- 47RE test ports/temp gauge question
- marine head gasket?
- chevy cummins swap questions
- Overhead temp gauge question??
- Massive oil leak, need help
- Washer Fluid Sensor
- Instrument Cluster not working...help!
- Engine nock at low rpm
- 02 sensor???????????
- north texas ?
- Hey Gotta<3a12valve
- belt routing???
- KDP Carnage!
- Wont Keep a charge
- warped head oil in water.
- "Chugging" question
- new truck and new questions
- P-pumped 24v q's
- Temperature Gauge
- Turbo with no wastegate
- no smoke and breaking up
- ANY other 12 Valvers in Alabama??
- Water in oil?
- 47re tranny
- Fair price on 8"bed?
- New 1997 Dodge Ram! some driving issues!
- lockup
- AFC foot questions.
- shift kit
- Transmission fun
- Druss
- P7100 Injector Pump Removal and Installation
- Tach will not read
- 1996 fender replacement
- belt tensioner
- New fuel solenoid won't pull up?
- no fuel in prefilter
- how to get sponsers
- Truck problem high egt laggy no smoke.
- P7100 star wheel plug options
- transmission downshifting
- 95 v10 dodge to 12 valve p-pump bus motor
- HVAC Vents and Vacuum
- 94 dodge 12v
- steering wheel r&r ?
- chicken lights
- Starting issue.
- Front End Pop
- dana 70 locker stuck help
- BATTERY?
- rods and pistons
- diff fluid
- no fuel?
- Noise from trans/t-case
- low boost
- Brake questions???
- Rebuild- Matching crankshaft casting numbers?
- Still having trans problems
- HX35 Shaft Play
- 95 cab & chassis transfer case
- Truck cuts off
- HEADGASKET?
- Heat Hand
- Engine Adapter Plate Differences?
- Darn my life
- Stripped banjo bolt on the injector
- Air bag light and cruise control probs.
- charging issues
- Fuel line size
- passenger floor board wet?
- Blue Smoke
- ac charge kit?
- clear smoke?
- Possibly buying a cummins. Need info fast!
- Mystery bolt at rear of p7100 pump
- tranny issues
- electrical starting problem
- FUEL PLATE QUESTION?
- How to troubleshoot 47re OD & TC lockup hunting
- Can't decide on a clutch
- Transmission heat exchanger
- NO AIR OUT OF THE VENTS
- Re Leaky injecters
- help with measuring new head gasket
- No fuel to injectors but fuel at supply..
- NEED TO KNOW PART ASAP!!!
- 12v Stalling Out
- 12v Exhaust
- Pennzoil manual trans fluid??
- Whats this truck Worth...?
- putting engine in
- Dually to single rear wheel
- Delivery valve holders.
- Sticking throttle! Not good!
- OFV mod w/ bic pen question
- Fuel plate out.. Ideas please?
- 3-4 accumulator piston
- Think this is a fair trade?
- FUEL PRESSURE?
- Shutoff solenoid for 98 12V Cummins
- HELP!!!! NEED a headgasket bad!!!!
- Bad Shake
- ..Stock rear-end gears?
- Injector Question
- Cummins 12v Question
- 47Rh HELP!!!!
- Tranny question
- 09 Steering upgrade
- gasket sets?
- cruise control only working partially, vents only work on floor/defrost. Vacuum??
- super sensitive throttle
- death wobble and repairs
- HX35W different part numbers and difference?
- Engine misfire? Odd vibration
- Fuel Filter
- Cam install
- Brake lights
- Couple questions about my 95 12 valve.
- fuel filter change/ problems
- Anyone want to trade?
- throttle sticks
- AC won't change speeds! Why?
- Strange ticking comeing from drivers side near injector pump
- EGTS
- which harmonic balancer to run
- Cummins identification
- Pump timing for $200
- Blow by tube?!!
- leaky injector
- turbo question
- Rear End
- what year engine?
- felpro headgasket and head bolts
- Amsoil in nv4500
- Do I still need my TPS?
- Tach not working or engine not reving?
- Rear Brake Advice
- transmission 47re
- Fuel Leak at WIF sensor
- 47RH Gearing question
- pulled head any thoughts on rebuild or not?
- 4wd Light
- Major miss
- Torque Converter un-locking and locking
- power steering return lines
- short block, head and pump weight
- main and rod bolts
- 94 12 valve fuel help
- Need help with tires?!
- which fuel filt housing should i have please help
- BLOWBY ?
- bought a hx40. now need the t3 to t4 manifold adaptor
- Craigslist turbo - no ID tag
- RV exhaust manifold or stock manifold
- bus short block
- 96 cummins tranny issue...
- Speedo acting up
- Got me a new truck today!
- Lowering a 2nd gen 2" Front 4" Back Questions
- pulling motor
- Question
- Turbo Questions
- Rotors
- how to drill out 12v injectors
- 95 12v intermittent chugging and missing
- Broken egr bolt on exhaust manifold
- Stalling issue
- Rear end swap?
- ac compressor questions
- 1996 Dodge w/ Cummings
- Loss of power
- Preventive Maintenance
- first cummins project
- 47RE, Odd Issue
- PATC transmissions??
- Air horn installation
- Fuel overflow valve 1994 cummins
- valve spring help!!!!??
- START AND DIE
- new to cummins world... tools to show myself the ropes?
- 96 3500.
- head gasket or oil cooler?
- Fuel plate
- noise from p pump
- injectors
- Installing performance torque converter 47rh
- 96 2wd to 4wd
- new to cummins 12 valve
- TOW MIRRORS
- SoCal dyno
- 47re auto
- Mack plug ?
- 47RH (I am new here)
- 2 post lift for the cummins
- 97 cummins 12V
- Strange start up problem on '94 Cummins
- Sanden oil and freon?
- Turbo question?
- 3rd gen clearance lights on second gen
- NV5600 Rebuild DIY?
- fuel problems
- how much can you gain by tuning the injection pump properly
- Axel
- 3/8" npt weed burner valve for fuel pressure gauge
- fuel pump tuned
- torque specs
- Delivery valves or injectors
- FRONT PASSENGER SIDE AXLE SEAL
- need a little help on my fuel plate and EGT's
- JM Turbo
- DV's for 370's
- watchdog
- hx55
- blow offf valves
- Thunderer Tires
- raptor 150 max PSI?
- starter solenoid to fuel shutoff relay?
- Nv4500 or NV5600.. Can't Decide Which One!!
- useless stuff
- compound with aurora 3000 and stock hx35?
- Injectors
- is my thinking right???
- dies at wot
- s300 nonwaste gate
- Question on my gauges
- Cruise control works (More or less) Why?
- Bad lift pump?
- Airdog II, but which one?
- Trying to wire up Tc lock switch, no Trans relay in relay center
- Oil Leak After Fuel Plate Removal
- 95 cummins to 99 v10 swap
- my dodge 3500 4x4 needs help
- Auto to nv5600
- Pics of your rig and how many miles xxx
- need halp...
- benched pump wont start
- NV4500 swap speedo not working
- Low Fuel Pressure
- Adjust idle
- Valve question.
- Battery going Dead
- P pump leaking
- This pee pump is confusing me.
- 1997 dodge vaccum pump/4x4 issues/exhaust brake issues
- Picking out the right Clutch?
- 12 valve mods
- Goerend torque convertor quotes
- best twin setup
- rear driveshaft
