PDA
View Full Version : 12 Valve 2nd Gen Dodge Cummins 94-98
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29
  1. smoke screw on back of pump
  2. starwheel
  3. 12v blue haze
  4. Voltage problem
  5. 47RH???
  6. 94 12V been sitting for years.
  7. 95 dash
  8. Little question
  9. twins
  10. tps mounts
  11. U bolts?
  12. NV4500 Swap Question??
  13. LOCK OUT HUBS
  14. rpm gauge
  15. Injectors leaking/little bubbles around where injector seats
  16. trying to find a pump shop that will bench my pump to make hp...
  17. where to buy affordable coolant temp sensor for 12v
  18. 96 12v torque converter
  19. Popped HG, upgrade time!
  20. tranny problems?
  21. Rear main seal
  22. Want smoother engine
  23. Anyone heard of an allison swap?
  24. Dual Fuel Feed into my 215 pump
  25. boost seems low???
  26. 96 12v auto to standard swap, how to make speedo work?
  27. new motor
  28. leveling kit
  29. cams
  30. tranny questions
  31. 12 valve power
  32. Missfire...
  33. 4wd to 2wd nv4500
  34. 4wd to 2wd nv4500
  35. tools only tricks?
  36. confused tranny slipping or torque converter failure???
  37. 47re going straight to third. three codes
  38. 241D Transfer case fill and drain plug size?
  39. Anybody wanting to convert to an auto?
  40. Overhaul manual
  41. Flywheel Bolts
  42. need to turn up idle help please
  43. trouble with valve lash
  44. Is this a good price for the truck?
  45. Rear end help!
  46. Weird noises.
  47. 96 ram brake controller
  48. Transfer case id
  49. 98 Dodge Ram, front end making noise over bumps
  50. Advanced Timing
  51. transmission decisions
  52. 6.7L harmonic balancer on a 5.9L
  53. compound turbo set up or a single for my goals?
  54. Rpm guage not working and alternator not charging
  55. my truck is driving me
  56. Blue smoke
  57. 360 for cummins
  58. 12 Valve Get's Some R&R
  59. Lots of smoke / what size injectors
  60. Too much power?
  61. GEAR RATIO'S
  62. Leveling kit help
  63. 47re
  64. Aftermarket tach and Dakota digital dsl-1
  65. to much boost!!!
  66. The old "Fuel solenoid pull cable"
  67. Throttle sticks
  68. Exhaust Question
  69. 3k gevenor instal
  70. 47re questions
  71. Transmission time..
  72. vaccum pump
  73. Star wheel 98 Cummins
  74. GT3576
  75. just picked up a 96 ram 3500 5.9 12v cummins and have some questions
  76. Is this a steal?
  77. drop shackles
  78. She's showin' her age....
  79. Front Pinion Seal
  80. Charging woes
  81. what pump is this 175 or 215?
  82. Stiff brake pedal in traffic
  83. Tv cable
  84. blowby
  85. Stock 95 12v trans temp sensor replacement
  86. Another Auto Tranny Problem..
  87. shakes at crusing speeds
  88. The Dodge Blues.
  89. 47re help.. going crazy
  90. Painting the interior
  91. AFC
  92. eBay hx40
  93. Dodge 12 Valve Project
  94. Fuel Pressure Gauge Issue
  95. swaps i need input
  96. 12v injector washers!?
  97. fuel shut off relay
  98. 94 cummins shifts fine but no overdrive
  99. NV4500 Trade?
  100. I hope its not a pump!!!
  101. lift kits differences???
  102. More cat 2 micron filter questions.
  103. powered seat in base truck
  104. mud tires? help!
  105. Power power and more power
  106. suggestions
  107. A/C Not blowing Cold..?
  108. 47 re problem. ABOUT TO GO CRAZY
  109. Tire clearance
  110. p7100 swivell block!!! help
  111. Nv 4500 input shaft
  112. bolt sizes
  113. I... have the worst luck.
  114. Did some work on the 96
  115. 12Valve Fuel Plate
  116. Need advice... build cut short
  117. air getting into fuel
  118. Blow By Tube
  119. Hard gas pedal
  120. 93 rearend in my 98
  121. bumper
  122. Your Input on a light performance rebuild
  123. Torque converter wont lock up
  124. Aurora 4000- mpg?egt?
  125. High idle
  126. Tranny shifts hard and randomly
  127. 97' 12 Valve Battery Drain Help!!!!
  128. NO VOLTAGE/POWER
  129. Air intake
  130. 215hp injection pump?
  131. Reverse Lights
  132. Starting
  133. Water temperature ?
  134. block warmer ?
  135. Low oil pressure
  136. Aurora 4000?s
  137. 2nd gen grid heater
  138. 4x4 problems
  139. Redneck exhaust system :)
  140. fuel pump thread type
  141. brand new NV4500
  142. Dodge won't start
  143. Throttle sticking, motor dies
  144. Truck won't pass?
  145. 97' 12 Valve 2500 NO HEAT BUT A/C
  146. injector nozzles enlargment
  147. My temp gauge goes up n down
  148. pitman arm
  149. performance upgrades..??
  150. head bolt removal?
  151. 97 5 speed 4x4
  152. 98 dodge lift question
  153. 98 2500 12V 4x4
  154. how much cfm needed for muffler?
  155. transynd fluid in 47re?
  156. axle ?
  157. Fuel tank pressure
  158. Pryo?
  159. 96 12 valve no start after crash????????
  160. Trans temperatures
  161. Tranny Going Out
  162. Clutch change/upgrade 12.25 to 13"
  163. Boost/Hissing Leak
  164. Can anyone post a pic on where they tapped in for the Noise Isolator??
  165. Truck idling down and wont go over 40
  166. Switchable afc preboost fueling idea
  167. just sayin
  168. Blow by tube
  169. TPS
  170. help.....engine removal..
  171. CAT 3126
  172. CLANKING SOUND!????????
  173. Grid heater solenoid replacement
  174. temp gauge
  175. 92 tranny in a 95
  176. Looking for Throttle shaft/bell crank assembly off a 12valve!!!!
  177. need help with windshild wiper fuse blowing
  178. Need a little help
  179. Four Wheel Drive Issues
  180. A knock (Hear me out)
  181. 94 cummins fueling question.
  182. PUMP TIMING
  183. Air intake manifold
  184. How fast can you drive in 4 Hi?
  185. rough running cummins
  186. Brake problems
  187. What's a top speed u can reach with 4.10 gears?
  188. Dry starts? And...
  189. spindles?
  190. one more for you guys -shift points-
  191. 1996 dodge front clip changed to a 2005
  192. T-stat problem
  193. Decent price?
  194. bad stumple in Park?
  195. need throttle linkage for a 96 auto
  196. stock injectors? can they be modified?
  197. turning barrels... good or bad?
  198. stalling help
  199. hey guys
  200. Project 12 Valve Cummins
  201. Small coolant leak by the water pump
  202. leak on top of pump
  203. crap mileage, think convertor may not be locking
  204. help with pyro gauge
  205. Ground Activated
  206. injector thoughts please
  207. Torque Converter Lock/Unlock / OD Hunting Issue!!
  208. ?what is the best fueling system
  209. New 12v Owner
  210. P7100 Spring/Linkage Attachment
  211. Plugged waste gate
  212. pillar guage dimmer
  213. boost elbow
  214. EGR Vacuum Hoses
  215. Got myself a new toy
  216. Cummins injectors out of a 96
  217. Electrical Issues! =(
  218. tranny
  219. nv4500 input shaft replacement
  220. Flex plate question
  221. Loss of top end with fuel plate movement
  222. EGT question
  223. 2500 running gear and drive train into a 2001 1500 chassis
  224. need quick reply to auto trans question
  225. milky oil. head gasket?
  226. Bad shut off solenoid??
  227. best torque converter for best price????????
  228. speaker size??
  229. 5 spd noisy
  230. 4.10 to 3.55 gears
  231. aux fuel
  232. 5 inch exhaust ????
  233. cruise control
  234. pot or switch?
  235. 96 cummins in need of a tranny
  236. 94 dodge upgrades help
  237. Name this part!
  238. water meth injection????????
  239. 98 5.9L oil in radiator
  240. Cummins in a F600 turbo, freeze plug issues
  241. Head gasket questions??
  242. 96 cummins
  243. Speedometer not working
  244. fuel gauge issues
  245. 1996 cummins no power, stalls under load
  246. first diesel and I need some widsom......
  247. Seized Turbo.... Any help?
  248. New Alternator & BD APPS Noise Isolator installed, now no "Wait to Start" light
  249. Ball Joints
  250. 2 wheel to 4 wheel
