PDA
View Full Version : 24 Valve 2nd Gen Dodge Cummins 98.5-02
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28
  1. 02 Extended cab, auto 4x4 for sale
  2. 2001 Cummins Idle Sputter Since FASS Install
  3. Need some advice PLEASE
  4. Swapping cabs
  5. Turbo Issues
  6. 245 HP auto
  7. Newbie here
  8. Refurbished tuners
  9. Mind blown
  10. 2001 5.9
  11. spraying oil out near Power steering pump
  12. compression test
  13. Lift questions
  14. Good WeekEnd
  15. Truck studders only at 1.5 RPM???
  16. chiping My 2001 5.9 227.+miles
  17. Expecting HP
  18. NV4500 Shifting without Clutch
  19. trans fluid change questions
  20. 98.5 cummins 64mm dtech?
  21. Truck Died Today
  22. Lift pump question
  23. 150hp nozzles
  24. turning over won't start, sometimes...
  25. Hard Start w/ Horrible lope, dead throttle
  26. Front end fix
  27. Ball Joints
  28. Rusted oil dipstick tube broke
  29. Governor override
  30. 02 47RE build
  31. Fuel Issues
  32. Parting out 2001 dodge
  33. 4wd light is on and can't go over 35mph!!
  34. Tuning
  35. ECM problems?? Please help:( be ready to read lol
  36. Just installed new turbo
  37. Need help identifying the sensor in PIC
  38. Speedo/abs/no bus problems
  39. Need info
  40. Bad boost fooler?
  41. Fuel pressure
  42. Manual hubs
  43. ac only works out of defroster outlet.
  44. 4wd Shifter adjustment
  45. No Oil Pressure
  46. wrecked 99 no start now
  47. Big Electrical Issues.
  48. fuel knock?
  49. 1999 3500 AC Issues
  50. Ebay turbo vs bd performance
  51. Identify transmission in my 99
  52. Please help with DTCs!!
  53. 2000 dodge won't start lift pump comes on when I turn the key but won't start
  54. 99 dodge Cummins problems needs some help
  55. Vancouver Wa area
  56. Bad turbo bearing
  57. Auto to manual
  58. VP 44 INJECTION PUMP
  59. Looking for a thread
  60. Exhaust temp
  61. Towing
  62. 99 cummins replaced locked up ATS TC still stalking in drive gears
  63. Starts chugging then quits
  64. 01 Cummins turbo compressor wheel
  65. Cummins grille emblem
  66. oil leak
  67. Help help help.someone please
  68. Trucks stuck. In high gear.
  69. one headlight
  70. Map sensor issue
  71. crank positioning sensor
  72. Pressure plate for 01 6spd????
  73. lost a wheel
  74. 1999 dodge cummins 24 valve hard to start when warm
  75. P0237 plus crazy gauge readings
  76. What is the best Tps/ apps for 98.5 24v
  77. 24v vp-44 help with fixing circuit board
  78. Blowing blue smoke like a boss.
  79. 1999 2500 rear differential swap to 2002 2500 gasser differential
  80. Fan blade came apart can't find part
  81. Time to start fixing the truck up. Suggestions?
  82. Awkward automatic
  83. stock suspension replacement
  84. Witch gears for my 4:10 carrier
  85. New to 24 valves. Needing advice
  86. 99 cummins Holley blue pump
  87. PCM issues after 2-1/2 hrs of driving
  88. Power steering issue
  89. Custom intake
  90. EDGE CT TUNER GOOD????
  91. Snow performance power max vs banks straight shot
  92. oil gauge, engine temp and tach dont work suddenly
  93. make my auto trans stronger
  94. new airdog losing pressure HELP
  95. Terrible squealing/grinding sound
  96. Fass pump high pressure
  97. Dana 60 Service Manual
  98. Changing Gauge Colors
  99. HELP 01 cummins 5 speed cutting out at 55mph
  100. 99 dodge 2500
  101. Is stacking a good idea
  102. oil in cooliant but no cooliant in oil?
  103. New Owner 2001 Cummins
  104. quadzilla adrenaline p2
  105. New member in deep thought..
  106. nv5600 making noise during deceleration in gear
  107. turbo
  108. dually to single wheel
  109. new to cummins
  110. what horse power am I looking at?
  111. Brakes are super touchy, lock up instead of pulse
  112. new to me owner-98.5 cummins
  113. Need help please tranny problems
  114. general info
  115. help
  116. fuel return line pressure?
  117. I need help
  118. I nedd help
  119. Truck wont start in Park
  120. fuel return line leaking
  121. advice on clutch setup
  122. 2001 24V fuel issues?
  123. More Fuel System Problems
  124. 2001 3500 cranks and no start
  125. 01 dodge ram 2500 4x4 24 valve Cummins 5-spd
  126. 7" downpipe back exhaust?
  127. engine out of truck
  128. NEED HELP
  129. White smoke?!? Diagnosis?
  130. Low oil on dipstick
  131. no idea whats wrong fass issues
  132. New to me
  133. 47rh rebuild need help
  134. transfer case poping into neutral
  135. Had enough of the straight pipe.
  136. High Readings on Oil Pressure
  137. Relocated my lift pump. Have some questions...
  138. 2001 cummins no start
  139. ISO used smarty
  140. not sure whats going on 24v 5.9
  141. Truck dies first time throttle is applied..
  142. New battery crank no start!
  143. 99 cummins drops to idle while driving. Help
  144. howdy folks
  145. Drive Pressure
  146. RPMs jumping while A/C on
  147. Alignment issues
  148. Clutch recomendations-economical
  149. 2wd suspension issue
  150. Brake pedal goes to floor after tight turns
  151. Compound turbo options
  152. where do i start
  153. Bubbling sound by the heater core
  154. When od is off...
  155. turbo ?
  156. Mr. Wheel deal New wheels
  157. 2001 24v issues
  158. grinding tappets
  159. HX50
  160. brake problems proportioning valve
  161. 01 Heated seats not working
  162. power steering isues
  163. vacuum issues
  164. excessive oil from breather
  165. No fourth gear.
  166. No fourth gear.
  167. VP44 and Vacuum pump removal at same time ok?
  168. Rough idle after 150 hp injector install
  169. Help! Truck shutters while shifting into overdrive!
  170. Miss at idle when warm
  171. 47RE shift problems
  172. not a fan of tuners looking for some options
  173. VP44+Rag+Vice-Grips??
  174. Nv4500 question. Newbie
  175. Edge EZ what all do i need
  176. Best Programmer For Me
  177. it's about time to replace the steering components
  178. FASS...nothing but problems
  179. looking for other mods
  180. Edge comp box up for grabs...
  181. HELP HELP HELP HELP HELP
  182. ECM or injection pump failure?
  183. Nv4500 won't go in 5th or reverse
  184. Turbo for racing??
  185. Stuck in 2nd gear wont shift!!
  186. Fluttering noise under load.
  187. cummins rough idle
  188. throttle position sensor P0122
  189. ECM or wiring faults?
  190. fuel pressure light
  191. Block heater works when it wants to
  192. Rebuilding the 47re
  193. 99 24v Engine Surge Issues
  194. 47rh lockup/od
  195. Weeping shift linkage
  196. Transmission I.D
  197. pressure ?
  198. lock ?
  199. Sucking air
  200. new clutch
  201. been a long time ,,got some ???
  202. engine vapor in engine compartment
  203. new torque converter issues
  204. bad credit killing my cummins dreams :(
  205. Wipers don't work when cold
  206. 99 Cummins no start after fuel filter change.
  207. Ready for some more power!
  208. introduction and a few questions
  209. 2001 losing power with small load
  210. 2nd gen cummins bodylift who's done it? Help
  211. gear ratio??
  212. Boost reading on original EDGE juice attitude quit reading
  213. 6 speed parts? 2001 dodge 5.9
  214. 01 Cummins hard start issue
  215. New audio head unit.
  216. new to me 99 5speed
  217. 1999 Dodge Cummins Wake up Call
  218. Edge cts problems
  219. Air wont bleed and leaking return line
  220. bigtruck4
  221. So here is ,my build...is MPG where it should be?
  222. looking for some advice
  223. DEAD PEDAL w/edge comp box
  224. cummins cranks but wont start
  225. Lift pump upgrade question?
  226. 1999 Cummins. No speedometer or odometer
  227. Fuel pressure question
  228. Edge comp installation
  229. will a crazy carls p pump a.p.p.s. kit work on a 12 valve in a 99 ram
  230. Unexplained dinging
  231. injector quality ???
  232. p1488, p0236, p0522, p0122, p1693
  233. 47RE Build Questions
  234. putting a 12 valve in a 99 - transmission problems?
  235. What is wrong with my 2001 Dodge Ram 2500?
  236. 1999 Dodge/Cummins
  237. rust noone likes it
  238. Cummins Engine Swap no start - HELP Needed
  239. 01 Dodge 24v P7100
  240. 2nd Gen to 3rd Gen Trac Bar Conversion
  241. 1998.5-2002 cummins automatic ???
  242. 1998.5-2002 cummins automatic ???
  243. 2001 5.9 Cummins Rough running
  244. 911 help in MAINE. I 95 EXIT 7 ISH
  245. out of my comfort zone (again)
  246. 2001 dodge cummins no start
  247. 1999- 5.9L Air Dog Fuel Unit
  248. wait to start light will not go off..No starting
  249. edge 30300 vs. 30301 conversion?
  250. 4x4 problems
