- Hearted seats
- 2001 24v
- 2nd gen cummins traction bars
- need input for a proper build
- fuel pressure issues HELP!
- Keep burning up lift pumps
- Help. Keep burning up lift pumps
- Checking lift pump
- Missing bad at 2700 & above
- hot rod vp44
- Rusted out oil pan on a 99
- HELP!! Edge Comp Install!!!!
- 356,000
- 2001 auto cummins shifting issues
- nv4500 shifting problems
- No Start Inj.Pump issue
- bad t cooler now no gears
- Computer Problem?
- ASD relay issues
- Single stack is it loud in the cab?
- overdrive issues
- 01 cummins p0216
- Which transmission should I buy?!
- Want to make more hp
- Vp44 24 valve injector up grades
- my first 24v
- Air dog lift pump failure ?
- brown cooliant..cracked block?
- PLEASE HELP! Mom's 98.5 2500 4x4auto tran has taken a poop!
- looking to upgrade exaust
- Programmer?
- *Please Help* Only Runs with Computer Unhooked
- tow hooks on a 2nd gen.
- simple questions
- transmision slips after fluid change
- Edge comp box
- 24v fuel pressure drop
- 24v cummins won't start
- Fuel leak need help
- First start in 2 years.
- trouble finding a part please help
- Need help with programmer!
- can anyone help?
- VP44 and 2-stroke oil?
- 99 Cummins NO BUS after failed TC lock switch install
- removing valve springs
- Raptor pump going down to 6psi at wot
- dually tires
- 98.5 Cummins California Smog Passing
- atf in bellhousing?
- Truck doesnt want to start
- Is it worth my time.... Head work
- Overhead Console Map light switch repair
- steering fluid puking
- Mud truck check engine codes
- 01 Bad injector(s)?
- Hub replacement
- Making Progress
- new turbo
- rocker arm galling
- No lift pump
- LIVE VP44 TAPPING NEED HELP!!!
- i need brakes
- Converting to a sport front bumper
- New to this
- AMP Research PowerStep Conversion Kit - FINALLY!
- Replacing input rod seals on hydroboost
- Bulids
- Edge Attitude fuel pressure sensor
- EDGE WITH ATTITUDE 31000 Not Working properly...
- KYB shocks
- How to?
- converting to p pump
- high idle help!
- Bosch 7100 p-pump
- 99 cummins 5 speed torque monitor spiking
- recabbing 99 dodge with cummins
- Can I swap an NV5600 with an NV4500?
- Cold air intake
- Best cleaner
- Surging, High Voltage, High Idle
- not charging
- skipping around 30 to 45 mph
- Charging Problems/ Wiring question
- Dead batteries, water pump leak
- 500hp cummins
- EDGE-ATTITUDE PLUS RAPTOR = QUESTIONS
- lift pump and injector help
- vavle springs?
- problems cranking
- Power steering and brakes
- rough start
- Parking Brake issues
- anybody out there selling a programmer? 01 24v
- no power
- airdog acting strange in cold
- Acceptable battery draw or drain key off
- High Idle Kit
- HELP WITH MY LIFT PUMP!!! PLEASE
- tuners and cruise control
- Coolant
- Leaking problems
- grid heater un-delete help
- Fuel pressure droping
- Cruise control not working
- Dead Pedal using Cruise Control, Intermittent Engine Stumble without CC
- 99 stalls when warm
- idle missing/stutter problem?
- 01 24 Valve performance questions!!
- Low voltage even after new alt and new batteries.
- Egt and boost question
- Wide open throttle when pedal is touched
- Flexplate off V10
- Cranks but won't start
- Cruise control situation
- Gauges Dropping Out / Surging Engine
- Parts?
- 2001/1999 Cummins cam gears
- Sheared teeth on nv4500
- Looking For More HP
- 2001 Dodge Cummins
- Starting Problem
- Shifting/Tranny question
- Rough running
- Tuner help
- 4 wheel drive conversion?
- Aggressive tune = air in fuel?
- 98.5 auto transmisson problem
- 23 stamped on block?
- Another Code P0216
- 6 blade inducer on stock hx35???
- Fan clutch issue?
- Intake horn
- ANYONE HAD ANY ISSUES WITH BD DIESEL PERFORMANCE PLUS TRANNYS
- Leaking Fuel?
- tranny problems help
- clutch selection help
- Hard to start
- New starter or rebuild solenoid
- Which turbo to use
- 24valve lovers, I need your help!
- Turbocharger education
- thread sealant for fuel line
- If it was your truck
- day time running light trouble
- Turbo/injector suggestions
- help
- hotrod vp44 and edge issues
- charging system problem
- P1690 & P1693 codes
- fass issue
- Heater/Ac control not working HELPPPPP!!!
- Fuel pressure gauge question
- Injector Pump Change Mishap!
- 2001 2500 SCLB 6SPD 2WD LOW MILES $8,500
- Should i sell or rebuild?
- transmission help
- MAP sensor symptoms?
- 01 speedo cruise control odometer not working
- Cracked Timing Gear Housing....Help?
- map sensor 2000 Cummins
- 24v fuel pressure question
- HY35
- Steering upgrade
- transmission issues
- 01 cummins 24v
- Speed Sensor
- Headlight upgrade
- Block->front cover gasket, Book time?
- Manual Trans, Engine revs up, Truck stays
- 6.5ft to 8ft bed swap
- vacum leak in fuel line new raptor 100
- 2001 Dodge Ram 2500 to 2005 Cummins' motor mounts
- 1k saved up
- P pumped 2001 Dodge Ram 2500
- '01 TRANSPLANT ISSUES/CONCERNS
- Tranny slips when cold
- what to do before injectors
- 3 cold cylinders
- new vp44 , shrader valve and gauge question
- Project white stallion
- vp44 going out...need advice
- DTT assasin lift pump.
- 01cummins. ac issues
- 01 Cummins 5.9
- Advice needed for programmer!
- 98.5 24v jerking on accerlation
- DRW LB to SRW SB (2wd)
- fuel pump problems
- Want opinions on programmer
- twin turbo advice
- shifting problem
- high hp questions
- Manning motorsports
- 4x4 will not engage
- No Start
- suspected lift pump problem
- 2001 cummings pressurized fuel tank
- No power to lift pump
- First Time Owner and I'm at a Loss
- Putting a bed on a 2001 reg cab dually
- 98 cummins slow as sh*t
- is it worth it? need advice.
- over boost issue
- vp44 leak help
- starting issue
- Transmission
- Cummins longevity
- powerloss
- rusty turbo bolts
- Brake peddle pulses when stopping slow
- Need a little help. will not start.
- Question about the NV4500 conversion
- bad cam sensor?? or bad wiring??
- Bad cam sensor ???
- FASS pump to replace mechanical LP.
- nozzles v.s. injectors
- Resetting odometer in 2000 cummins
- help no power to gauge cluster
- boost questions
- New cummins owner
- tps
- No power cummins!!!
- tires
- Oil Pan Gasket Leaking
- no left brakes good turn signals and right brakes
- turbo help
- Front End Overhaul, parts list review please.
- 99 cummins no power under throttle! HELP!
- Gauges
- Terrible oil leak!!
- Need help on upgrade
- Water pump upgrade?
- Weird lift pump problem - HELP!!
- Fan clutch delete
- Truck just dies after 2hr trip then starts back up next morning
- PCM help
- 99 wts light problems
- Thinking of putting these on my truck thoughts?
- Electrical problem
- Mounting custom bumpers
- brake squeaking help.
- Reman VP44 and P1688 code
- new injector nozzles now runs horrible
- exhaust question
- Trans Problems!!
- crossmember under oil pan ?
- 2001 Cummins Trans Issues
- 2000 dodge 2500 w/cummins cuts out
- fuel in the oil
