Gov. Spring Adjustment????????????????
- no plate and gutted afc to plate and tuned afc?
- P7100 injector pump shut off question
- Track Bar Question
- Headliner Woes
- KDP?
- Fuel gauge
- 47re tv cable concern.
- volt meter
- afc plastic hose boost line?
- Intake Horns vs Flow
- 1995 trans lines and cheap paper clip fittings
- dual exhaust
- Transmission computer maybe?
- tranny swap
- 47re Won't shift at wot
- strange noises (engine)
- What do I do?
- Tranny Problems Maybe ???
- Trim
- NV4500 questions
- 12 valve
- '94 F350 knuckles & hubs on '97 2500?
- I'm assuming starter?
- Tires
- Oil in water?
- Fuel Plate effect on Auto trans life
- Gutting your AFC?
- $150 solenoid or $1500 P pump?
- Best place for freeze plugs
- Blowby oil screen?
- trans problems
- Tranny swap ??
- lift kit/stacks advice
- Thermostat Problems
- Good deal?
- Replacing motor mounts sucks
- help Hard starting 96
- Good Deal?...or keep lookin kid...?
- Wiring Harness
- Super B
- Vaccum diagram
- Missing at 2200rpm?
- Gauge Question
- coolant on the ground.
- Starter Hits my New SBC DD Clutch Flywheel
- Sway Bar Links=Death Wobble?S
- AfterMarket 47rh
- Front Driveshaft
- I Think My P Pump Took a Dump
- poping at 2000 rpm or more
- Dash Light?
- grid heater delete
- band adjustment
- a couple questions
- trans issues
- Lift Pump Question
- Air horn bolts
- Batteries Suggestion?
- mopar paint jobs
- Grid heater ground?
- trans help
- ok here it goes
- which ones?
- obd2
- 12v LP bypass plate
- fuel plate
- Heat Shield BHAF
- 4x4 help
- 4x4 slips in and out.
- Adjusting Idle RPM
- 12 Valve help
- new trans
- Dodge!!!!!!!
- how low can i turn my idle down
- waterboy system
- wastegate
- track bar
- turbo shaft play
- about had a heart attack yesterday
- overhead display
- fuel pin
- head
- P7100 pump numbers.
- pull cable for fuel shut off
- egts
- Stock 12 Valve going for 400-500hp. Any suggestions?
- still leaking oil
- blow by
- thermostat
- 60lb valve spring installation help
- tune up
- fuel plates
- converter lock up
- 6-speed
- Why wont my truck warm up
- power steering
- timing
- block heater
- got a bad hi/low idel miss, any ideas???
- 5.9 vs turbo 400 with gearvender
- nonwastegated turbo
- 12 valve
- fuel plates
- thottle position sensor
- sliding the fuel plate?
- bed toppers
- weird
- just a few auto meter gauge questions
- valve body and tc
- tire clearance
- ABS
- best 12v
- Trans cooler lines
- i think this is the last issue
- more issues
- rpm
- Intake heater
- stack
- Looking at 60lb valve spring how do I install myself ? and what brand would recommend
- do they make chips or programmers for me?
- new tranny with problems, GRRRRR!!
- injector torque specs
- Don't get mad! Where should i start?
- Turning up my timing tuesday what would you bump it up?
- Can any one help me KDP came out and need to fix how can I do this cheap?
- crossover tubes?
- 12 Valve Fuel Economy
- some more quesions
- gov springs
- What To Buy ?
- How to get oil out of antifreeze
- 2 QUESTIONS
- 96 Wiring Schematic
- 95 46RE Won't Shift
- Seat Belt Won't Unlock????? HELP!!!!!
- Somethings Tapping
- Totaled Truck..Speculation
- Something Gave
- Oil Pressure
- KDP repair kit
- How Much To Fix KDP?
- Dually To Single Wheel Conversion
- Blue Smoke
- All New Parts For The Front End...
- Water Temp Sensor
- Lift Pump Quitin, Any Economical Home Builds
- 0 plate and NO SMOKE
- Trans Shifts Real Hard...
- Temp Gauge?
- Smoke Button Help...(attn. cumminsdieselboy)
- No 4WD
- Don't Want GM Parts
- Blow By Every Now And Again Blue Smoke
- 98 12V Steering Problem
- White Smoke?
- A Few Auto Trans Questions
- Good Buy?
- New Fuel Filter Setup
- I NEED SOME HELP
- Looking For Some Stick Ideas
- 12 Valve Dog Off The Line
- What Torque Converters.....
- Oil Line?
- NV 4500 Stuck In 5th
- Grrrrr... 3rd Head Gasket In 6 Months!
- My Parts So Far........
- Trading A Ford For A Dodge.... What To Look For
- Where Is The Catalyst Sticker On 98 12 Valve?
- Squeaking Noise From Speed Bump?
- PS Pump Bushing
- emission requirments for texas? movin there
- What Does The Shutdown Solenoid Shut Off ?
- New Fuel Plate And Which One?
- 12 Valve Shuttering
- Tranny Slipping
- Idle Problem
- Fuel Tank On The Dodge
- How To Make A P-Pump Like This?
- Will 37s Fit?
- Fuel Shut Off Problem
- Buying A Cummins I Can't Look At..
- Timing cover torque specs???
- 215 injectors
- Drained Battery wrecks CD Player?!?
- I need a replacement transmission
- 12 Valve Engine Problem
- More Delivery Valve Questions
- #0 plate
- Lost 5th gear...
- Bad Steering Issue
- T-Case Issue?????????????
- What's Up With My Steering?
- Oil Pressure
- Would This IHI RHB7 Be An Upgrade On My 6BT?
- 215 HP P-7100 Question
- 60 lb Valve Springs....
- 1992 D350 Won't Start
- I Think I Just Bought Another Rig...
- Intermittent Problem?
- 12V Input
- Delivery Valve Questions
- 12v Here To Stay
- Dually Conversion
- 1994 Injection Pump
- Vibrations From The Front End
- 4x4 Broke
- Need A TPS
- Headlights And Blower Motor
- Pyro Problem
- No Smoke?
- Loss Of Power
- Speedometer Quit
- 3rd Gear Let Go Today
- Thermostat?
- Trucks Dead...Again!!!
- 8.3 Pump On A 5.9
- Fuel Pressure
- Truck Having A Problem
- Major Trans Problem….
- NV4500 4x2 To 4x4
- NV 4500 Clutch Install
- Shifter From A 96 To 94
- Pinion Seal
- NV4500 To NV5600
- Bad Vibrations
- Alternator Wiring
- 12v Turbo Maxing At 17PSI
- 12v Blue Smoke
- Speedometer Correction
- Thinking About Selling The Dodge
- Smoke
- Speedometer Quit
- 4.10 To 3.54 ???
- More Trouble With My 97
- Starting
- Lift Pump Tick
- Not Sure, But Could Be A Problem!
- Axle Bolts
- Setting Timing From Scratch.
- 12v Fuel Pressure Test Fittings List
- Gear Ratio Questions
- Timing
- Trans Overflow?
- Transmission
- Whats Wrong With This Truck????
- Losing Coolant
