- Transmission Question
- is a larger turbo needed?
- Turbo Play
- good buy ?
- top end power?
- lift pump
- 47re wont downshift
- #6 injector leaking coolant
- rebuilt trans wont move
- what tranny do i have?
- Help me new to 12 valve!!
- bllack diesel ?????????????
- problems after p pump swap
- tranny issues
- 2nd gen pcm interchangability?
- Blowing oil out the dipstick tube
- Blowing oil out the sipstick tube
- New to Diesels
- Truck refuses to stay running at idle
- swaping a auto out for a nv5600 on a 98 12v?
- how much lift on stock Radius Arms??
- When is it time to upgrade my Transmission
- old boost gauges-wierd calibrations..
- Anyone have this problem? Clutch issues
- NEED HELP!
- Front UJ Service
- is my turbo going out?
- 2nd Gen Air Ratio Spring adjustment?
- fuel problems
- Looking for a sleeper
- Hello
- Automatic trans having overdrive issues
- uhhh ohhhh 12 valve
- Timing issue
- wierd noises
- electrical problems HELP PLEASE
- 96 cummins 2500 slt indash gauges
- fast rig
- Auto Tranny No speedo, no overdrive, 47RE may have solution for u.
- Lower EGT's
- GENERATOR LIGHT CAME ON
- 96 dodge ram 3500?
- I need Help!! 24v to 12v swap
- 12v in a 1970 ford sport custom
- 97 ram 2500 tranny troubles
- got 1st, 2nd gear an thats all?? need help
- how to hook up a pot
- 98 12V maint questions.
- convert auto into standard
- GOV SPRINGS AN TIMING
- antenna mount
- 4gsk
- Hooking up gauges?
- What Timing to Run
- 68RFE in a 12 Valve???
- Cummins Vs. 6.5
- CA. diesel HELP!!
- valve top dead center
- 47RE
- trans cooler
- help 12v conversion
- can only column shift to get 1 and 2...help
- Miss at idle
- installing new injector pump???
- Oil pressure gauge high. Kilopascal
- PATC Transmissions???
- Transmisson
- Transmisson
- buying a 94 to 98 trucks
- headgasket ?'s
- got a injector size question
- Turbo spool trick... Fuel cut?
- NO SMOKE?????
- Bed Bolts
- Ring gear on flexplate/flywheel
- 3rd gen parts, 2nd gen truck??
- Fuel Gauge issue
- DODGE 12V
- Would you burn fuel from the early 80's?
- abs/brake lights on
- Banks high ram intake on a 12v?
- per4mance innovations transmissions
- water meth injection
- Trying to make more power
- Project Cummins Kodiak
- 96 fueling problem as in none!
- idle help
- Fuelling trouble
- Trans trouble
- killer pin
- Fuel heater
- help please!??
- 96 Slipping Tranny
- 97 cummins loosing power
- 1996 cummins swap into a 1992 dodge gasser
- Lucas
- new rubber?
- axles?
- 97 problems
- rebuilt 47rh slipping when not in lockup
- new dash
- gauge cluster lights not working
- walks all over the road help
- 97 fuel problem ?????
- i need some creative ideas
- 4.10 to 3.54 questions
- looking for a pic
- Driving Habits
- Fuel Module
- fp issues
- Stalling issue, and fuel plate question.
- keeps blowing starter fuses
- trying to understand this lock up switch???
- nv4500 swap wiring questions?
- tranny went boooom
- knocking issues
- clutch choices
- 12 valve popping..?
- diagram's for a 96 cummins?
- What is a 190hp ppump worth?
- 96 nv5600 swap/no start
- bad injector pump???????????
- looking to buy a dodge diesel with NV4500 tranny preferably cheap.
- rims
- Where do i start on a stock 96?
- 4wd drive problem
- advancing timing
- Want to trade 5x0.14 DDP's
- fuel system
- oil dipstick
- trani cooler tube?
- somebody help
- difference between 97 and 94 motors
- tire fitment on a 97 dually
- Cold Idle issues
- nv4500 swap questions
- Does your truck leak oil?
- down pipe
- turbo ex elbow ??
- How do you remove the push pins in the fender liners?
- Lookin to buy a nv4500 or trade my mint 47re for a nv4500 kit.
- Anyone done a Half-Ton swap ???
- killer dowl pin
- 97 dodge neon 2.0 5 speed cv axel problems
- Oil pressure sensor location
- NV4500 issue
- silver 64
- Oil pressure
- completely SHATTERED my driveshaft center bearing (not sure what you call them)
- #4 plate
- Looking for NV4500 conversion kit!
- possible charging issue
- 5'' exaust
- exhausted!
- 3000 gsk / 4000 gsk pricing ?
- Dodge 2500 12v cummins tranny swap
- dowel pin problem
- gear case
- transmission shifting weird
- custom lift pump
- break off screw on p pump
- Waste gate, shoulda thought about that
- damper proff screw on p7100 pump
- modifying stock TC
- wastegate and star wheel
- Neutral safety switch
- 4k gsk plate or no plate
- 450 hp
- hx35 turbo rebuild kit
- NV4500 problem???
- Silencer Ring Removal - Affecting CFM ?
- Head lights went out, then came back?
- NV4500 is this normal?
- auto to standard swap!
- Need some help diagnosing my no-start scenario on 12v conversion
- need some input
- 4x4
- wastegate question??
- loping at idle
- NV4500 conversion
- lowering my EGTs???
- dash
- Turbo Upgrade?
- trans upgrade???
- Brake calipers
- Turbo
- 1999 trans in a 1997?
- trans trouble (again)
- Really Stiff Steering!
- my 97 stuuders than stalls while driving???
- another timing ?
- Studders between 1000 an 1400rpm
- axle seals and gear oil everywhere!
- 66/71/14???
- Do I really need studs?
- Need to figure out mileage drop
- 4K GSK?
- problems bleeding lines after pump swap
- engine starts ticking then shuts down
- tranny troubles....yay
- 94 6 speed swap
- cylinder head numbers
- $800 94 5 speed truck missing on front two cylinders
- 1995 Dodge 5.9 Why does it smoke when cold
- Too big Injetors?
- what should my gauges read
- Ugh... Help? White smoke issues
- How would this work as a single?
- 96 12 v for $1250
- what gear ratios should i get?
- any suggestions on upgrades that won't hurt my tranny
- problem with high rpms at 65 or 70 mph
- Ceramic clutch. Your 2 cents.
- Input shaft nv4500
- Bad injectors?
- 1998 cummins egr delete ?
- 12 valve with blue smoke
- Broken Bolts!!!
- Interior lights fuse Blowing.
- whats everyone getting for fuel ecconomy
- HX52 over HX35 :) 750hp doable ? streetable ?
- Smoke
- extended cab rear molds and headliner questions
- exhaust manifold need some help
- Rebuilt transmission slipping need help fast! 47rh
- Chrome Rocker Panels?
- finding stacks
- websites
- hub assembly/ ball joints
- Anyone here removed their door moldings ?
- DV replacement
- 12 Valve to 24 Valve Swap
- electrical wire on lite switch
- 38MPH electrical gremlin
- broken "throttle" spring
- Little help
- turbo question
- clutch recommendations
- question about boost
- thinking about some mods to the 97, need input
- STOLEN TRUCK
- need help......
- Dana 70 ARB F/S
- 12 inch to 13 inch clutch
- stuck in gear help
- Emission test ?
- coolant temp jumps around
- what mods??
- Emissions test revved to 3500 rpm
- Fuel cap hissing
