- ppump
- Chugging/surging on freeway with hard throttle after head gasket install...?
- 01 cummins gauge cluster
- loss of power
- Where to buy rebuilt calipers?
- Lock N Stitch
- new problem to me?
- hy35
- 47RE problem, hanging in first
- Cold fuel plugging fuel filter...
- Axle swap
- Clutch problems
- code crazy!
- Injector help
- Fuel Filter Leaking
- scanner code 1689
- vp44 return line
- Motor Oil
- Fuel Leak
- The Official, Unofficial, My "53" Block Cracked (Or Not) Thread.
- fuel economy
- 02 or 05 wrecked truck.
- which thermostat?
- 53 block?
- Opinions on a 2002 dodge cummins for sale.
- another 53 block question
- No Fuel Pressure
- Color Matched stacks?
- Coil Spring Question please help
- 99 Valve Seal Busting
- exaust temp
- Turn signals
- Gauge Install
- new battery cables or relocate?
- Swap: 6spd in 5spd out?
- got a ? about 98 dodge
- blowby or valve stem seals?
- power steering/brakes
- exhaust brake
- 98.5 Ram 3500 no-start
- Sputter/buck
- chattering clutch
- air dog connect?
- heater noise
- thoughts??
- exhaust system question
- How much would you pay?
- Help Please
- seat belt wont unlock
- input needed
- transmission line pressure
- blue haze
- Turns Over But No Start
- apps???
- STARTS RIGHT UP, DIES, THEN STARTS HARD
- Bouncing at 50 MPH...
- steering box leak
- 5th gear issue
- Rocker Arms and Pivots Scored/Scratched Help??
- What would you pay for it?
- Upgraded Ball Joints are they out there
- Trans Crazy
- Replacing the door
- No start
- Looking for parts
- 1998.5 advice on vp44
- Window Pillar Sticker?
- Shocks?
- Potential 2001 Dodge 2500 2wd owner.
- rolled over running-stayed running-now no start
- 01 cummins throws white smoke
- lots of add ons see any prob
- anyone in Roy, UT
- what would you pay?
- High Idle 3cyl Cutout High Idle
- 1998.5 dodge no top end power while towing
- What do you all think?
- 4wd light?
- Diesel fuel in antifreeze....?
- fuel leak
- speed gov turned off
- porting?
- 98.5 has gone full dead pedal
- 99 dodge cummins hard start when warm
- truck dies while driving down the road
- 01 ball joints
- nv5600 swap
- front brake pad uneven wear?
- stupid dodge sprinter belt routing!!!???
- 99 cummins prob new to this site but help me if u can
- 2000 cummins
- trans problem need help
- 1999 Dodge 24v
- Batteries for the 02
- Need Help with a few Trouble Codes
- Shattered T-Case
- Hardware to Improve Fuel Economy??
- backup light on
- tail lights wont turn off
- rebuild 5600
- Rear Sway Bar
- Fuel pressure gauge bad???
- Rearend leaking
- codes
- Lift pump
- 4wheel drive popping out! Please help!
- Need Headlights Changed
- oil pressure
- 1998.5 Cummins 24v problems HELP
- trans problem
- HEAD HELP!!
- two piece exhaust manifold leaking at joint
- transfer case ?
- Help!!! Leak in the transfer case!!! (I think)
- New clutch slipping
- Throwin codes GALORE
- help with long start
- possible boost leak? or..?
- I.D. this lift pump
- dodge_girl
- Shaved Door Handles
- where to put bleeder valve?
- bad day today
- fuel pump signal
- Oil and oil filters
- posi or unlimited slip ??
- "no Bus" code
- HELP PLEASE!
- Show off your 2nd gens!
- trans slippin really bad
- trans burp!
- Buzzing sound under hood 99 dodge
- Help truck died and wont start
- new vp still ?s
- wont start,,2002 cummins
- 1688 vp44
- gettin a new vp
- 99 dodge Water temp ?
- '99 wont start
- gear oil?
- oh where to start
- how to wire in lift pump
- oil problem HELP!!!!
- p1689
- Fuel press loss
- check engine light
- Dealer said no high idle.
- DRAGGING/ LOCKED UP FRONT BRAKES
- VP44 help!
- New batteries for 98 cummins?
- Have dash lights coming on and off...
- help bad turbo?
- 4 wheel drive
- Single or dual steering stabilizer
- FUEL PROBLEM...
- blow by...:/
- Coolant Leak During High Idle
- VP44 safe fuel pump pressures?
- Heat senor leak on Fuel filter.
- Injection Pump?
- P 7100 question
- 2001 dodge won't start
- valve adjust and missing problems
- turbo causing leaks?
- T-Case Help
- FIRST CUMMINS AND HATE IT
- Smarty problems
- clutch
- gear question
- Oil leaks ???
- new truck need advise
- hd t-case
- should i trade for a 99 cummins
- Leaky injector, or lines?
- 4 wheel drive disconnect
- 5x18 injectors
- power
- ADVICE PLEASE:Replacing U-joints on front driveline...
- Head gasket or oil cooler?
- fuel pump is shot!!:(
- 47re lock up fix
- 1999 24v question.
- dead pedal
- ECM thoughts
- cruise control
- Transmission hoses
- Transfer Case
- Clutch not disengaging?
- Loss of power
- The Ol Headliner
- axle ratio question
- O-Rings, Pictures, Myths, Facts and Info!
- Still won't start
- Losing prime. What else is there to check?
- Truck stumbling Need Help!!!
- Turbo Trouble
- throttle postion sensor
- Compression Specs for 24 valve
- what gas mileage am i getting?
- Throttle goes dead.
- clutch questions
- HY35W to HX35 Question
- New Bed Needed for '02 Ram 2500 4x4
- lift pump
- Lope after wide open
- Messed up fuel return line
- muffler poll
- No brakes!
- good hot wire
- Transfer pump stays on/guage issues
- fuel leak
- 2wd loose steering.
- Need Help !!!
- cummins oil pressure?
- All good things.
- i need some enlightenment
- 99 cummins clutch install gone wrong
- Alternator or computer?
- fuel heater leak
- transfer Case, 4x4 Not Working
- Poor fuel mileage?
- is my vp44 on its way out?
- trailer running lights
- VP44 or APPS
- speedos off
- rebuild the old or in with a new.
- CRUISE CANT GET IT FIXED
- hard starting issues
- It runs slow from cold starts ??
- bad fuse??
- Worth it?
- Fuel level sender
- transmission
- Truck
- Heater Short
- hesitating 2002
- Dropping the tank
- injector pump
- mirror questions...
- Single to Dual??
- converting to power windows and locks
- cruise control help 2001 2500 p-pumped
- just for poops and giggles.
- scary smoke?
- Brake pedal slow coming up
- weird problem truck will idle all daylong
- Friend has a 24valve... what can i mod for him ?
- left turn signal and cruise control short??
- valve lash
- Gasoline to Diesel filler neck
