- Another vp44 questions
- banks big head wastegate
- Lights
- Future problems
- Truck running rough/wont run
- Auto Trans - Truck in gear for warm up?
- computer issue???
- 47RE Torque Converter
- is it worth fixing?
- P1689 2001 24v????
- lift
- What's it worth?
- rpm surge all rpm range/no codes??
- cab and chassis rearend
- auto to manual swap
- Shifter
- New Member With Transmission Question
- Vacuum issues ? ? ?
- Valve Lash
- Good programmer for my truck
- Cooling system
- smarty ?'s for an 02
- motor oil big leak from exhaust pipe
- Fuel pressure gauge hook up
- Stack kit for 2001 cummins
- Truck does not go over about half throttle
- Truck does note go over about half throtttle
- My single wheel conversion
- still getting dead pedal
- fuel heater resolve found
- EGT's ?
- New starter and will not start... Need help
- After a LP hard start
- hardly have breaks, no pedal. HELP
- air intake
- Newbie, Smarty and Boost elbow query :/
- guage cluster
- Intercooler boots
- improving gas mileage
- testing fuel heater
- programming remote
- cummins edge comp box
- ideas on Traction bars
- Front driveshaft u-joint help
- Turbo boost psi
- early 24v cummins issues?
- door from 1500
- Fuel tank pick-up problem?
- fuel tank sender assembly?
- buying a new 2000 2500
- tranny thoughts/suggestions...
- surgin down the fwy???
- Fuel Tank Vent???
- power loss and turbo whine
- 47 re reverse band snapped time for a re-build
- Tach shutting off?
- Injector nozzels
- Sloppy 6 speed shifter.
- looking at a new rig to blowup.......
- brakes
- 2001 wont start after engine swap. throws p1690
- 01 cummins 47 re with no reverse?
- connecting tubes?
- throttle fluctuates up and down HELP PLEASE
- rims n tires....
- Lighting
- No gauges HELP
- raptor pump install
- oil pressure gauge dont work
- Water pump pulley fell off...
- 2000 Cummins Power surging
- VP44 gradually dying??
- 98.5 loosing power
- Where is the intake air temp sensor?
- Manual transmission fluid?
- Brake light wont go off.
- boost leak?
- not all there
- transmission swap???
- Lessons learned...When this is off you should also replace...
- Cold start hi idle issue w a 99
- Reverse Light Switch
- four wheel drive help
- gas to diesel swap
- Unsolved mysteries, what is this thing? and more
- fuel pressure gauge
- a little help here
- Turbo Problem?
- V10- cummins swap
- stock turbo output?
- oil/coolant leak
- Need help. 2nd gen Cummins. RPM's drop to 0
- What MPG's you guys running?
- 5th gear back off
- Grille Cover
- throttle cable snapped on way to work
- 01 2500 still not starting
- new guy here
- Inconsistent fuel pressure
- Brake Pedal Sensor?
- putting power/heated on truck w/o
- Turbo oil drain tube size??
- New cts installattion?
- fuel pressure gauge kit/diesel dawgs!!!
- I have 53 block!!!!!!!!!
- 1999 24 valve issues
- BD Rad system question
- OIL LEAK
- auto tranny about had it
- edge ez or edge juice
- Engine stalls when shifting to reverse.
- VP44 and H.O. question
- A post grab handle
- edge comp with smarty or edge juice with attitude?
- what mods to do first
- dead pedal..... still
- Time For A Heater Core
- Help with 99 clutch system!
- Need Help! 99 3500 Not Charging
- Highest horsepower VP44???
- P1687
- need help!!! questions on installing new cts edge programmer???
- Sport Bumper
- Best setting for mpg on edge
- 01 2500 not starting
- guage cluster
- Irradic Fuel Pressie
- Whos clutch do you prefer?
- What Turbo and Injectors
- 01 cummins 2wd transmission codes p0753 and p1763
- injection pump gone bad??? please help
- 24v boost fooler
- do i need this
- fuel gauge instalation
- cummins injector question?
- Hey everyone!!
- isspro fuel pressure guage
- 24V vs. CR oil dipstick
- Dually swap for single wheel??
- asd relay problems
- Alternator plug
- High Idle Mod
- 2000 Motors Have Camshaft or Crankshaft Sensor?
- 2002 rear end (dana 80)
- Wait to start light flashes
- truck cutting in and out
- Cold Start - Whining
- drill & tap egt
- chips give me a headache
- starting to get cold up here
- injection pump removal tool
- ideas for a new turbo
- powermax 3 cant get to cool down setting
- egt guage reads weird
- How do you know when you have the "Death Wobble?"
- South Bend clutch vs OEM replacement
- hard start and restart
- FASS FILTERS
- Need turbo help fast
- Happy new years everyone!!
- p0180 code
- clutch problem
- CRANK POSITION SENSOR
- RPM gauge drop then return
- synthetic or regular oil?
- cutting out?
- cheapest place to get a fass 150gph pump kit
- No Lift Pump Prime Cycle, No Wait To Start Light (at all), NO Codes! HELP?
- tranmission problem just had it built
- Vp44 codes... Need help quick
- steering parts
- 5.9 losing fuel prime???
- upgrade brakes 1999 dodge
- My truck wont turn over. Help please!
- cam
- Clutch master cylinder bleeding
- Vacuum Pump?????
- PCM for 01
- HELP...LOSING OIL AND NOT SURE WHERE :scare2:
- What injectors???
- Im back. Bunch of pics.
- bov?
- how hard will this be?
- banks big hoss / edge ez
- Serp belt question?
- New to site 99 cummins
- hp tq estimite
- 99 Cummins Autos HELP!!!
- Hate warning lights!
- injectors
- Engine Coolant Temp sensor?
- 1998.5 ext long bed build sweet!!
- Leo
- Engine temp gauge showing low temp?
- 4x4 not working
- bleeding off the slave cylinder
- white smoke
- Stock injector pump?
- transmission rebuild
- injectors first?
- tranny problems
- p0216!!
- engine not getting fuel
- Clutch master cylinder issue
- pto covers
- 01' dodge brake and 4x4 issuse
- leaking gearbox
- dodge ram diesel intake manifold relay
- 99 dodgeram diesel battey drain at fuse 12 i.o.d
- Truck dies in gear with no pedal
- Automatic trouble
- OEM Mirrors?
- Loosing pedal
- White Puff On Cold Start
- Blown head gasket?
- compressor housing
- something in trans bogging down engine?
- oil leak? 02 5.9L
- Camshaft sensor
- turbo oil lines & fittings
- hx35
- NV5600 Input shaft
- 02 surging and multiple codes
- Fuel Pump Relay
- 02 2500 rear door latch bolts
- Turbo and injectors next?
- got another comp question
- Doesn't seem right...?
- edge comp woes
- what do you guys think ?
- Defueling/ Stuttering at 20-25 PSI
- 04 drive line fitment
- p1682
- what size injectors to run??
- edge juice with attitude question?
- Battery replacement
- CPS location
- Gauge questions???
- I thunder my engine pulling too much
- Vibration in the floorboards on and off
- need help
- rules on idle?
- S300G
- 4x4 not workin...
- 2002 24v edge comp problems
- rough running skeeter fogger
- rattling noise
- injectors
- edge comp & smarty stack?
- Exhaust... Need help!
