PDA
View Full Version : 12 Valve 2nd Gen Dodge Cummins 94-98
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 [23] 24 25 26 27 28 29
  1. kdp help
  2. Is there a chip/programmer for a 98' 12v???
  3. service truck with 2nd gen
  4. air in fuel, starts to die or does die
  5. exhaust housing?
  6. what turbo?
  7. KDP tabbed
  8. help
  9. dodge tow mirrors
  10. Need more power
  11. pump question
  12. mirrors
  13. tranny shafts?
  14. tranny
  15. throttle position sensor
  16. 96 12 v
  17. issues with the charging system
  18. pump question.
  19. cummins help please
  20. the dodge took a dump
  21. Speedo correction
  22. Enterprise-Ohio
  23. Thickness to build a girdle
  24. Rack Plug?
  25. front end alignment?
  26. how big fuel plate a stock turbo handle?
  27. Fuel Problem
  28. bad MPG
  29. egts
  30. what if compression test shows lost?
  31. diesel "knock"
  32. I need a track bar!
  33. 94 12 valve dead batteries or short...
  34. dually adapters?
  35. need help
  36. 3rd gen track bar bracket
  37. 4 wheel drive problems
  38. lift pump?
  39. runnin right
  40. tamper proof bolt in p7100?
  41. miss what to do?
  42. what gauges for a 12 valve?
  43. P-Pump problems
  44. wanting to up boost
  45. Re-Torquing STOCK Head Bolts Questions
  46. Tach Sender Location??
  47. need prices
  48. AFC ADJUSTMENT
  49. whats up with the ticking lift pump!?!
  50. hp guesses for my truck?
  51. need more power at higher speed???
  52. fuel pressure gauge
  53. why???
  54. Building bottom end, adding 24v head, questions/ thoughts
  55. Power steering leak!
  56. grid heater
  57. door seal?????
  58. nv4500 inspection
  59. Clutch Replacement
  60. Fuel/Water Seperator blow up?
  61. Bio Diesel with Mods?
  62. Air filter choices
  63. dv's leakin
  64. park lamp fuse keeps poping
  65. 12 valve fuel gauge dinger
  66. 12 valve fuel gauge dinger
  67. bought my nv4500 conversion
  68. bottom end
  69. stuck synchros???
  70. Tires
  71. motors
  72. all bad
  73. Fuel Shutoff Solenoid
  74. nv4500 HELP
  75. headlight problems
  76. hard start.
  77. dash board cover
  78. 3rd gear
  79. timing
  80. sometimes she starts, sometimes she just cranks
  81. Turbo Boost & RPM
  82. boost
  83. no air
  84. need some help
  85. In need of some help
  86. 5th gear
  87. fuel capacity
  88. New FASS system- No pressure ??
  89. help!!! 4 wheel drive
  90. 3GSK/idle
  91. need some help on a 12 valve
  92. confused NOOB
  93. injector nozzels?
  94. What IS a safe EGT
  95. oil pressure drop
  96. valve cover gaskets
  97. nv4500 jumps out of 5th gear
  98. converter
  99. Clutch Master Cylinder Help
  100. brake issues!!
  101. Slipped Timing?
  102. trans
  103. oil bracket
  104. pullin up steep grades
  105. Looking at 12v trucks, anything to avoid, look for, best year?
  106. WOT then dies and hard to start
  107. pump side plug
  108. Parking Brake Dash Light?
  109. transfer case problems
  110. HELP!!!!! 3GSK
  111. Aftermarket Headlights
  112. Starting issues
  113. tranny slipping?
  114. HELP!!!!! 12v Fueling problem
  115. 10 PSI of fuel pressure
  116. Stupid battery.
  117. fuel sending unit
  118. 12 valve trannys
  119. 1997 Dodge 2500 4wd Issue
  120. issue after issue
  121. problem with front axle
  122. Ugg cab leaks SUCK!!
  123. NV 4500 Transmission Filter Kit
  124. Leaking steering box?
  125. Tachometer Install Using Factory Sensors
  126. Fuel Shutoff Relay
  127. random shut off
  128. desperate please help!!
  129. wastegate
  130. Tranny Issues
  131. fuel line question.
  132. fuel line size?
  133. please help!!!!!
  134. PROBLEM!!!!
  135. injectors and turbo
  136. help!!
  137. DT Profab track bar broke?
  138. dampner and front main
  139. Ball Joints - Moog vs. XRF?
  140. Help!!! wont start !! is the pump fried??
  141. tire issues
  142. more problems!!!
  143. 94 AUTO towing problems
  144. Burnt out fixing the NV4500
  145. Fuel Filter problems
  146. headlights
  147. Speedo Adjustment
  148. gauge readings
  149. columbus diesel
  150. Some Good Reading On The P-Pump
  151. signs of starter going bad
  152. Seeking higher MPG
  153. Fuel Pressure Question?
  154. Iam lost
  155. Preheater
  156. Doing Killer Dowel Pin and Injector timing together?
  157. Sport Headlamps?
  158. TC coming apart?
  159. drop visor
  160. ball joints?
  161. overdrive solenoid
  162. Low Fuel Pressure Warning Light Needed?
  163. need some dodge help
  164. Fuel pump timing?
  165. how much my truck worth
  166. redneck way to set timeing?
  167. 94 missing
  168. 47re ?
  169. Timing Your P-Pump
  170. stacks
  171. Drag strip
  172. oil leak
  173. light switch
  174. turbo boost
  175. banjo bolt
  176. Boost gauge problems
  177. Auto trans shifting problem
  178. fan
  179. oil leak
  180. Dash Pod
  181. grid heater gasket
  182. fuel plate and exhaust temp
  183. Valve cover gaskets
  184. TPS
  185. what kind of injectors?
  186. delivery valve holder
  187. fuel filter right?
  188. Compression Test on 95 Dodge
  189. truck wont idle!!
  190. EGT'S
  191. 1996 ram diesel fuel lines
  192. ht3b exhaust housing
  193. nv4500 swap!
  194. still no start,I WILL PAY for your time!
  195. help
  196. Oil Covered Injectors
  197. lift pump ,question
  198. nv5600
  199. how bad
  200. oil pressure
  201. fusable link
  202. injection pump gone....
  203. nv4500
  204. I need help!!!
  205. lock problems stilllll!
  206. egt issue
  207. 4x4 acuator
  208. how much is my 96 cummins worth
  209. starter problems
  210. truck died
  211. Towing mirror
  212. swaping injectors and fuel plate hp diff?
  213. breakaway screw
  214. Injectors and tranny?
  215. Fleabay Timing Tools?
  216. Brake line
  217. another afc ?
  218. aftermarket fuel filter help
  219. injector and fuel plate questions
  220. fuel plate
  221. Front Driveshaft Question
  222. 370 hp marine injectors
  223. Truck starts..almost stalls..then runs ok
  224. tranny pressure
  225. injection pump problem help me
  226. valve body problems i need help!!!!
  227. turbo help
  228. Block Heater
  229. oil under truck
  230. what year the 215 injectors start?
  231. Tuning!
  232. axle joints
  233. CCV Into The Exhaust?
  234. tranny fluid
  235. Squeal
  236. climate control...comes out defrost when set to cab
  237. timing 911 need help asap
  238. Transfer case busted
  239. turbo = junk
  240. 12v Stalled and won't start
  241. tc qestions
  242. Engine Pulsing & Breaks Up When Its Cold.
  243. replaced fuel line...still starts, runs, dies
  244. idle adjustment on a 12 valver
  245. Thermostat
  246. squattin hard
  247. 2wd to 4wd
  248. GEN light on
  249. pump timing
  250. Changing diff oil - torque spec?
