PDA
View Full Version : 24 Valve 2nd Gen Dodge Cummins 98.5-02
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28
  1. smarty / edge settings
  2. np241 vs 241dld
  3. need immidiate help with removing dash!!
  4. 24 valve question
  5. Repair kit for 98.5-02 VP44 Electronic Control Unit
  6. Time for injectors.
  7. mpg difference between 6 speed and 5 speed
  8. trouble adjusting new anzo headlights
  9. Freezing 24V Cab. Best way to warm it up?
  10. ddp 110 hp injectors
  11. 2002 cummins 6 speed transfer case oil
  12. Bad miss,white smoke
  13. Water separator smells like gas?
  14. smarty
  15. Vp 44 pump connector
  16. Tow Hooks
  17. blown codes
  18. 99 2500 Cummins MPG low?
  19. Speedo Problem!
  20. advice/opinion(s)
  21. Water in passenger floorboard
  22. Water in passenger floorboard
  23. 100 RPM spikes, trying to shift?
  24. Oil leek from gasket?
  25. Airdog Filters!
  26. Loud knock when cold, goes away when warm
  27. Programmer help
  28. need pic help
  29. OverFlow Valve
  30. oil leaks
  31. Injector advice needed
  32. Free spin hubs, yukon vs spyntec vs dynatrac
  33. DEAD PEDAL DRIVING ME CRAZY HELP
  34. Feedback on this boost elbow
  35. phatshaft 62 internals?
  36. Stumped on this 24 valve
  37. 1999
  38. fuel filter housing leaking again!!
  39. Shifting Issues
  40. phatshaft boost elbow issues
  41. Temperature fluctuation :jigabop
  42. Auxiliary fuel tank install tips
  43. BHAF options
  44. Electrical starting problems
  45. help!!
  46. Head studs or no?
  47. 24v cooling system problem..very wierd..check out!
  48. 1999 cummins better mpg?
  49. coolant leaking threw headstud after retorque
  50. turbo upgrade
  51. 5.9 upgrade
  52. 99 supply pump problems
  53. u joint catastrophe
  54. 2001 24 valve injection pump?
  55. SHOULD I TRADE MY 24 VALVE
  56. Outerwear for Amsoil EEAU 4090
  57. gauge differences
  58. Clutch sqeaks and oil temp
  59. Noises when hitting bumps
  60. Egt readings?
  61. Bad Heater core or t-stat?
  62. Looking into to clutches
  63. Lift Pump?
  64. Quadzilla repairs/modifications
  65. 24 Valve Rough Idle/miss
  66. 01 cummins hard starts and has thin oil?
  67. burning oil
  68. Fuel pressure gauge install?????
  69. Fuel pressure gauge install?????
  70. boost question
  71. No start, anything but a vp44.
  72. HELP LEAK
  73. P0720 Help Please
  74. Keyless Entry
  75. Stacks???
  76. need help now!
  77. alternator diodes, torque converter, vp 44
  78. Who Has done the Most 24V Motor swaps...?
  79. 98.5 Cummings 3500 high idle?
  80. surging fuel pressure
  81. valves
  82. APPS, ECM, or what?
  83. timing question
  84. fuel presssure gauge
  85. Injector Chart Understanding please
  86. Sad News
  87. 2000 Ram 3500 Fog Light Help Needed!!!
  88. TURBO SUGGESTIONS
  89. Is this a good price for 2001 dodge 2500 diesel?
  90. CRANK SENSOR!!!???
  91. truck fixed, finally
  92. Turbo Gurus - - need input
  93. Fuel Pressure Gauge with a FASS question
  94. Injectors
  95. anyone running bd super b twins?
  96. single to dually
  97. 1999 cummins exhaust tips
  98. fass lift pump intall help
  99. Problem with it cummin!!
  100. 1998.5 24v installing a fass pump need help
  101. fuel del. issue
  102. turbo boot wont stay on!
  103. New truck/tranny problem
  104. what turbo do i have?
  105. 98.5 hole in block
  106. Engine chirping
  107. Intermittent power loss
  108. 98.5 to 2001 swap is it possible
  109. yellow check engine light
  110. 2nd gen 24v shrieks when I shut it off
  111. Cummins acting funny
  112. 2002 24v water will not.drain.from fuel filter
  113. Wat to do with a one ton
  114. 360 to cummins swap
  115. Need help fast
  116. donaldson oil filter
  117. Piston protrusion
  118. High idle issue and WTS light not coming on
  119. truck wont start
  120. Advice for purchase on 2002 2500
  121. More Power? Auto vs Standard?
  122. What's next?
  123. Information on 1998.5 to 2002 Cummins
  124. Turbo Innercooler
  125. Bigger Injectors? 5.9 cummins 24v
  126. piston position
  127. Oil pressure gauge
  128. To good to be true? Trade a 92 dually for a 99?
  129. 4x4 posi-lok
  130. how often do you guys change your fuel filter on a fass system.
  131. Advice on Purchase of 99 2500
  132. VP-44
  133. making two trucks into one any advice?
  134. How much can i go???
  135. Questions about twins
  136. 6.7 cummins stock turbo / exhaust brake
  137. new cummins owner
  138. EGT question
  139. 3cylinder warm up and superchips max micro tuner
  140. FASS TECH SUPPORT- Phone number???
  141. 2001 HIGH ++ Fuel Pressure DDRP-02 Why??
  142. no power and smokin.
  143. bad radio wiring?
  144. victor reinz vs cummins?
  145. so my new clutch slips....
  146. In need of longer control arms
  147. edge cs programmer
  148. What to do about my filter?
  149. fuel pressure gauge reading 0psi
  150. Electrical problum
  151. cummins 4x4 11mpg ?? how can i get 20
  152. Bad Fuel Mileage
  153. 3.55 to 3.73 mileage difference
  154. upgrades for my 1998.5
  155. HP & TQ
  156. BHAF?
  157. Just another newbie with some questions
  158. Best tire size for highway fuel economy
  159. won't start
  160. new truck questions
  161. transmission shops
  162. intake tube bolts
  163. o-rings?
  164. Looking for a Holset HX35
  165. Exhaust Heat Shield Wraps?
  166. Electrical
  167. Exhaust & Intake
  168. brand new to the diesel world need some help
  169. excited to join this forum!
  170. hard start after injectors help pinpoint issue please!
  171. P0234 - Turbo Boost Limit Exceeded
  172. Bad drive shaft ? Leaky transfer and diff
  173. 01 dodge power upgrades
  174. Boost gauge too small??
  175. dead pedal
  176. Should I rebuild or replace?? my hy35
  177. 2001 Cummins Jerking/Bucking
  178. Boost elbow questions
  179. Looking at a truck..PLEASE HELP
  180. My 1999 Dodge Ram 3500 QC/4WD
  181. OLD PROGRAMMERS
  182. injector help
  183. Vacuum Problems!
  184. 2001 2500 wheels fit a 2003 2500?
  185. Did I blow it changing fuel filter
  186. Fog Light Question
  187. looking to get a locker
  188. Turbo question
  189. 5" strait pipe??
  190. Power Total Guess
  191. Kool-Vue mirrors
  192. Ready for my next mod and need help desiding
  193. temp gauge running hot for no reason
  194. Programmer Thoughts?
  195. 2012 bumper on 2002 cummins
  196. Not shutting off
  197. Weird electrical noise
  198. mods
  199. Throwing a lot of Codes and "Surging"
  200. Trouble shooting
  201. P0234 p0236 p0216
  202. rpm moving going down the road
  203. Silencer ring
  204. Larger tires pros and cons
  205. Need help priming
  206. just another transmission question
  207. HELP! Auto Stuck in high gear and wont shift. lots of smoke
  208. Might be buying A 02 3500 with 166k
  209. NOOB IN THE LOBBY
  210. What gears for 37'' tires
  211. Please Help Diagnose
  212. Honest opinion for transmission?
  213. dana 70??
  214. 98.5 - no start.
  215. quadzilla adrenaline
  216. Hard to start
  217. New to me 99 Cummins ?'s
  218. Whining noise when accelerating???
  219. oil filter housing
  220. buying a new clutch
  221. 2001 Dodge Just Quite
  222. Awesome 99 QCSB for sale - Gotta see it!!!
  223. New might buy 01 5.9 tomorrow help?!
  224. s466 over s4t over phat bastard IS IT POSIBLE?
  225. t4i flange adapter leak
  226. 99 for $500 yes or no?
  227. No power til warm
  228. so i just bought a 98 24v 2500 head/reverse lights-speedo
  229. Turbo spool issues
  230. fuel pressure issues
  231. cummins starters
  232. Who is the best 24V Mechanic / tech here..?
  233. brake drum full of oil
  234. bad injection pump?
  235. Keep blowing head gasket need help
  236. I HAVE NO FRONT BRAKES
  237. please helppppp
  238. No Turbo Blow Issue....?
  239. need a block
  240. shot in the dark
  241. nv5600 rattling
  242. where to check temp. of Transmission
  243. a good old vacume pump question...
  244. Goerend
  245. Transmission Lockout grumble?
  246. Auto to manual swap, motor swap, etc
  247. new pump , tricks ?
  248. what size and thread pitch
  249. Brand New Starter still giving me Hell
  250. Turbo question.
