PDA
View Full Version : 12 Valve 2nd Gen Dodge Cummins 94-98
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [21] 22 23 24 25 26 27 28 29
  1. Grid Heater Cycling
  2. body panels
  3. Blue Smoke & Rough Idle at start up
  4. How to change automatic shifter knob
  5. gosh darnit
  6. what do u think by watching this vid?
  7. Wiring Harness
  8. truck not starting
  9. Cheap cummins engine or not
  10. ran her hot for a mile
  11. conversion write-up 47re to nv4500
  12. help
  13. Missing after sitting
  14. what tranny
  15. help
  16. starting issue
  17. Engine Starts and then dies
  18. need some advice
  19. how much timing
  20. ring and pinion swap
  21. tps wire colors
  22. another delivery valve question
  23. help
  24. return spring question
  25. high flow delivery valve barrels?
  26. Lesson learned.
  27. need i help
  28. Auto Trans Upgrades?
  29. letter in vin to decode paint color?
  30. help
  31. plate or no plate
  32. Pedal wont go past half way.
  33. Front end hopping?
  34. what years will convert to p pump conversion
  35. 12 valve stalling
  36. looking for 14cm exhaust housing
  37. dual steering stablizer
  38. what are these?
  39. p pump fuel inlet size
  40. help no radio power mirrors or dome light
  41. shifter ideas
  42. pump numbers
  43. delivery valve help
  44. more trouble
  45. overflow valve question
  46. lights
  47. Deffrence between Mechanical and Electrical Guages??
  48. ELECTRICAL PROBLEM No gauges or wts
  49. ford school bus p-pump
  50. 12v High Idle
  51. grinding noise
  52. Broken Idle Spring?
  53. rear crank seal
  54. milling rocker arms
  55. Shocks
  56. Need help
  57. wastegate adjustment
  58. lost 5 pounds of boost
  59. diesel bombers stickers?
  60. Where to find cheapest 4" dp?
  61. turn off truck.
  62. What turbo is this
  63. AFC
  64. Fan clutch is shot; cause for poor mileage?
  65. Whats Too Much /Starwheel
  66. trans problem
  67. self priming bulb leaking
  68. nv4500
  69. nv4500
  70. injector seals
  71. 95' mods / 96' Stalling
  72. Transfer Case
  73. Repalcing frost plugs
  74. Input please
  75. Turbo oil return block elbow
  76. Additives for blowby?
  77. Lets assume my motor was ran out of oil very briefly...
  78. 97 remote keyless entry question
  79. factory fog light kit
  80. valve job
  81. Idler Pulley
  82. what are the best mods for pulling
  83. Fittin to replace both hubs any tricks or tips?
  84. Air filters need your opinion
  85. blowby problems
  86. Cheapest way to lift my rear-end higher up?
  87. need some help
  88. turbo leaks oil
  89. tow mirror help
  90. Any transmission gurus in here?
  91. new gears for bigger tires?
  92. mirror vibration
  93. Fuel pressure readings video.???
  94. hey
  95. egts in relation to tranny
  96. P7100 timing
  97. Death Wobble
  98. No plate but should i put it back in?
  99. My brakes are starting to scare me. Any help?
  100. new truck
  101. sensor
  102. 6 speed swap? 4:10, or 3:55?
  103. 95 Curb Weight
  104. help.
  105. turbo??????
  106. swapping delivery valves
  107. fornt axle longer
  108. diesel hp rating for pounds per minute
  109. can't wash the dodge off of it.
  110. running ruff
  111. .020 marine headgasket.... thin washers?
  112. Bad Noises
  113. sorry a nv4500 question
  114. newbie: 1996 12v with 500,000 on the clock
  115. desperatly trying to find a housing
  116. ??? piston swap ???
  117. help
  118. hooking the spedo back up
  119. how big is too big
  120. will it hurt anything
  121. Throttle linkage
  122. 5 speed?
  123. Killer Dowel Pin?
  124. anyone know any good 12 valve techs
  125. Oil Leak
  126. @#$% pyro u dirty @#$%
  127. temp gauge sensor location
  128. fuel pressure question? fuel filter or over flow valve?
  129. Gear ratio
  130. I Am Completely Stumped Coolant Loss
  131. Dodge Ram Spedometer Sensor Location
  132. HP increase with fuel plate adjustment
  133. 12 valve swap
  134. overflow valve
  135. AIR IN FUEL STILL
  136. nv4500 swap tranny temp light on?
  137. headlight and dash light problem
  138. Valair Ceramic single clutch like?
  139. high idle problem
  140. 96 5 spd
  141. Overdrive Problems
  142. Fuel Problem
  143. Problems with....just about everything
  144. removing antenna
  145. New 12 valve light on power
  146. lights
  147. Cat on a 96?
  148. injector removal
  149. application years for gear housing
  150. My oil overflow tube puffs smoke
  151. Whats Too Much Boost
  152. I'm now even more excited.
  153. hey
  154. Casting number?
  155. 2001 Powerstrok 7.3l vs 1998 12v
  156. cam problems/ tranny problems
  157. starter contacts
  158. Transmition sprag
  159. figure this one out!!!!!!!!!!!!
  160. is there any diff from a motor with a standerd to an auto trans?
  161. Turbo Oil Draining
  162. should i do wheel bearings?
  163. 4sp. auto tranny problem only have 2nd & 3rd. Gears
  164. leatherpounder
  165. 47rh transs parts
  166. Ive got a problem and need help!!
  167. boost loss
  168. shocks
  169. Leak ?
  170. whats wrong with this truck.
  171. Tranny Parts
  172. Why does a 215 pump retard timing?
  173. 98 12 valve
  174. Draw Straw Info Please
  175. Anybody here shift clutchlessly?
  176. Dodge Ram Front Fender Replacement
  177. temp guage problem
  178. Drives like shizen.
  179. help 47re cummins conversion
  180. I need a new 12V head
  181. ignition wire
  182. wiring issue
  183. fuel shut down solenoid
  184. Parts seller???
  185. Blinker
  186. o/d shifting
  187. clutch question
  188. kdp fixed
  189. what input shaft
  190. Whats the name of that spring on the top left corner of the p-pump?
  191. RH valvebody in RE?
  192. tranny question
  193. fuel filter bracket
  194. Flywheel Bolts?
  195. Dodge 3500 4x4 dully needs parts
  196. no fuel!!!!
  197. ev2 or performax?
  198. Stumbling/Running rough
  199. trailer wiring
  200. No TC lockup...
  201. valve cover gaskets
  202. Manual Trans Issues
  203. bed rail caps
  204. trans oil NV4500
  205. tach and spedometer
  206. What kind of issues could a leaking front cover cause?
  207. TERRIBLE mileage on my 5spd cummins!! 11mpg city!
  208. why does my truck start soooo good? seriously..
  209. factory cummins/allison
  210. tires not lasting????
  211. This is not right
  212. Pulloff: Dually in 2wd vs 4x4 4.6 chevy
  213. DIFFERENCES BETWEEN 96 & 97
  214. White Face Gauges
  215. Lost in the sea of short forms and references
  216. The dreaded 5th gear
  217. abs and e brake light
  218. exaust tubing
  219. Where do these go??
  220. follow-up mods
  221. Tires
  222. shutoff
  223. what to do
  224. setting valves on 12 valve
  225. tranny temp
  226. I think I'm screwed, big time.
  227. 77 ford/cummins
  228. nv4500
  229. p pump issues
  230. New 12v owner
  231. dash removal
  232. atf?
  233. what should the trans temp running
  234. GRID HEATER DELETE
  235. More Acceleration
  236. tc
  237. rear brakes
  238. Killer Dowel repair
  239. Axle left me on the side of road
  240. what tranny fuild
  241. 12 Valve into an 03....
  242. gear ratios
  243. reg cab to ext cab conversion?
  244. where"s my leak???
  245. NV4500
  246. what can i do
  247. battery cable question
  248. Timing
  249. weird door
  250. just like a new truck
