PDA
View Full Version : 24 Valve 2nd Gen Dodge Cummins 98.5-02
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 [28]
  1. Silverline T409 Turbo Back Exhaust Installed (PICS)
  2. Now I Got Some Codes?
  3. Return Fuel Line Leak ?
  4. 53 Block
  5. At High Altitude My Truck Has No Power And Blows Blue Smoke
  6. Fuel Mileage
  7. Sensor Help
  8. 4" Exhaust
  9. Whine From Rear Axle
  10. Input Shafts
  11. 5 Or 6 Speed
  12. Auto Trans Help
  13. Running Too Cold?
  14. Went To The Aid Of A Fellow Bomber
  15. Decal
  16. White Smoke
  17. Need Help
  18. TPS Error Code P0122
  19. It Will Live!!!
  20. Start-Quit-Run
  21. P0605?
  22. Fuel Gauge
  23. Brake Parts Needed!
  24. Leaking Fuel From Injector Line
  25. Tire Sizes
  26. Diesel Fuel Tank Fittings
  27. Hate To Do It But Have To
  28. Need Specs On Rear Leaf Springs
  29. Haha So Who Says You Can't Smoke With Bio Diesel
  30. VP44 Replacement.
  31. Loosing Coolant, And Can't Find It.
  32. Transmission
  33. How To Change Door Handles
  34. Track Locator - Bar For Front Axle
  35. New Tires Have Dents In Sidewalls
  36. New Guy With Fuel Questions
  37. Driver's Side Water Leak
  38. Lookin For Parts
  39. Help Help Help
  40. Fuel Pump
  41. 224,000 Mile Purchase Help?
  42. Back Window
  43. Will It Fit?
  44. Calibrating The Speedometer
  45. Injector Question
  46. New Truck
  47. Headgasket Let Go.... Pics
  48. Question About Grid Heater Bolt
  49. O2 Sensor...
  50. If You Have Steering Problems
  51. Boost - How Much
  52. Sputtering Problem?!
  53. Dipstick Blow By
  54. Tranny Swap
  55. Map Sensor Going Bad?
  56. Sweet Car
  57. 98 24valve Dodge No Start.
  58. Ignition Problems
  59. Stupid Key Fob
  60. Trans
  61. "53" Block Information
  62. Anybody Beat 110mph Yet?
  63. Fog Light Questions?
  64. Lift Pump Fuel Pump
  65. Major Tranny Probs, Long Story
  66. VP 44 Help
  67. Went To Dealer Today.
  68. Got Hooked Up!
  69. ECM
  70. Rear End ???'s
  71. Code P0500
  72. How To Pull Codes
  73. Any Real Reliability Issues With The 24v
  74. I Need Code Help! I'm Stumped.
  75. Fuel Pressure ?
  76. My First Dodge Cummins
  77. Code Scanner
  78. KDP Question
  79. Limited Work During Warm Up??
  80. Transmission Leak Probem
  81. Only One Heated Seat Working
  82. Dana 80 Trac-Lok Rebuild Questions
  83. Rear Wheel Lock Up Fix
  84. INJECTORS
  85. Aux. Pump Setup Or OEM Bypass???
  86. Problem Truck
  87. Anybody Know Sizes On The Battery Cables
  88. Cracked Dash
  89. I Need New Brake Pads ASAP...What To Get?
  90. Cigeratte Lighter Dont Work
  91. Lights On My Truck
  92. Fuel Pump PSI
  93. 650hp
  94. Suspension Specs
  95. Hesitation When Cold
  96. Can't See At Night
  97. Crossover Tube O-Rings...Where In The Heck Can I FIND Some
  98. Extended Idle Times
  99. New #'s
  100. Automatic Door Lock
  101. Kick Down Cable
  102. High Idle
  103. 7.05 Diesel Only - Monster VP44
  104. Manual Transmission Filter
  105. Need Opinion On Flashers Problem
  106. High Idle
  107. Ground The Block Heater?
  108. Electric Fan??
  109. Vac/Power Steering Pump Help
  110. Just For A Little Fun
  111. More Headaches From The VP Truck
  112. What Does A Machine Shop Charge To Machine A Head?
  113. ? On TST And XZT.
  114. Need New VP
  115. My Project
  116. Hunting 1st-2nd 2nd-1st
  117. Engine Idles Itself Up While Letting Out The Clutch
  118. 2002 Cummins
  119. Code P0602
  120. 01 Ram Owners Manual
  121. How Many VP44's
  122. My 01 Is Wacked Out
  123. Funny Idle
  124. 47RE Not Shifting Out Of First.................
  125. Crazy Scare Yesturday
  126. Which Turbo(s) Are You Using?
  127. Intermitten Fuel PSI Loss
  128. Just my luck
  129. VP44 DEATH Who make the best replacement
  130. vp44 bracket broke / power steering pump removal
  131. factory exhaust repair. Size info needed
  132. wipers got a mind of there own.
  133. delima
  134. clunking
  135. Which Input Shaft Is In My 6 Speed?
  136. lost front brakes
  137. 5 Speed/6 Speed Ratio Comparison
  138. 2002 Cummins 24 Valve Idle
  139. tranny giving up?
  140. Well i got it today!!!!!!!!!!!
  141. Oil Pressure Problems, Or Not
  142. ID transfer case
  143. cruise control not working
  144. Stock Turbo Wastegate Question
  145. Parking Brake Light
  146. Got the new injection pump!!
  147. Auto to manual conversion
  148. Started Conversion
  149. wont run in reverse
  150. Removed Items
  151. 99 24v wont start...electrical?
  152. Will a valve body from an 02 work in a 99
  153. HELP! Dead VP?
  154. custom gauge pod i made
  155. link to obd2 codes
  156. idle adjustment for dummies?
  157. Need Some Detective Help
  158. trouble code
  159. Oil Leak Help
  160. It's Broke AGAIN
  161. 24V Guys File In.
  162. #53 Blocks
  163. Apps?
  164. Truck anyone?
  165. ABS questions
  166. First thread for the 24V's
