PDA
View Full Version : 24 Valve 2nd Gen Dodge Cummins 98.5-02
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18] 19 20 21 22 23 24 25 26 27 28
  1. MAP Sensors differences
  2. no power steering at idle
  3. turbo
  4. twins???
  5. 2001 EGTs too hot for my liking. STILL
  6. minimum to start a 24v
  7. Transmission controlling and YOU
  8. Radiator
  9. smarty_s03
  10. cooling down egt
  11. Help. New guy figuring out modified truck
  12. Dead with Dtc's
  13. tps?
  14. S300 lightning
  15. resistor installed on 1998.5 24v 5.9 between tps and ecm
  16. Trouble Code P 1693
  17. Need help ASAP, fuel pumps and pressure questions
  18. Bed interchangability
  19. slave cylinder question
  20. Trans jumps in and out of lockup
  21. hx35 dying upgrade ideas.
  22. 01 concerns
  23. Weird tranny shifting?
  24. up grade
  25. New vp44 and still wont run
  26. tranny problems
  27. Possible Transmission Patch
  28. Engine swap...
  29. Silencer Rings
  30. towing truck
  31. RPM limits
  32. injector hold down
  33. Fuel pressure switch location
  34. Help New 47RE Transmission is Cracked
  35. Transmission issues wont stop
  36. clutch squeel?
  37. Stock exhaust size
  38. Truck Died
  39. Transmission? Electrical?
  40. Electrical problem?
  41. need help 99 24v cutting out
  42. Keyless Fob
  43. Weird Fuel Pressure????
  44. Starting problems
  45. Truck stalls sometimes
  46. Cruise Control Issues
  47. Seat belt light
  48. vp44 story
  49. MT-45 5.9, Fed Ex, Custom Chassis
  50. New issue
  51. Trade
  52. need help truck over charging and no power with key on
  53. TPS $500
  54. 94 12 valve in 99 24 valve motor mounts
  55. ATS Auro 3000 turbo
  56. fuel leak need help
  57. converter issues
  58. Transmission Woes (another one of these ?)
  59. excessive noise
  60. starter solenoid
  61. starting troubles
  62. New Dodge owner
  63. hx 35 swap help!
  64. turbo silencer ring removal a guide
  65. 2002 Dodge ram 3500 Brake upgrade
  66. Fuel leak..
  67. cummins wont start!?
  68. Billet Grills
  69. A/C Issues
  70. rebuilt the bosses tranny... :/
  71. Time for twin turbos!
  72. 4x4 problems
  73. Completely dead dodge...
  74. Tranny question...
  75. Help me fix my Steering...
  76. need help
  77. 99' 3500 doge cummings , break fuse blow out
  78. Rebuild Questions
  79. 47re transfer case
  80. fuel pressure gauge
  81. Tricky Cummins
  82. wacky gauge cluster
  83. Front end rattle???
  84. Front Driveshaft ?
  85. Turbo Bad???
  86. How much power?
  87. stacking a chip over a so3 smarty
  88. need help please
  89. in need of Stack parts
  90. 2000 24v 450hp truth or bs
  91. Programmer
  92. u joints
  93. wont start
  94. miss at idle help
  95. Reverse lights on...
  96. new vp44
  97. squeeks and squeels and unidentified noises
  98. engine temp running high
  99. 24v KDP
  100. 4" or 5"
  101. Cupholders the real fix
  102. 01 questions
  103. Fuel Issue... Maybe
  104. Dash Bezel
  105. spare tire winch broke
  106. why does my truck go into high idle
  107. in need of rebuild?
  108. no power windows no ac air bag light and abs light ohhh and no speedo
  109. Filling up on 17 gallons???
  110. hearter grid
  111. AC vs Trans
  112. Could it be something else??
  113. 99 5 spd shifting problems
  114. cummins missing a beat?
  115. popping in front end
  116. brake lines
  117. CLUTCH PROBLEMS 1999 DODGE RAM 3500
  118. Beefing up 47RE
  119. 47RE troubles
  120. Coolant at Turbo
  121. 02 24v cutting out
  122. Starter questions
  123. need advice for my 01 3500 24 v
  124. 2000 cummins lift pump issues
  125. fuel/oil
  126. reverse light switch
  127. Hauling question
  128. Fuel serging
  129. engine running above normal temp????
  130. Wiring diagrams for 98.5
  131. Need Van aaken smart box V5 wiring diagram!!!
  132. white smoke. help!
  133. lift pump?
  134. Engine temp fluctuation
  135. Tranmission has me ready to drive truck off a cliff.
  136. fluid for nv5600?
  137. Front end help
  138. airdog 2 issue
  139. problems with front axle camber
  140. Help I don't know what's going on
  141. Where can I find a manual on the 5.9L?
  142. superchip?
  143. airdog or fass
  144. Day time running lights
  145. Vehicle Speed Sensor only works in the rain
  146. swapping nv4500 to nv5600
  147. TS Performance Torque Converter Lock Up
  148. banjo bolts
  149. how to tell and how to remove
  150. For Sale: 2001 Dodge QCSB CTD 105k
  151. south bend clutch question
  152. P-Pumped 24v Advice
  153. Transmissons
  154. power steering help?
  155. Possible input shaft?
  156. Engine temp is running very cool
  157. Fuel issue
  158. Multitude of worries
  159. 02 24 v will not shift outta 4th gear
  160. lift pump
  161. TOWING IN OD
  162. vp44 or apps?
  163. continuing tranny probs
  164. Turbo
  165. 2000 engine in a 2004 3500 truck?
  166. BOOM...BOOM...Rattle.......
  167. 01 24 valve cummings no start
  168. low fp sensor
  169. tuner ?
  170. FP gauge no start?
  171. Turbo Compressor Wheel
  172. Gears = mpg???
  173. 2002 Dodge Cummins Noise
  174. another problem wierd sound? power steering?
  175. TC and Valve Body
  176. In-tank pump??
  177. Fuel Pressure Warning Light
  178. fuel problem
  179. ABS / P-brake lights on
  180. tow mirrors
  181. e brake drag
  182. Bought my first Cummins! couple???"S
  183. Unhooking the odometer from you trans.
  184. I feel like an idiot...
  185. Cummins help needed
  186. dtech turbos
  187. No power
  188. trailer wiring
  189. What is Valve Lashing
  190. Possible axle issue?
  191. Snap-on scan tool reading 5psi boost at idle
  192. where to but trans comp?
  193. Noise?
  194. please help im loosing my mind lol
  195. P1689,P1693,P0237
  196. Throttle cable
  197. Fan Clutch going out
  198. 2001 cummins oil leak?!?!
  199. Trans / TPS
  200. Leaking Fuel $$$
  201. 2000 5.9L Cummins value?
  202. Code
  203. tranny
  204. Question for the pros
  205. vacuum?
  206. hard start
  207. Boost or Exhaust Leak
  208. will it bolt up?
  209. is this pump issues
  210. 01 stock turbo ho motor
  211. how much is to much
  212. torque specs
  213. engine blocks
  214. Pitman arm puller
  215. continuous codes
  216. How Much Are You Paying For Diesel.
  217. fuel press
  218. Block Heater Humming
  219. Electrical Gremlins
  220. 2001 cummins 4x4 6 speed lacks power
  221. is it my IP or the APPS??
  222. help!
  223. sensor question
  224. Help installing a Fuel Pressure Guage
  225. leveling kits
  226. rim back spacing?
  227. Manifold question
  228. Engine Flush
  229. help with a nv4500 swap.
  230. Changing Chips! Going from Pooper chips to Edge juice or smarty??
  231. ECM?
  232. Codes
  233. Valve adjustment after rebuild
  234. Weak throttle response.
  235. loss of power
  236. alternator connector
  237. 02 popin in the higher rpms...headgasket?
  238. Heater fan switch
  239. getting codes again.
  240. New to 24v, looking for a quick bit of info to get started
  241. rebuild or replace nv5600?
  242. New Injectors or Remans?
  243. looking for dually flares for my 99 Dodge 3500
  244. Boost leak??
  245. HY-35 Feeler
  246. Quadzilla adrenaline
  247. water injection??
  248. AirDog Question
  249. can anyone help me please??
  250. Gasoline in my Cummins
