- Need Fuel
- Turbo Rebuild Problem..
- governor sring questions
- 47re problem HELP
- Soot???
- GOVERNOR SPRINGS INSTALLED, 2 QUESTION
- 94 12 v
- no heat little tiny bit out defroster
- MANUAL PROBLEM
- Stock trans specks
- sensor help
- pro fab trans ?
- alternatives solutions to kdp ???
- weld the kdp?
- 1500 hp possible?
- help 400-500 hp ??????
- fuel sending unit leavel kit problems
- chugging help
- still having tranny issues
- Head and head gasket questions?
- wont start
- shift kit
- Pulling Trucks
- AFC boost line location
- turbo difference
- Stock Transmissions
- tranny issue need answer asap please
- Fuel Plates
- P7100 bushings
- 98 12v fuel leak
- injection pump. p7100
- star wheel
- 12v head gasket problem
- badges,emblems
- head studs???
- nv 4500 backing plate and bellhousing
- Buyer precautions
- Pump questions
- mix and matching clutches and flywheels
- flatbed question
- can you stud a 2nd gen with the engine in?
- Little blue gremilins...
- 4wd help
- Fuel usage very weird
- 47rh not tcc not locking in
- New to 12v's got a few maint questions
- will a 2001 auto trans fit in a 1996 dodge?
- fuel plate
- 12 valve issue
- 98 12v question
- 12v problems
- afc tuning(new england tread with p pump cut out)
- Oil Pre-start for a rebuilt?
- 95 tranny
- 12v bearing replacement
- #6 or #5
- need help?
- Thanks a bunch!
- Building Bigger now looking at Injectors and Meth
- Oil pan gasket replacment
- 98 12v head gasket
- For Sale: 97 12 valve 4x4 2500 Ext cab SLT/Auto
- Turning barrels
- 12valve tuning? I need help!
- Little coolant line on my 95
- Anyone in Utah
- What is gonna happen
- trans cooler lines
- Rear end ?
- Thermostate and heat problems
- tranny issues
- 88-98 1/2 ton chevy gmc body to dodge frame???
- Frame fabrication
- cab
- Torque converter lock up switch and "CHECK ENGINE"
- Manual VB
- Timing..?
- WTB94 thru 02 DODGE DANA 60 FRONT AXLE WITH 4:10 GEARS
- Need mpg tips
- boost
- Overhead console lights
- 95 cummins wont shift into overdrive or 4th gear please help
- turbo problem
- batmowheel
- twin set up?
- 3 inch or 4 inch straight pipe
- injectors
- 1994 cummins tourque convertor questions. what one to buy and hore power rateings?
- Death Wobble?
- Heater
- Front main seal
- 265/75/16 MTZ tires on 3" lift????
- need help with garret t 66 turbo
- 6 speed manuel?
- Stacks
- whats the bet for a set of twins???
- Wont lock into 4wd
- first post
- Advice Appreciated
- holset ht3b
- 96 12v brake/ps problems
- Slow idle
- Winter oil
- Another 47RH Problem
- 97 dodge 5.9
- Stack?
- AFC
- Miles
- Rpm question
- clogged injector?
- Tow mirrors
- Allison swap
- hx 40 turbo
- Winter question
- K10 cummins swap
- Cab lights
- 5 speed swap
- Winter start up help
- Twin turbo info
- 12 pillar gauges?
- 12 valve hp
- 12 valve stalling
- Stack question
- How to install a stack?
- Heater block question?
- 1996 12 valve help!!
- hp range
- Air In Fuel?? NEED HELP!!!!
- Mystery torque converter
- Control Arm Qs
- price check for truck
- Exhaust idea need help engineering
- 1200hp!
- 4 inch downpipe
- What to do! 98 12 valve
- will this work?
- what size turbo?
- SNOW PERFORMANCE Stage 3 Diesel Boost Cooler QUESTION!
- 94 dodge with 2000 or 01 wheels
- dually
- 95 trany
- help
- hate this transmission..help
- Used 5.9 cummins with locked up P pump
- Banks Twin Intake
- 4x4 light always on..and front driveshaft always locked in
- HX40 turbo
- 2nd gen rear disc brake conversion
- turning barrels
- Crank case breather
- Who knows anything about EMPs
- How much HP will i have
- extended cab short bed dually?
- axle u joint?
- Head Leak
- Help finding dodge parts!!!
- fuel pressure gauge going crazy
- a/c hoses
- Boost elbox2
- Trani questions
- Flywheel Housing
- tow mirrors?
- Low Mpg
- Truck with a few mods.....not so fast??
- will this work
- Not getting heat from heater
- How To: Adjusting Idle Speed on a 12 Valve P7100
- truck idle
- Beginner engine mods
- HELP!! Vacuum Line and if so where does it go!!
- Smoke question
- cummins block heater
- hooking up a fuel pressure guage
- torqu converter wont stay in lock up 1994 dodge cummins
- 94 head lights randomly turn off!
- Tappet Cover Gasket
- HX35 Rebuild Delay...
- ABS Brake Light
- DO I need the Fan Pulley??
- Torque specs
- First road trip in the 12 valve!
- Question for the Gen II 3500 4x4 crowd
- Growling noise while turning.
- Hissing noise
- newbe here
- 3rd gen springs in a 96?
- money well spent.
- the holy grail
- just a general question
- 97 dodge
- squeeking noise
- lifting my 4x4
- 1998 12V auto REBUILD???
- turbos, wat would you suggest, where should my money go?
- 1996 Ext cab value
- Head light switch?......
- smoke screw on p pump???
- Hello all
- No Bottom End!!
- loud ticking or missing at idle?
- FordCummins or Destroked?
- Turbo Questions...
- Help Squeeling noise from the motor
- oil temp and oil pressure gauge on 12v
- front end noise help!
- happy veterans day!
- Odd shift points???
- 1996 cummins not running right after 2k?
- my plans, what is your input?
- fuel additives
- Fuel plate
- 96 12v 5.9 cummins towing mods!?
- Check this OUT!
- ddp injectors
- a/c
- Waste gate question
- New guy saying hello...
- What's the worth
- 98 12v problems.!
- 12v Swap into 1999 F250
- Found this for yall!
- fuel plate
- Need some vgt help
- Hard starting
- LASER CUT DV's
- Front End
- Transfer case help!
- Couple of questions... mostly turbo related...
- Positive report on 1A Auto Tow Mirrors
- how do i turn up a ag pump?
- 1998 cummis no charge
- fuel gauge doesn't work, not sending unit
- Lift Pump
- lookin for advice on a truck im lookin at
- afc
- Chevy/ cummins build
- 96 12valve cummins dually
- Last 12 Valve?
- how can I tell what rear end I have in my 97 12 valve?
- speedometer inaccurate after major swappage
- EXHAUST FLUTTERS AT LOW RPM'S HELP!!
- Heater Grid
- fuel gauge does not work need help!
- 12 valve injector pump wont adjust
- modifying injection pump
- nv4500 Swap Safety Neutral Switch
- Need a good sti
- 47RH help
- fuel lines
