PDA
View Full Version : 12 Valve 2nd Gen Dodge Cummins 94-98
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25 26 27 28 29
  1. 24 to 12
  2. TPS
  3. Throttle cutting back
  4. death wobble like a mother on new suspension HELP!!!!!
  5. The Best Timing Setting
  6. Freeze plug install
  7. engine shake
  8. power to manual windows
  9. tranny ?
  10. Rumour ive heard
  11. AFC Question
  12. starting problem
  13. dies at idle
  14. how to turn up a p7100 injection pump
  15. fuel plate for mileage
  16. ring and pinion question
  17. Found a truck but is it a deal?
  18. newcomer help
  19. Fuel oil
  20. P7100 gov arm adjustment help needed
  21. Order List
  22. #6 dv gone ???????????????
  23. bucking and kicking
  24. Vacume lines from transfer cast to engine
  25. new 1995, what should i do?
  26. Added consumption with following mods...
  27. very loud poping out of intake need help
  28. NEW TRUCK!!!
  29. Fuel tank mounting hardware?
  30. i have a new oil leak
  31. rocker panels
  32. can someone measure their springs for me?
  33. no more slushbox
  34. fuel screw help
  35. wiring
  36. Racing a Ford
  37. AFC adjustment
  38. Why does my truck make a popping sound?
  39. need help making a decision
  40. Stalling problems
  41. voltage problems
  42. Oil leak need help!
  43. dana 70 rebuild ?????
  44. pcm
  45. Bump up my timing
  46. tranny temp light
  47. copper spray
  48. dclemens
  49. Fuel system problem
  50. Timing and KDP
  51. Battery Not Charging
  52. Installing Tranny temp sensor advice?
  53. dropping RPM's
  54. fuel pressure sender?
  55. egt problem
  56. Weirdest thing happened today
  57. NV4500 questions
  58. Fuel filter question
  59. Desperate, getting conflicting information
  60. low fuel pressure (pulling my hair out)
  61. wheel seals
  62. black smoke with no throttle
  63. Question on tire/wheel size and backspacing for a 98 Dodge 2500
  64. been doing some bombing the past few weeks
  65. What rear end should I look for.
  66. intercooler size
  67. Newer cab on older truck
  68. Wiring Harness
  69. hood scoops
  70. 4wd only in reverse
  71. Help 12V Misfiring ????
  72. help
  73. white smoke
  74. headlight relay???
  75. a/c problems
  76. Body or Engine swap?
  77. I found a deal on a motor tranny
  78. trouble with truck
  79. My quest for a CUMMINS!
  80. Help mystery spark
  81. A/C problems
  82. HELP
  83. parts breakdown for the the 241
  84. Nice 12V
  85. Rev Limiter WTF
  86. no intercooler?
  87. Grinding the Fuel Plate
  88. I need a measurement from a 2nd gen DRW
  89. What's normal temperture?
  90. '96 2500 4X4 quit working suddenly?
  91. voltage regulator
  92. NV 4500 Parts Brakedown
  93. o/d kicking in and out
  94. KDP.....KILLED
  95. Brake light issue
  96. Trans. not shifting right
  97. new to this forum
  98. Want to tap into turn signal wires.
  99. Tranny? Or gears? Or what?
  100. ac compressor
  101. 12 valve oil pressure
  102. Headlights
  103. Leak?
  104. Front door speaker nothing issue
  105. Lift pump questions
  106. FUEL PRESSURE
  107. grid heater/voltage
  108. fuel pressure gauge
  109. Tranny Temp
  110. 96 dodge
  111. auto tranny swap
  112. clutch
  113. Brian Vannest
  114. wiring harness
  115. hgh egts
  116. headliner removal
  117. 47RE Valve body removal?
  118. axle seal
  119. gas pedal
  120. No 4Wheel drive??
  121. P-7100?
  122. front end ?s
  123. Tranny problem
  124. Project SLOBOAT P-pump conversion
  125. Hard Spot in Throttle Linkage
  126. Bolt Torque Specs?
  127. shift points
  128. Starter has worn out....
  129. fuel plate problem
  130. whats wrong here???
  131. rear lift blocks
  132. twin turbo air intake
  133. newfuel pressure guage
  134. RPO codes or similar ?
  135. Rear end... dually vs single ?
  136. cummins overflow valve
  137. broken gas guage
  138. donor truck
  139. Oil leaking from exhaust manifold
  140. 4x4??
  141. blown headgasket
  142. Pitman Arm/ Steering Bind
  143. 07 turbo?
  144. Good deal on engine or not
  145. new 12 valve
  146. Estimated HP ?
  147. headliner fail
  148. number 5 & 6 valves
  149. auto to manual
  150. HELLLPPPP!!!!
  151. 4x4
  152. Smoke ?
  153. Seat repair
  154. Boost ?
  155. turbo???
  156. oik leak from injection pump/afc housing
  157. 12 valve manifold fits what years ?
  158. 12 valve lope
  159. 12 valve question
  160. tranny vb mods???
  161. Engine degreaser
  162. best price on a tps
  163. Just got a Cummins to toy with....
  164. 35s on stock 97?
  165. blowby tube
  166. tranny
  167. what do you guys think of zoom clutches from napa
  168. hard starts in the morning any ideas?
  169. Wheel question
  170. Chemical Injection
  171. Gear case cover bolt torque?
  172. AC doesn't work.. common problems?
  173. turbo
  174. question on timing kit ebay
  175. 12 valve cummins injector
  176. need a part number. can someone help?
  177. pull the engine for oil pan gasket
  178. cummins heater grid
  179. TPS read out - 1996
  180. help cummins white smoke rough idle
  181. crank position sensor
  182. tps question again
  183. Hard to start
  184. who makes a good clutch
  185. fuel shutoff
  186. hey
  187. got my o-ringed head back...totally pissed!!!!!
  188. Starter contacts
  189. ruined my freshly rebuilt trans??
  190. ball joints
  191. Blowby
  192. is this worth it?
  193. turning my a/c pump into an aircompressor
  194. 12 valve
  195. changing my cab over
  196. Transmision or engine problems?
  197. injectors help
  198. oil pressure sending unit
  199. transmission pressure
  200. HP recipes
  201. What size fuel line?
  202. Oil pressure falling
  203. front axle disasembly
  204. How do i time my new pump?
  205. 98 12v touchy throttle
  206. how much timing?
  207. sliding the plate
  208. trans question
  209. 96 and 98 whats the difference
  210. Tranny lines
  211. Flutter?
  212. fuel pressure sensor
  213. tachometer
  214. tps question
  215. dont buy cheap parts to save money
  216. Valve Lash Adjustment Help
  217. voltage regulator
  218. HELP!!
  219. Trans AN fitting size
  220. delete pre-filter and heater?
  221. Timing in WNY
  222. KDP Questions
  223. unsolved air in fuel
  224. Head Dimensions
  225. Transmission cant make up its mind?
  226. heres one for ya
  227. Trackbar
  228. Oil leak under injection pump.
  229. front ladder bar
  230. i f!@#ing broke it
  231. Shifting from 1st to 2nd
  232. Not revving down and loss of power
  233. better traction
  234. Alternator?
  235. pretty sure i blew my TC
  236. HELP
  237. Turbo Question
  238. tranny opnion
  239. ball joint
  240. alittle smoke help please
  241. help id this holset turbo
  242. No Overdrive
  243. Erratic oil pressure gauge.
  244. ABS sensor
  245. front coil springs
  246. confused
  247. Oil Leak
  248. whats a good timing degree?
  249. HELP! Truck is dead!
  250. help
