- best bang for the buck clutch....
- Timing slip
- better than new
- puting a 6 speed in a 12 valve
- Removing The P-Pump
- body parts?
- Dressing Your Truck Up
- Timing issues?
- turbo swap on my 96 cummins
- Overhead Console
- another 4x4 problem
- What turbo
- EGT question?
- 96 auto p pump?
- ring and pinion
- fuel gauge
- Front driveshaft...
- trouble with 97
- 5.9 timing pin flange torque spec
- What size is our stock exhaust?
- Transmission check ball Location
- Why does my truck not always start? It just makes ticking noises..
- transfer case grinding
- turbo slip
- Smokin Hot Tranny HELP!!!!!!!
- tranny adjustment
- Anyone ever use those plastic dash-plates?
- grinding/scraping noise....
- harmonic balancer
- Why is there hissing and black smoke from under the front end??
- Need to replace front cover gasket; do timing and kdp at same time?
- Timing
- Finally came across a deal
- H1C and HX35
- help
- 12v shutting down
- Transmission work for 300-400hp
- smoke screw
- help with fuel shutoff soleniod
- Clutch Master/Slave Questions..
- 14 MPG Please Help!!
- Allison tranny
- wierd boost question
- Harmonic Balancer
- Complete Rebuild
- Turbo specks need HELP
- turbo problem?
- front shocks
- ANY SEAL OR GASKET WHEN CHANGE TC?
- transmission - NV-4500
- 12V Head?
- getting boost
- Lacking power at shift
- Kill Switch
- turbo change
- tail lights
- Throttle sticking or what?
- tps help
- Twin turbo
- Star Wheel
- Hx35/55 twin question
- ring & pinion
- Putting a P7100 from a auto on a Manual
- turbo ???
- oil filter
- 3rd gear
- Speedo question.
- radiator
- turbo oil feed thread
- what color paint!!
- Need Help with AFC
- will more power hurt
- Fuel starting problem
- compression loss & bad rings?
- lookin to make some power
- I have a turbo question
- Big A$$ electrical problem
- shutoff
- where can i find a shifter shaft?
- 1994 cummins tranny acting funny
- Popping/Clunking Sound
- Diagnos my problems.
- New truck 13mpg???
- tranny help needed
- 95 dodge maintance
- complete front trailing arm replacement
- need engine built
- Oil Pan Replacement
- turbo is froze up
- Tranny slip
- diesel fuel in oil pan???
- timing covers
- HELP- tranny trouble
- front fender replacement
- loss of power and white smoke
- injector leak?...maybe?
- Door hinges
- a 95 12V for $3000? Opinions?
- Transmission question
- Cracked Timing Gear Cover
- tranny question
- spare tire size
- Losing Water
- seem to be leaking some fuel
- CFM fan
- how do i get the shifter handle out of the top of my tranny?
- Cheap Head Gasket Fix
- Service Manual Ram 1996 diesel
- Automatic Transmission
- Oil Motor
- slipping around
- second gen cummins
- Fixed yoke for an NV 4500 2-wheel drive?
- part identity help?
- 97 12v throttle
- help help help
- new 97 12v question
- turbo oil line?
- Help
- Dyno help
- just did the timing
- new guy needs help!
- curious
- 95 cummins with a miss
- voltage and electrical question
- whats the bar on a injector?
- loosen power after 2200rpms
- tps sensor
- need help for a 95 dodge ram 2500!
- best 12v
- 94 cummins
- Newbie ??
- fuel plate problem
- timing
- cup holders
- need tranny
- valve seating prob
- instrument cluster problems
- clutch problem
- Need Tranny help 12v
- 97' Dodge Stock Fuel Plate can it be slid forward for more power?
- trans shifting
- thermostat
- hey
- gosh darnit
- oil pressure gauge bouncing
- Oil in Antifreeze
- ppump swap
- I am stumped!
- fuel lines and fuel pump
- 96 help with trans
- 370's???
- cruise control
- Chrome valve covers
- hey
- starting problems?
- driveline issue two
- Trans seems to shift between 2 3 at light throttle
- help
- manual tranny question
- loss of power
- vaccum pump
- white smoke at idle
- afc housing
- shifting into od
- how to add alot more horsepower and torque
- 6 speed
- egt problems?
- California cummins
- Tappet Cover
- Guys need a little help!
- Altenator Voltage or Transmission??
- turbo and intercooler Q
- tranny help!!!!
- P7100 pump
- changing dv
- nv4500 release fork question
- what she worth?
- how to cut my own fuel plate?
- egt?
- help idel problem
- looking at buying a cummins got some questions
- afc ?
- lift pump instal help
- What's it worth?
- weird noise
- so many problems. need advice.
- painting stacks?
- 1998 dodge ram no gauges no charge no wts light
- stacks
- differences ?
- what to look for ?
- injection pump issue
- pulling to the right
- big oil leak
- help
- isspro gauges
- Starter spinning, but not engaging...any advice?
- transmission noise
- Looking for some Transmission expert advice..
- sensor
- 12v misfire
- Transmission Slipping
- helppp please
- 4x4 problems
- cooling/heating system
- lowering 4x4 96 ram
- 2000 Dodge 5.9 cummins
- a few quik ?s
- stereo v.s. motor
- selling 94
- timeing and starter question
- tranny
- fuel problems
- gallery gasket
- seat question
- timing
- 2wd 2500 leveling kit 1994
- rattling and low power till i back of throttle?
- Axle
- looking to buy a turbo from a db sponsor
- 12 valve conversion
- tranny problems
- Removing engine from 97 4x4 dodge
- Well it finally happened to me.
- my picture
- pre fummins de-tune
- Transmission dying? Need HP converter?
- Its been fun guys
- fuel plate
- Power steering issue
- Removing Transmission
- fuel pressure
- Looking at 12v for son
- Drive Line Issue
- torque converter and valve body
- Rear main seal
- turbos?
- Gsk install
- steering box
- Time to de-tune
- Well might as well build the motor now :(
- Dash Lights
- cummins injection pump question
- different injection pump
- 4x4
- Only got defrost
- fuel lines
- injectors
- replacing lift pump
