PDA
View Full Version : 24 Valve 2nd Gen Dodge Cummins 98.5-02
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 [19] 20 21 22 23 24 25 26 27 28
  1. air ride or traction bars? help
  2. It choked and died with no warning….can’t figure it out
  3. Help me identify this turbo
  4. speedometer not working right
  5. 47re help
  6. 53 block precautions?
  7. center lug nut hubcap
  8. dead reverse lights
  9. Parking Brake Light
  10. power problems
  11. Fuel Mileage
  12. Fuel Mileage
  13. Vp not working, no trouble codes
  14. 6 speed trans failure follow up
  15. fuel pump
  16. fan hub
  17. Im in need of a rear passenger window...
  18. hard start fuel problem?
  19. Stacking Tuners?
  20. blowby tube
  21. Bad batteries cause bad mpgs?
  22. 99 dodge ram engine swap questions
  23. nv5600 tear down... o dang
  24. 5 speed tranny fix
  25. APP Sensor
  26. pcm flash
  27. hx35-40 compressor wheel
  28. 01 Cummins cylinder head fuel overflow line
  29. Need Help
  30. PUSHRODS
  31. Replacement Hard Vacuum Lines
  32. Windshield Repair??
  33. VP44 BLUES
  34. 6 speed trans failure
  35. 2001 stock Turbo pressures
  36. Oil and thick grease build up???
  37. No Injectors for Me!??
  38. idle lope
  39. Doors pins
  40. Wheel hubs
  41. Wait to start light
  42. 2nd gear slip
  43. Turbo help
  44. Warm up idle
  45. one more question
  46. 6 speed swap ?!?!
  47. 31 psi w/ stock un touched HY35???
  48. What Psi are you getting at Idle with A/F Pump
  49. Help Please!
  50. 0380 dtc ??
  51. Cons of stackin smarty and edge comp box?
  52. 5 speed trans help
  53. in the tank fuel pump
  54. Headlights Stuck On
  55. 01 2500
  56. Pics of Cat Stax Wanted
  57. TPS Sensor code
  58. Sending unit replacement
  59. h.i.d bulbs
  60. Funny noise!!!
  61. Need help with nv4500 parts
  62. abs light on
  63. 02 Auto Trans
  64. blew something
  65. EJWA Install
  66. HELP! TDC question
  67. dt control arm bushing size
  68. Need an answer FAST
  69. Swaping OD units.
  70. Bad injection pump?
  71. Turbo going bad?
  72. 24valve plug and play
  73. ABS Booster
  74. Tore the roof(and doors) off
  75. Auto Swap 47 for a 68 conversion??
  76. always grinds into 3rd gear
  77. new lift pump or intank pump
  78. quadzilla xzillaraider help!!!!
  79. Vulcan DS V Install
  80. carrier barring?
  81. strange pull??
  82. Stock looking for more but no chip?
  83. Driveline noise?? Doesnt sound good.
  84. Muffler Delete Yes or No
  85. 02 24v issue
  86. 33x12.50's
  87. 01 cummins smoke at idle
  88. 5" down pipe
  89. new lift pump?
  90. Spray in Bedliners other uses
  91. Several Questions (lift pump issue, 4x4 engagement)
  92. t case... rebuild or upgrade?
  93. Injector Upgrade
  94. Fuel Problem
  95. Fuel gauge not working !
  96. Any suggestions ??
  97. 01 Dodge 3500 diagnostic port problem
  98. My latest 2nd Gen electrical system gremlin
  99. Fuel Pump
  100. another fuel pressure gauge question
  101. Computer Question
  102. VP44 swap
  103. dead pedal question
  104. 1999 dodge ram no start
  105. Upgrade intake?
  106. Oil filter relocation
  107. Smarty Troubles HELP!!!!!!
  108. Gauges or a EJWA or QUAD?? Need opinion
  109. neutral safety switch - what tool to use?
  110. I Got A Little Problem
  111. Speedo quit after installing BD speed eliminator
  112. AirDog Question
  113. new guages, now what
  114. 1998.5 NOT cranking
  115. What size injectors?
  116. I GOT A PROBLEM!!!!!!!!!!!!!!!
  117. 4WD DO-DAD
  118. 24 Valve 5.9 Liter Dodge Cummins
  119. Yes! Got it!
  120. lost 3rd and 4th gear
  121. thought I had a spare turbo...
  122. auto to manual swap
  123. blow-by
  124. 2001 ram steering/brake issues
  125. what did I MISS?
  126. guidance
  127. getting a 02 cummins with an auto and 130xxx
  128. oil leak?
  129. starter problems
  130. In tank lift pump ?????
  131. no lift pump power
  132. need help
  133. 2000 5.9 MPG!!
  134. power steering pump leaking
  135. E-brake
  136. How long can i run my truck without an air dog or fass?
  137. New to Diesel world with Cummins Wastegate questions
  138. 53 block perdiciment
  139. First post and a question
  140. Maintenace
  141. tranny rebuild qustions? please help
  142. 47re help needed
  143. No power
  144. What would cause my fuel tank to be pressurized?
  145. Advice on tuners
  146. 2 Run or not 2 run 2 stroke
  147. blue smoke
  148. crappy night.. now what?
  149. Is Exhaust Brakes Worth The Money
  150. 01 cummins not starting
  151. power steering/brake issue
  152. Should I dump it?
  153. good reads on a website about used motor oil and disel fuel
  154. Transmission is starting off in 2nd.
  155. 1999 Dodge 2500 no altenator charge
  156. BANKS EX. BRAKE
  157. Cheap turbo???
  158. lost 10lbs of boost when i swiched to a hot rod vp
  159. P0500 and P1693 codes
  160. Need Help Apps
  161. crazy exhaust sound
  162. Should i buy this truck?
  163. block heater temps
  164. 24 volt conversion
  165. truck running weak please help!
  166. 2000 Cummins, start issue
  167. is amsoil worth the bling
  168. Miss at idle? Help
  169. Best 47re VB
  170. intank pump or not?
  171. CB Mount
  172. loping?
  173. 53 block
  174. starter problems
  175. axle ? for yall
  176. 19.5\22.5 rims on 1998.5 dually?
  177. tps/curse corntroll problems
  178. DAngitT!! NV4500 5th gear clutch ring...
  179. What could this noise be?
  180. Torque specs and bolt size for RH motor mount???
  181. HX 35/40 turbo?
  182. Freshly minted diesel owner...key fob ??
  183. 3 codes please help!!!
  184. throttle position sensor???
  185. Any suggestions on where to start?
  186. (beating a dead horse) trans question
  187. crank sensor or what?
  188. Trying to find leak in return line.
  189. 1999 cummins making driving me nuts
  190. vp44 normal pressure
  191. 53 block
  192. How much is it worth?
  193. fan control switch
  194. Hard Start, Error Codes, New Transmission
  195. fuel press low warning light???
  196. Sending Unit?
  197. parking brake???
  198. ABS Problem
  199. Clicking in Front End
  200. winter cover
  201. Fuel Filter housing
  202. not starting
  203. take over jumpin
  204. vp44 hot problem
  205. ok next question dana 80 spline count
  206. G56 swap?
  207. Found Out What My Stutter Was Caused By! &%$#!!
  208. i have 3 codes on my ecu
  209. 4x4 isnt really4x4
  210. 2001 cummins programmer for fuel mileage?
  211. 99 dodge overdrive problems
  212. Tuner Question.
  213. 4 wheel drive issue
  214. stupid turbo clamp!
  215. Weird vibrations
  216. lift pump questions
  217. New whistle
  218. Need some help
  219. Lift pump delay
  220. engine washing
  221. hy35w turbo
  222. 2001 Sputter and stall ...no codes
  223. Gearing
  224. replacement seat bottom cover
  225. what is a smoke kill kit?
  226. veggie oil
  227. Grease used front sus.
  228. Trans rebuild
  229. what causes the truck to go into limp mode?
  230. nv4500 grinding in third & fourth gear
  231. Torque Management
  232. Trans shutter.... need help
  233. 1690 DTC
  234. Is it my VP??
  235. run away pump
  236. 53 Block
  237. looking at buying a 01 24 valve cummins
  238. vibration sound from somewhere
  239. 02 swap to 03
  240. I hate 24V's
  241. 47RE VALVE HUNG OPEN
  242. Dodge exhaust brake
  243. rocker arm ratio
  244. How long for shop to replace VP44
  245. ABS Control Module questions
  246. Brake Issues?
  247. Fueling Problem?
  248. Dash dead
  249. 0216 Fuel Injection pump Timing Malfunction
  250. Hard starting after sitting overnight
