PDA
View Full Version : 12 Valve 2nd Gen Dodge Cummins 94-98
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 [26] 27 28 29
  1. typical dodge rust!
  2. 12v timing sweet spot
  3. Cooler
  4. towin hooks
  5. trans temp gauge
  6. ordered my 4k gov. kit
  7. Axle Wrap issue's
  8. INTERCOOLER PIPES
  9. 12v Injection Pump Timing
  10. Engine Oil
  11. Transmission shifting too much?
  12. Wastegate Fully Closed
  13. Temp
  14. 98 california 12 valve help
  15. ball joints and tie rods
  16. TCC Mystery Switch
  17. looking for place to get aftermarket camshaft?
  18. 12V cold start stall?
  19. how much HP
  20. how to adjust idel
  21. fuel lines.
  22. all 4 gauges?
  23. Clutch install and removal HOW to?
  24. my first 12 valve
  25. stalls in reverse
  26. Help my truck is about to self destruct
  27. 215 pump injectors
  28. what size fuel tank?
  29. no start when hot maybe ???
  30. Mag Hytech Tranni Pan
  31. Short Shift Kit Question
  32. crap! what should i do
  33. Cab Light Install?
  34. tranny
  35. kick down cable
  36. hmm
  37. rpms and fuel plates
  38. guttin the muffler
  39. change the gears?
  40. usin two stroke oil
  41. throttle stick
  42. trany problem
  43. ac is killing me
  44. turbo ring
  45. fuel plate
  46. Filter Sucked In?
  47. trans temp probe location
  48. hard starting after plate install
  49. sled pull/lock up?
  50. TQ lock up question
  51. slippde timing?
  52. boost elbow???
  53. cruise control issue
  54. break off screw???
  55. how to get better mpg?
  56. high idle
  57. 47re to NV5600 conversion
  58. air truck horns
  59. need more power
  60. de-lip, open piston bowl?
  61. Reverse light hookup 47RH
  62. BEST CHOICE EXHAUST
  63. Governor
  64. 45 psi
  65. takin out seats
  66. Single Stack Tips and install pics
  67. air ?s
  68. Idle
  69. Ball Joints?
  70. isspro gauge short
  71. Oil Pressure Sender 98 12 valve
  72. beefin up the tranni
  73. Fuel plate question
  74. Tranny Question..
  75. 24 valve on 12 valve
  76. dyno results
  77. Electrical Problems on 98 12V
  78. Wastegate help ....
  79. My fuel problem
  80. the low down on my stock fuel plate
  81. lift pump
  82. EGT gauge
  83. white smoke/no power
  84. Options
  85. Cruise control
  86. 3000 gov kit.
  87. misfortune
  88. throttle valve cable
  89. Removing Starter??
  90. in or out
  91. HTB2 or B1 bomber?
  92. Downpipe Question
  93. 2002 VB in a 1998 12v causes TRANS TEMP light...
  94. spewing fuel
  95. need help
  96. timein at 16?
  97. what year has the best 12v for engine swap
  98. no power at start
  99. tranny temp???
  100. ATF as fuel additive ??
  101. 1997 12 valve engine wiring harness needed
  102. Installing Gauges
  103. wondering what i should do
  104. i've got the bug
  105. Nitrous
  106. Afc arm
  107. SMOKE
  108. odometer question
  109. egt tune
  110. Fuel Plate and Towing
  111. tire toe in
  112. High EGTs at idle
  113. auto trans shifting
  114. ENGINE DIES
  115. Need ADVICE on transmission .
  116. No power to transmission
  117. Weirdness
  118. this cant be right! help!
  119. 12v low to mid rpm stumble
  120. 12v cummins whats wrong?
  121. marine injecter
  122. Mpg?
  123. brakes
  124. help
  125. need some advice
  126. pistons
  127. O/D Wiring Diagrams For 47rh
  128. Four wheel drive actuator
  129. Head Bolts
  130. Question about turbo
  131. valve guide seal? update on this? Keep them down?
  132. Guages quit workin
  133. tranny problems
  134. Fuel Plate Question
  135. Lock Up??
  136. ahhh crap
  137. stock speaker size?
  138. Ohio Craig's List Ad
  139. Steering shaft
  140. Pre filter O-ring
  141. 97 fuel filter leak?
  142. how much would it be?
  143. 2 different axle splines?
  144. Fuel Plates
  145. BD boost elbow..
  146. where is my boost going?
  147. stock tranni
  148. Bread Truck 12v
  149. Redline MT-90
  150. hard to put in gear....squeeking
  151. rocker arm
  152. valve cover plate
  153. timing
  154. Anyone know how to remove the trans cooler line check balls?
  155. New goodies
  156. Torque converter cooler
  157. 191 delivery valves?
  158. ford cummins swap
  159. what web site to get a stack
  160. anybody try this? prolly dumb thing to do
  161. tranny cooler... fuel tank
  162. compressor wheel?
  163. more take off power?
  164. does anyone know how to block off an EGR!!!
  165. highest idle
  166. some questions for you
  167. front axle u joints?!
  168. new to me can you tell ?
  169. dyno
  170. breakin
  171. AFC screw setting..
  172. Sway bar issues..
  173. 16X8 factory aluminums
  174. new truck
  175. exhaust
  176. front coil springs
  177. kdp fix
  178. all gauges the same?
  179. who makes a nice steering box
  180. 2003 dodge wheels on 97 dodge
  181. Sending Unit
  182. stock injectors?
  183. Electrical Problem
  184. pump question
  185. lost power when towing
  186. 44lbs of boost
  187. Favorite mods
  188. SuperB and Stock Exhaust
  189. injector QUESTION
  190. Ball Joints??
  191. a good diesel shop
  192. EGR??
  193. pullin toy hauler
  194. changin to a 1 ton
  195. Replacing the seal between the vacuum and steering pump
  196. home made stack
  197. runnin two stroke oil?
  198. ats commander lock up contrller
  199. MBRP Exhaust
  200. timeing should be?
  201. exhuast
  202. Killer Dowel Pin?
  203. any advice would help PLEASE!!!
  204. New Turbo
  205. a couple of questions
  206. i need help with installing injectors
  207. extra fuel tank
  208. injector sizes?
  209. a shift kit
  210. carrier bearing in long dodge drive shaft
  211. For More Information About Your Truck
  212. small mods
  213. stupid front end
  214. do i need a KDP kit?
  215. truck frame
  216. new injectors NEED MORE AIR...conical filter??etc
  217. need a new one
  218. I have fuel problems
  219. more fuel hard on pump?
  220. preventing a problem before it happens
  221. trip odometer
  222. South Bend Clutch
  223. NEW INJECTORS install,NO START
  224. any one have a.....
  225. trailer brakes?
  226. Clutch Replacement Options
  227. 12 valve rebuild ???
  228. installing injectors TOOLS NEEDED?
  229. star wheel
  230. valve size
  231. auto price vs. manual
  232. boost hits a wall.
  233. new guy
  234. miss and smoke
  235. blue smoke over 2000 rpm?
  236. headgasket failure
  237. Transmission
  238. another piping question
  239. intercooler piping size
  240. Propane Injection
  241. steering
  242. makin it pretty under the hood
  243. 5 speed input shaft
  244. boost question
  245. hard shifting after fuel plate
  246. wont start after plate
  247. Headliner
  248. Oil in the coolant? Oil Cooler/Head gasket?
  249. which way to slide fuel plate
  250. where to get some cheap gauges?
