- fuel cutoff relay:how to check
- Injection Pump
- future bombs
- Gov.Spring Kit.
- who has cut their intake plenum off and done a port/polish job themself?
- Single wheel to a dually
- topper or bed cover for more MPG's?
- Turbo Silence Ring?
- 2003 V10 47re in a 1998 12-valve?
- exhaust gas temp
- intercooler boots
- Electrical issue
- The star wheel
- help asap!
- switchin tranny from auto
- tranni valve body
- pop testing injectors
- Diesel drag racing on Pinks all out.
- anybody have one?
- vacuum gauge???
- helppp
- Dumb question maybe?
- What turbo to use?
- White Smoke
- Do Injectors go Bad?
- only 80
- fuel plate ?
- 12v to 24v block
- any one from arizona?
- Waste Gate Adjustment
- TRUCK PULLING HOW TO'S??
- #10 Plate compared to #5
- Lots of blue white smoke.
- Bout to tackle the head gasket on my 97 12 valve
- HOME MADE INTAKE MANIFOLD
- 94 auto cummins
- installing gauges
- Blown Head Gaskets
- Rear end gears?
- HOOKIN CHAINS
- Weird clicking sound?
- Fuel Sender Repair
- SLED PULLIN GEAR
- what would cause this????
- overdrive problems??
- Annoying transfer case shifter noise
- rack plug
- 6sp
- 94 cummins how much horsepower
- How fast should it go
- Leveling kit from KORE
- plugging wastgate
- HELP
- Transfer case parts
- will tires hold,not load rated
- fleetguard filter number
- 3rd gen mirrors
- help on tranny
- WHEEL SIZE?
- FUEL MILAGE?????
- creeking from the front end
- how much power
- 04 cummins vs 96'
- back flushing coolant
- tool to remove injecectors?
- HELP!!!!!!!!!!!!
- fuel tanks strap
- tranny temp. or fuel pressure?
- short bed frame
- Waste Gate Question
- throttle
- removing fuel plate
- dodge ram keyless entry
- Why?
- turbo spool
- 1995 ram 2500 2wd ctd
- afc housing star wheel won't turn
- Need Suggestions on NV4500
- 1st steps to a fast diesel???
- want to buy a dodge?
- wierd problem starting, NEED ADVICE
- Fuel Gauge Not Working
- Fuller RT610
- Problem starting
- AFC housing break off bolt
- luk clutch?
- Money pit.....BALL JOINTS
- engine serial number - where to find
- turbo brain fart
- HELP! What's wrong with my truck?!
- Transfer case question
- new truck, need power
- boost
- turbo wobble
- Converting an auto to manual
- voltage
- help
- Questions
- 12 valve
- clutches??
- Max Boost on stock 96 12v turbo
- some help.
- tire wear
- 5" exhaust
- differental Q's
- Fuel shutoff diagnosis
- Cylinder wear???
- PACBRAKE VAC CYLINDER REBUILD??
- poor mans big honking af?
- AFC housing
- boost elbow
- Oil leaking around injectors
- 97 3500 srw
- NEW TRUCK
- Boost Press location
- 95 cummins reg cab for 2500
- EGT sensor location
- how to get more rpms cheap
- Fuel Pressure Question
- Antifreeze
- oil leaks
- AFE Filter Part #'s
- Beat by a Duramax
- what makes auto tranny shift?
- Engine Cleanup
- Yikes
- Difference between cummins engines?
- Power and fuel mileage loss 1996 12v
- timing question
- STARTED UP RAN FOR sec now wont start during cranking
- Heater core hell
- rear diff
- Death Wobble
- headliner
- TOO LOUD!!!
- are they serious?!?!?!
- Got a wierd noise.
- Miss through the RPM range
- Turning up 8.3 Cummins?
- 5sp to 6spd?
- killing your rear tires
- Rpms?
- 1997 12 valve broke the sensor above crank shaft
- too much power!!
- injector problem
- Think it's bad?
- T-case Problems.....
- DAMPER on way out,where to get new one?
- bolt up turbos?
- switch from auto to 5 speed
- Great Power loss....
- bed lined rockers
- John Deere Turbo
- White smoke/skipping?
- Super singles on a dually
- smoke
- Hello there
- idling her up!
- its about damn time
- Third Gen. Mirrors.
- Oil Leak
- track bar problem
- 4th gear acceleration vid
- stock EGTs
- Parking BRAKE BROKE cant change crank pulley?
- filter relocate
- help abs
- dodge cummins 1994 12 valve
- Advanced timing caused high idle
- lift pump rebuild?
- STUCK INJECTORS!!!!!
- specs
- 1410 slip yoke
- rookie questions?
- low on power?
- advice for p pump
- just wondering
- No power and lots of white/gray smoke
- 96 dodge 2500 4x4 wheel bearing noise?
- really starting to make me mad now
- future upgrades
- Dyno Results
- Overfull on Transmission Fluid.
- 12v questions
- painting the trim factory color
- 10 plate to a 0 plate?
- High beam issues
- HT3B turbo
- killer dowel pin
- Wheel Hub Bluessss???
- fuel leak
- breakin?
- 90 horse injectors
- Heater cord plug replacement
- steering wheel play
- Rebuilding the 12v ......What would you do?
- power steering
- It's been asked b4 but I got another ?
- Heater Problems
- chewed up serpentine
- high idle
- rebuild
- 4wd Gear
- knock
- Steering
- Timing
- 4wd problems
- need advice on a 95 3500
- twins
- cant adjust gov. arm!!
- Window seals
- Injection pump install
- 48RE in 12v?
- Smoke
- Gov. Spring Question
- cold air intake
- oil filter
- Modifications
- towing question.
- Front U-Joint Help
- P7100 injector pump timing help
- 1995 5.9 engine keep running after ingnition stop
- Glow Shift Gauges
- Rear brake question.
- trans
- Hey guys I need help modifying my 12v pusher motorhome
- 12 valve fuel plate question
- Do P-Pumps Knock When Going Out
- Starting issues in the cold.
- Speedo Gear
- difrence in 12 and 24 valve trannys
- Where to buy an oil dipstick
- p pump power ratings question
- Fuel guage trouble
- lost power and cant hear turbo
- Loud intake or filter
- Truck geling up
- Boost pressure
- Engine lopes after load
- Whats the Dimensions of a 12V Engine ??
- Hard start after #100
- 12 valve intermittent power & throttle response loss
- Turbo time
- mpg
- Fuel Problem
- head.
- oil pressure Q's
- cant someone explain how to use the auto tranny lock mod?
- Need pics
- Warming up Probs.
