- possible trade for my 6.0
- 96 auto trans lack of power 49-60 mph
- I need a 94-98 timing cover case for p-pump 12v
- Fuel filter assembly change
- Engine swap!
- replacement evs 2 alarm key fob?
- Airdog systems?
- what track bar do i need
- Required hardware for EGT/boost/fuel pressure gauges. Help needed!
- need performance help
- Shuttle shifting 47re
- Oil coming out of dipstick?
- Anything wrong with this plan?
- What to do??
- weird water/oil mix what yall think
- Best shocks for my money??
- identifying axles
- 95 5 speed jumping out of gear!
- Blowby
- Return Line
- how much horse?
- Paint and Body
- Does the motor match the truck vin? How to know?
- 47rh problems
- outside temp, compass isn't working. HELP
- P7100 P-pump
- When you hit brakes steering wheel jerks to right
- 94 Cummins, 6 speed 2500 with 3.07 gears??
- Turbo Not working will I do damage towing/ driving
- 1996 cummins questions
- fuel gauge sender
- stock air box vs aftermarket intake
- No overdrive/lockup and some other things
- 12v cummins wont crank
- trans temp,wait to start,water in fuel not coming on
- Making power?!
- Pass the knowledge please
- ABS Light and Brake Light
- 12 valve help
- Check engine light on
- shaking while accelerating
- Need help/advise on price for selling truck!
- Grey smoke
- Using window tint to smoke tail lights?
- Injector Spray Pattern...
- Stacks on a 98
- Do 4x4 injection pumps fit 2x4 trucks?
- 96-98 Difference??
- terrible pulley squeeel. HELP!
- TC lock up help
- Post Some Pictures Of Your 12 Valves
- Trying to get my Cummins to smoke???
- Building a 94 Cummins....ideas
- Turbo....(?)
- trying to break 500 rwhp, what to change.
- Looking at buying a 96 cummins
- tork tek adjustible ofv
- 97 Cummins Turbo Diesel
- 98 cummings with the California emmisions. need help removing the EGR
- What could it be?
- 1994 Fuel Sending Module
- What size fuel tank?
- afc spring kit
- Need some help white smoking
- Hays clutch slipping
- Odometer not working
- Mounting a sleeper and flatbed for a cross country road trip
- Killer dowel pin
- charging problem
- lots of oil in radiator, help!!!!
- Steering box replacement ??'s
- Rattle through the exhaust? Help!
- 78 ford cab on a 94 ram 2500 frame
- Got my Raptor 150...
- advice on truck thats for sale
- Help 4x4 guys
- 97 Cummins fuel system troubles.
- tv cable mount
- Winter diesel oil
- governer springs and shift kits
- oil leaking out of my front axle???
- head bolts or studs
- 12v cracked cylinder head / performance advise
- KDP help
- how to test fuel sending unit and fuel gauge
- Where to get a Superstat?
- 400 hp turbo
- just got my first 12 valve & need some tips
- Dual feeding a P-Pump...
- Nv4500 question
- Looking at a 1994 Dodge Ram 2500 Cummins 5sp manual with 330k miles
- afc housing wastegate line question
- 78 ford cab on a 1994 ram 2500
- Aftermarket Hood
- biggest tires on a 2wd?
- Holset wh1e
- he351ve on 12 valve?
- 2.6 Turbo
- any ideas?
- Nerf Bars
- Main difference between the 95-96 12v?
- Sweet tooth grill
- injector pump spazing out after a couple miles
- Building a cummins and have lots of questions
- wastegate question 12V
- Raptor vs AirDog
- New Clutch
- best dash cap go get?
- 12 valve cummins 87k engine with pump
- 96 auto dually for 98 5speed???
- Am I daydreaming for looking for 20-25 mpg?
- need help. running rough cold
- Ford inter cooler
- STALLS IN REVERSE
- good turbo upgrade?
- cummins wont shift into overdrive
- 1pc Driveshaft in 94 reg cab 3500?
- Gen 1 vs. Gen 2
- 94 auto trans. PLEASE HELP. From TX
- bd aux trans cooler
- brake problems
- How to get a 12v running...
- HX55 turbo... ?!?!?
- Injectors.... having a hard time picking...
- Adapter Plate.
- 12 v running issues
- what yall think its worth?
- Trans issues... I think?
- how to tune afc to get less lag?
- keep the 24v or get the 12v
- 47re question
- Cummins Part out
- towing turbo upgrade
- tranny time
- htt s364 upgrade kit
- no start issue HELP
- bad lift pump?
- I'm back boys & girls...
- 97 cummins into 90 f250
- Water meth injection
- New Shoes! XD
- '94 with converter problem
- modifying or changing intercooler
- transfer case poping out of 2hi high pitched grinding in 2hi and 4hi
- Lack of power
- spooling a Screaming Eagle 63/68/14 on a 12 valve auto
- Rear main replacement.
- 96 A/C and spedometer problem
- 67 Jeep M715 build
- P-Pump Question on a CA Version
- 95 cummins 12 valve
- a couple questions
- HELP after Transgo shift kit install
- Help Please..
- Fixed my KDP , will my timing be off , can I time with cover on ?
- vibration help
- Miss at idle
- P7100 pump supply pressure
- How to make a 97 dodge automatic smoke alot
- Odd issue
- whats next?
- will a 1st gen turbo fit a 2nd gen
- 12v cummins turbo issues
- Axle seal question
- Were is the power steering fill cap
- Lots of smoke, low boost, high EGT's
- low idle in drive/reverse
- 94 12 valve oil leak around the back of the block?
- Constant White Smoke?!
- 97 3500 2wd?'s
- Turbo lag
- BLACK FUEL FILTER?
- opinions and help for my 94 12v
- 95 dodge Cummins tranny help
- Blue smoke
- need turbo selection advice
- 04 hemi or 96 cummins
- Right Pump?
- 1995 Ram 2500 Steering problem, please help!
- What am I missing and where can I find one?
- FP: normal lift pump behavior
- WANT TO MAKE KILLER DOWL PIN A RECALL
- 95 Dodge Diesel To buy or not to buy?
- Lost tach, speedo and won't charge..HELP!
- What trans is this?
- Hard start, miss, air in the lines. Where to check?
- 1996 12v Fummins knock
- gas pedal problems
- noisy 5.9 after new injectors
- Bad pump?
- Best 12v additive
- offer on a eaton 5spd out of fleet truck
- Tv cable adjustment
- OFV cause popping sound
- No downshift to 1st at stop
- Dash Bezel Removal
- transmission issue help please
- how to turn idle up on p7100
- new suspension
- Making more boost
- 95 12 valve radiator hose
- Dead pedal when first starting. any ideas.
- Power steering cap leaking....help!!!
- 1995 dodge cranks but wont start
- 97 2500 No overdrive or lock up
- 53 Chevy with a 12 valve, Wiring questions
- Exhaust
- '90 f250 cummins swap
- turbo questions
- metal rubing sound
- 47re/47rh differance
- Building a 2001 12 Valve
- Soft clutch pressure
- Lift pump or plugged filter?
- Lower metal coolant line
- 95 ram 2500 turbo diesel loss power
- which valve body and torque converter?
- stock input shaft????
- 47re rebuild tips
- 2nd Gen project
- dodge headliner replace
- Decoding a pump
- qcsb 5 speed cash or trade!!!
- kdp question
- Looking at buying first diesel
- Help
- Overheating or Common?
- NEED QUICK REPLY! P-Pump
- Where to start?
- he351 on a 97?
- ABS and Brake light help!
- 1995 Dodge Cummins, wont stay running. Please help
- HELP!! No fuel plate and no smoke.
- 12 Experience Enter!
- 47RH problems, any ideas.
- Anyone selling?
- white smoke/missing/help
- Red October
- What would u pay?
- maybe a 97?
- looking for how to timing, or related threads
- What is this..? PICS
- DRW long to SRW short bed
- transmission not going into gear
- Cummins Grille Emblem
- dash removal
- Fire
- Leveling Kit
- KDP Info.
