PDA
View Full Version : 12 Valve 2nd Gen Dodge Cummins 94-98
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 [19] 20 21 22 23 24 25 26 27 28 29
  1. where be the ring
  2. need help with my speedometer!
  3. removed fuel plate and no start
  4. removed 12-valve fuel plate will not fire/help
  5. needs help
  6. Tires
  7. Idle messed up
  8. wheel bearning
  9. no lights???
  10. help
  11. Transmission problems 47re what else
  12. turning screws
  13. Fuel Shut off Solenoid
  14. And another question this time a fuel leak
  15. dead air bag and cruise..??
  16. 47re problems shifting
  17. 4wd help please
  18. Couple of ?'s
  19. Just bumped my idle speed up
  20. truck wont rev up in rpms
  21. Dana 80 dually
  22. looking at a 98 2500
  23. smoke
  24. pump timing
  25. tow mirrors... i know i know
  26. remote start
  27. ebay
  28. weak 12 valve
  29. manual to an auto??? any info on controls
  30. Trans Rebuild...
  31. gauge problems.....?
  32. how to get injectors out of 12 valve
  33. Trans cooler lines
  34. Dome Lights Always On!
  35. looking for a streetable "quick spooling" 500hp
  36. vgt turbo on a 12valve
  37. 47RH to a NV5600
  38. Paint time HELP ME CHOOSE!!!
  39. somethings not right
  40. how can i tell what injectors i have?
  41. Fuel leak
  42. I got problems
  43. Speedometer not working right and very high RPM
  44. Urgent: Anyone have info on replacing rear axle/hub seal? (D80)
  45. Cab lights on a 1996 truck
  46. 98 12 valve quad cab 4x4 for $5500
  47. twin turbo
  48. loosing power while towing
  49. auto to standard swap???
  50. does this afe tube help at all?
  51. Frame
  52. stack drone inside cab?
  53. engine bogs down and dies
  54. how many miles on your truck? ever any compresion problems?
  55. best injector cleaner
  56. Hello, y'all
  57. steering/brake issues
  58. NEW TPS
  59. 5th gear nut
  60. Changing mods
  61. truck keeps losing prime! where to start?
  62. nv4500 bellhousing
  63. gears I.D.
  64. Truck dies when in gear
  65. replacement fuel filter with out a drain
  66. Truck wont start after swapping to 5speed.
  67. engine pix request.
  68. 12 valve fuel mileage
  69. Need socket sizes!
  70. pump diagram
  71. Clutch break in period??
  72. 12 valve wont start!!
  73. Electrical short?
  74. heating problems
  75. No Power
  76. head lights on 94
  77. here is one for ya
  78. truck died wont start back up replaced lift pump
  79. what is it? timing?
  80. No overdrive
  81. torque converter lockup switch??
  82. 96 12 valve wont idle, gray smoke
  83. turbo question
  84. just got a cummins, have some questions
  85. gauges wont work & gearing issues my first cummins in need of some help.?
  86. Bad 4th gear syncro's, whats the prefered method of changing them?
  87. Installed new cummins thermostat...
  88. kdp problem
  89. injectors
  90. oil leak
  91. 1998 dodge 12 V start problems
  92. 94 12 v dies
  93. nv4500 tail housing
  94. new to diesel bombers but on my second cummins need a little help
  95. 1998 12 valve 2X4 2500 fuel milage
  96. 12 valve high egts
  97. tps????
  98. 96 12valve auto vs 96 12valve 5 speed
  99. rough idle
  100. keep your 12 valve save money
  101. headlight problem
  102. Gearing for 37's???
  103. my truck has a miss
  104. dies while driving down the road
  105. Oil Pressure/Supply Questions
  106. new to diesels need help
  107. fueling at wot and afc tuning
  108. blow by tube
  109. Check oil in transfercase?
  110. Shopping spree today...
  111. radiator wanted
  112. Starting issue
  113. 5 speed question
  114. tranny temps??
  115. having trouble settting timing
  116. Tranny fluid and transfer case fluid question?
  117. stock tranny
  118. painted 94-02 wheels
  119. need help about overdrive ground switch
  120. head gasket
  121. trans acting up
  122. Auto Trans
  123. Injectors
  124. any 47rh experts out there?
  125. 94 12v bad tps...replace with new still bad
  126. Oil leak 95 12 valve
  127. slightly bent aftercooler
  128. Auto Trans mod for 12v
  129. L.E.D. Taillights
  130. hard starting
  131. what the sound mean?
  132. 47re output bearing failure
  133. p7100 pump ofv?
  134. Shifting problem =/
  135. won't start this morning
  136. worn bell crank
  137. alternator charging problem
  138. no overdrive any suggestions ??
  139. injector miss
  140. HELP
  141. truck won't start, there's smoke but no fire
  142. NEW PARTS
  143. Weird Feeling when turning
  144. throttle linkage?
  145. p-pump problem
  146. help fuel leaks
  147. correct fuel pressure readings
  148. oem number on 97 p7100 pump
  149. 12 v cracked block
  150. Intermitant stalling - fuel shutoff?
  151. Hold Down For Battery
  152. Alternator Isn't Charging Bad ECU need help plz!!
  153. Tappet cover
  154. Running kerosene, timing issues...
  155. head shaved 20 thou. 10 thou. gasket, will the valves hit?
  156. need some help on my 12 valve!!
  157. hehehe, did some drifting :')
  158. Hard Starting and white smoke.
  159. NV4500 Swap
  160. Blown Head Gasket?
  161. Brakes
  162. woodnpig
  163. 60lb valve springs install
  164. 12 VALVE FUEL PLATE
  165. reasonable amount of labor to pay?
  166. i need a bigger hammer
  167. fuel leak
  168. nv4500 -- 4th gear
  169. 5.9L specs 94-98
  170. has anyone made a "how to set p7100 timming" video?
  171. 1939 Dodge 1.5 Ton Flatbed Build thread
  172. Gov Spring
  173. woodnpig
  174. Questions
  175. Break away bolt?????
  176. Help with AFC ?????????
  177. Steering play
  178. where can i get this fuel line (pic)
  179. Need some tools for the NV4500
  180. 1994 D valve question 191's
  181. oh the choices
  182. no start
  183. Bunch of question 98 12v
  184. tranny exchange cooler
  185. Making 94 Dodge Diesel the Bomb
  186. intercooler relocation
  187. MBRP straight pipe?
  188. Have you removed your fuel heater?
  189. heater delete
  190. Timing case repair (dowel pin)
  191. diff/axle
  192. Sleeved 98 12v
  193. Trans wont shift
  194. Lift Pump Symptoms
  195. Free Technical Article on the Cummins Lift Pump
  196. Maunal trans guys...
  197. tranny swap
  198. 4x4 issue please help!!!
  199. Oil question
  200. Normal or about to explode?
  201. What is this and what does it do?
  202. Are all 12v heads the same?
  203. 98 12V fuel additive
  204. 95 12valve advice
  205. banjo bolts off 24 valve the same as 12 valve?
  206. are they banjo bolts?
  207. need specs on 1261 CPL
  208. could the cylinder head survive this?
  209. Twins HELP!!!!!
  210. 1996 dodge with factory 24 valve?
  211. afc housing
  212. Leak Down with Head OFF
  213. can you lock the p7100 in position?
  214. where to put timing
  215. Turbo Questions
  216. help!!!
  217. Help
  218. lower egts
  219. front end screetching sound and wobble
  220. Help with injector #'s
  221. 94 automatic trans
  222. nv 4500
  223. woodnpig
  224. NewTPS
  225. timing question
  226. Injection Lines
  227. truck will not start. figured out the problem.
  228. transmission
  229. Drive belt/Serpentine belt tensioner
  230. automatic transmission for sell
  231. trans ??
  232. Gears, etc...
  233. timin on a ppump
  234. Afc mods
  235. 97 12v How to turn up pump?
  236. HELP 97 3500 Cummins 4x4 ext. cab
  237. HELP NO 5TH OR REV.
  238. pump question
  239. ATF all over the bottom of my truck?
  240. How to remove cam (part way)
  241. How to fix the KDP (part way)
  242. need smoke
  243. Hardly any fuel to #1 cylinder
  244. Need 2WD drive shaft help!
  245. New Truck
  246. p pump question
  247. another timing ? help
  248. LOL, i'm stranded !!!!
  249. No Oil According to Dipstick
  250. Synthetic oil question
