PDA
View Full Version : 24 Valve 2nd Gen Dodge Cummins 98.5-02
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22] 23 24 25 26 27 28
  1. running funny
  2. All The Symptoms Of A Head Gasket, But Its Not
  3. anyone in albuquerque?
  4. Restriction, Loading up ?
  5. CAD Axle
  6. Oil pressure
  7. help need help
  8. Having trans issues. Hoping you guys can help
  9. 99 Cummins Computer Problems PLEASE HELP
  10. If all else fails... check the EASY stuff!!
  11. door fasteners
  12. speaker problem
  13. gotta love owning a dodge
  14. Transmission Temperature & Overdrive
  15. rust
  16. Fuel Gauge Help
  17. Turbo oil leak
  18. Hx35 wheels Biggest/Smallest/Best
  19. Factory Oil Gauge
  20. wait to start light
  21. Missfires from time to time?
  22. Wait to Start Light
  23. 01 24v runs hot and cuts out
  24. turbo surge??
  25. 00 Cummins Crank Sensor
  26. WTB a tip
  27. wastegate actuator
  28. fuel and air mods??
  29. Curious about Dodge
  30. electrical issues bad
  31. vp44 pump
  32. TC lockup with cruise control
  33. Electic Problems
  34. fuel gauge 98 dodge ram 2500
  35. Ye olde oil vent bottle
  36. need some help with a truck not starting
  37. exhaust band clamp
  38. ECM problem?
  39. 99 dodge sometimes wont start
  40. Hard Starting When Warm
  41. KDP Help
  42. Low boost code
  43. Little miss?
  44. code 1690?
  45. helpp tranny is messed up
  46. fuel tank
  47. 98.5 dodge ram 2500 wiring diagram
  48. Little Miss at idle?
  49. 24v Things to look for and fix?
  50. cant avoid workin on the pickup
  51. Wait to start light problems?
  52. 99 Dead Clutch Pedal and fluid is all leaked out, Far from home. What to do?
  53. Steering.....
  54. Just changed the a/c evaporator and what a job that was!!!
  55. nv5600 no 6th
  56. Front axle specs and possible ball joint solution
  57. strange noise
  58. BOOST
  59. Steering problems
  60. looking for 2wd hubs and projector lights
  61. well vp44 is done
  62. cracked block
  63. jchavis
  64. VP getting air in it?
  65. The ol Velcro - THROW STUFF TIL IT STICKS! HELP!
  66. weird whine
  67. Loose control arm bushings?
  68. bad oil leak
  69. Muffler
  70. A/c Fan control...
  71. starting question
  72. Short box flat bed?!
  73. 1/4 tank issue
  74. transmisson swap
  75. Fuel Gauge
  76. strange noise... need help
  77. replacing a dash
  78. Dodge 2001 cummins
  79. transmission question
  80. VP 44 pump life
  81. vp44
  82. Turbo questions
  83. Vacuum Pump Woes
  84. 2001 6 speed
  85. Which clutch?
  86. do i need a new vp???
  87. Tanny Temp
  88. Shrader valve on the fuel in fitting
  89. Finally Fixed
  90. truck wont start after fuel filter change?
  91. 2001 cummins dead pedal
  92. Replaced VP got codes
  93. Banjo bolt for the VP
  94. no wait to start light?
  95. Lift Pump Electrical Circuit Issues
  96. VP44 install videos?
  97. VP replacement, I DID IT!!!
  98. couple questions about and 02
  99. Cruise control question
  100. More ???'s on VP install
  101. Cruise control as easy as...
  102. VP install today
  103. Sputtering/Stalling above idle
  104. Inside the VP44 - Cummins VP44 Injection Pump Internals
  105. Dodge Cummins Starter Contacts Replacement Video
  106. p0216
  107. Things I need for VP install
  108. Cruise Control not Working? A/C Wont switch off of defrost vents? heres the fix
  109. What year tranny
  110. Transmission Coolers
  111. auto or std
  112. timing trouble?
  113. Cam sensor
  114. About Tow Mirrows
  115. cruise quit
  116. Heated seats
  117. Torque Converter??
  118. tire balance causing death wobble?
  119. Front Differential Capacity
  120. Losing Oil
  121. where to get a good electrical noise filter from?
  122. no start or crank?
  123. New transmission down again!!! 3rd time!
  124. Can't win for losing....
  125. Raptor mounting on frame
  126. auto trans first gear and surge at 40 mph
  127. Check Gauges?
  128. Engine Codes
  129. Blue Chip Diesel
  130. cummins 53 block
  131. 98 dodge cummins ?
  132. 1998.5 dodge cab leak?
  133. Pillar pod
  134. clutch switch
  135. Dodge V-10 not shifting out of first
  136. Injection pump
  137. Nv4500 input shaft install walkthrough
  138. nv5600 shift rail pics
  139. No power sometimes
  140. diesel in oil
  141. failure codes for a vp 44 injection pump
  142. need help quickly
  143. oil in turbo ?
  144. a/c, heater fan
  145. sputtering
  146. Transmission is slipping. What to do now?
  147. somethins still wrong
  148. rear parking brakes on 2002 dodge dually
  149. power steering pump
  150. 53 BLOCK- Cracked block.
  151. catalytic converter removal
  152. Breather Bottle Delete
  153. alternator, voltage regulator or the pcm
  154. Quick Underhood Clean Up
  155. 24V Cummins knowledge
  156. wont start possible electric problems
  157. 02 PROBLEMS HELP PLZ
  158. 2002 Cummins Brake Rotor FAIL
  159. heavy white smoke.........
  160. 99 cummins, no codes, no power
  161. white smoke
  162. Weird transmission
  163. Bubbles in trans fluid?
  164. New torque converter
  165. slite miss
  166. Still cant figure this out
  167. In tank Pump?
  168. 271 input shaft swap and sye
  169. Where to get Transmission Rebuild Parts
  170. Voltage meter spike
  171. Overheating on the highway with normal EGT's
  172. Possible rear main seal problem
  173. damn junk air conditioner
  174. ABS light and brake lights
  175. Boost ?
  176. injection pump????
  177. front wheel bearings?
  178. overhead console
  179. Cooling problems????
  180. Best way to hook up a guage light
  181. Ignition On Power Source
  182. Vp44 Question?
  183. General question
  184. no bus
  185. Best Ball Joints?
  186. freon leak
  187. halfbreed
  188. Cummins Dead Pedal, Need Help!!
  189. Cracked Head!!
  190. STRANGE noise coming from.......front end????
  191. engine temp
  192. help
  193. 2 stroke oil
  194. New Diesel owner
  195. 24 valve cutting out, need help
  196. crank shaft position sensor
  197. steering gearbox
  198. slow truck
  199. No voltage
  200. fuel pressure
  201. 2001 cummins exhaust
  202. map sensor removal: can't get the socket on it
  203. turbo oil hose
  204. Pensacola Diesel VP44?
  205. Any Lawyers around here with some legal advice about a trans. builder?
  206. front diff oil ?
  207. trans problem
  208. My 99 wont start...
  209. 1999 cumins oil pressure
  210. New transmission broke again...
  211. truck died then wouldnt start
  212. Transmisssion fried again!!
  213. Finished Converting my Dually to a single wheel
  214. vp install
  215. Gooseneck hitch
  216. Whats wrong???
  217. Throws out of gear
  218. vp44 idle rpm question?
  219. 02 turbo
  220. I was just wondering
  221. Lift pump replacement
  222. Trac bar issues
  223. reving
  224. water temp guage problem
  225. ROD & MAINS
  226. turbo
  227. ***HELP PLEASE, I need a few random things fixed on my truck***
  228. truck is acting really messed up!!!
  229. 2001 cummins in a ford f650
  230. code 1690?
  231. Heater/ac smell
  232. flashing back to stock?
  233. VP or not???
  234. How to keep from getting P0238 code
  235. HP Numbers
  236. trans again
  237. Surging
  238. Manual to Auto swap
  239. info needed
  240. problem with check engine light?
  241. Need help
  242. heater ?'s
  243. Fuel leak / oil leak
  244. Keep breaking u joints
  245. trans. help!!!
  246. Engine Missing HELP!!!!!
  247. P-Pump parts
  248. fuel filter cap...
  249. tranny gave out? What do you think?
  250. stacking question
