PDA
View Full Version : 24 Valve 2nd Gen Dodge Cummins 98.5-02
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 [26] 27 28
  1. A/C Problems
  2. my 2001
  3. Restoration Bomb
  4. transfer case leaky?
  5. Help, Ball Joints...
  6. Question about Shocks...
  7. 18 psi
  8. Knows its got to be easy fix
  9. sweet gauges
  10. 47re Trans mount torque spec help...
  11. gauges
  12. TC Lockup...Not working...
  13. Truck Storage
  14. Cleaning Injectors
  15. Boost Leak
  16. transfer case issue
  17. transfer case problem
  18. Injector and head gasket Q's
  19. good bang for the buck transmission upgrades?
  20. Got an idea
  21. EGT ?'s
  22. what happens if you run a truck with a sensor out
  23. Removing front shocks?
  24. 4 wheel ABS
  25. Too many miles?
  26. cam position sensor??
  27. My Intake gasket
  28. air. fuel or what?
  29. Fuel Pressure
  30. Too much fuel for stock injectors!
  31. A big thanks to you folks
  32. 1/2 ton fuel tank
  33. fuel pump problems
  34. fuel pump
  35. 2001 dodge 24 valve fuel delivery problem
  36. turbo upgrade
  37. 24V Engine build advice
  38. Need advice
  39. Fuel Pressure Issues
  40. Stock truck Q's?
  41. Boost at an idle ?
  42. P0720, speed sensor location?
  43. vibration at low speed
  44. 03-07 Cab Lights
  45. Senders and adapters for gauges
  46. Warning Light Flashes
  47. up for trade bullydog outlook with PE and hypertech
  48. emu from bocsh motorsport
  49. crank case vent canister removal
  50. heater controls..shot?
  51. How do you tell if your shocks are shot?
  52. Time for new ball joints again!!Brand recommendation?
  53. Problem?
  54. Hard Start?
  55. ECM removal 02 Dodge 3500, 5.9
  56. tranny swap
  57. who knows what this code is?
  58. Need Help.. turbo problem
  59. turbo uh oh
  60. Killer Dowel Pin
  61. best combo for the best #s
  62. Problems with 01
  63. 2 Gen Problems?
  64. TRANSFERCASE
  65. Reverse Lights Problem!
  66. transmison line pressure ?
  67. Injection Pump Banjo??
  68. Previous Owner Plugged Wastegate Hose W/ A Scew?!?!?
  69. Blown head gasket???
  70. new injectors
  71. 2000 5.9
  72. Im thinking head studs
  73. Trans is hunting gears.
  74. steering gear on an 01
  75. Remanufactured ECM
  76. trucks starts then stalls
  77. Goodbye Edge
  78. looking for diesel mechanic in north alabama
  79. Mileage woes
  80. IAT Sensor Before and After
  81. What is the carrying capacity of my truck
  82. turbo question...
  83. Cummins said no cold start feature ?
  84. no warm air
  85. Quadzilla Adrenaline
  86. Going amsoil?
  87. where to find blowby bottle?
  88. Clutch slippin or what?
  89. Manual Trans Filter
  90. will this work good with my mods???
  91. full four door 2nd gen???
  92. good ATF
  93. Charging problem?
  94. DTC question
  95. loose connector in engine bay
  96. fog lights
  97. New airdog II 165
  98. Fuel milage in the crapper
  99. Cruise Control no worky..
  100. what do you guys think?????
  101. FOG LIGHT CIRCUIT
  102. Starter Solenoid Fuse Blowing
  103. more fuel
  104. will this work on my truck?
  105. Water pump woes
  106. power door lock relay location?
  107. fuel problem
  108. New apps and still not right
  109. P1693 codes (SOLO)
  110. Caliper Blew Out
  111. cutout
  112. common rail pump swap w/ vp44
  113. Steering Gear Box
  114. 24v kdp
  115. transmission generator/pto
  116. 24V Injector Problem?? HELP!!!
  117. Breather bottle relocation
  118. seatbelt
  119. stock 98.5-02 leafs
  120. help
  121. egt's
  122. Silencer Ring????
  123. tire size
  124. Dissection of motor
  125. vp44 Problem??
  126. ramdon high idle???
  127. Towing mirrors
  128. VP44 or What
  129. Edge or VP
  130. 3cyl idle?
  131. check engine light
  132. hot rotor
  133. general tune up
  134. Vp44 Pump woes ?
  135. new vp44 lift pump gauge
  136. Lock up question
  137. tranmission problem!!!
  138. spray on bed liners
  139. Lift pump running while cranking, mine wasnt
  140. Driveshaft carrier bearing,, suspected of 70+ mph vibe
  141. looks or power?
  142. Fuel tank
  143. Hood Spring
  144. Towing My Truck
  145. FLOW CHARTS?
  146. pressure boost sensor
  147. transmission control solenoid
  148. Boost elbow delete.
  149. Stock turbo
  150. Code P1687
  151. fuel lope?
  152. Driver's Side Seat... Replacement?
  153. Speedo not working
  154. Sad Story
  155. new VP
  156. high pitch squeal
  157. mecanical fuel pressure gauge isolater question
  158. turbo
  159. in need of a hx35
  160. what turbos will work of stock trucks
  161. vp 44 question
  162. 4wd issue
  163. cool stuff about our truck
  164. ITS ALIVE!!!!!!!!
  165. problem with fog lights
  166. dieing VP-44
  167. Is it worth is???
  168. big troubles
  169. Cluster and overhead console problem
  170. HELP! Want to get the best for my buck....
  171. i think its a wiring prob..
  172. please help vp44 !!???
  173. cb radio mounts
  174. What tranny will work in my 98.5 ?????
  175. TRAGIC accident
  176. fuel pressure gauge???
  177. tried everything Vp is gone RIP!!!
  178. No reverse lights..well sometimes
  179. thanks
  180. What Power adder for an '02. Prices also ASAP
  181. U-joint
  182. pitman arm stuck??
  183. Power Steering Going?
  184. cab lights
  185. vp44
  186. lowering a 1999 4x4
  187. PO253 & TRUCK WONT START
  188. Rear end problem and tranny issues!!
  189. well e big green is down again.
  190. runnin lights
  191. running a powerstroke?
  192. 99 To 02 BLock Change
  193. Transmission identification??
  194. 24v questions
  195. p pump swap
  196. big programer starting problems??
  197. Truck has trouble starting
  198. Turbo pressure
  199. 47re swap
  200. Need Fuel canister Cap ASAP!!
  201. super chip?
  202. 5 speed wont go into reverse or 5th
  203. Fuel Pressure issues
  204. no smoke
  205. How much problems?
  206. BIGED Broke my truck
  207. help truck won't start
  208. new 44
  209. Overhead Map Light
  210. smoke switch
  211. Tranny Swap !!!!!
  212. Power Steering Pump?
  213. AAPS or VP44
  214. squeek
  215. Fuel pressure jumps!!
  216. He351 Turbo in 02
  217. vp problems
  218. Helpful hint when buying parts
  219. Torque converter vibration fix?
  220. detroit diesel turbo
  221. oil leaking from transmission
  222. fuel pressure
  223. truck stalls?
  224. Dodge DTC code P3232
  225. Cummins Surging??
  226. hx or hy
  227. Edge box
  228. Input Shaft
  229. ball joints. any tips..
  230. what do you guys think?
  231. Smoke switch?
  232. Fuel pressure with adrenline???
  233. Injector connector tubes
  234. Newbe here i have a few questions??
  235. super chips
  236. Vacuum Line Size?
  237. hr vp44
  238. Nitrous v.s Propane
  239. where to go what to do
  240. Dana 80 Rear ??
  241. tranny ???????
  242. Rotors???
  243. Boost Elbow
  244. 2 stroke oil?
  245. .093 Lines/Tubes
  246. has anyone ever tried this???
  247. CTD won't start
  248. IAT Sensor
  249. Wheel Spacers/Adapters
  250. Tach Issues
