PDA
View Full Version : 24 Valve 2nd Gen Dodge Cummins 98.5-02
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 [25] 26 27 28
  1. fuel pump
  2. valve body or torque converter???
  3. Vp44
  4. injection noise
  5. Time to winterize
  6. The raptor LP
  7. DOES ANY ONE
  8. Fitting size on 01 Fuel Filter assembly?
  9. need help
  10. what does fuel pressure need to be on vp44?
  11. 2002 ram idling problem
  12. exhaust brake
  13. head studs needed for quadzilla adrenaline w/ pulse? if not, than what?
  14. more questions
  15. head studs and waste gate tubo fooler needed with quadzilla adrenaline?
  16. dead miss and deal pedal... ive tried everything
  17. cracked manifold
  18. Bd or suncoast??
  19. Clicking in front end in 4X4...
  20. Any easy engine upgrades, tweaks, or swaps for a 98.5 24v?
  21. boost leak???
  22. quadzilla help
  23. Need stock control arms specs
  24. Just lookin for ideas
  25. valves
  26. What aftermarket radio head unit will fit?
  27. vp44 bracket
  28. 47re valve body ?????s'
  29. what mods needed for 4k?
  30. I NEED HELP PLEASE About this TURBO
  31. gear puller?
  32. Injectors
  33. need some info
  34. Airsep Kit for crank case breather spray worth it? any home made alternatives?
  35. New 99 ram owner needs some 911oil leak need help!
  36. fuel injector removal
  37. Doors keep unlocking!
  38. Transmission Ideas
  39. I cant figure it out
  40. help please
  41. new guy with a major problem
  42. 01 Dodge 3500 Auto Tranny Problems
  43. need an opinion
  44. How to find rearend ratio?
  45. steering stabilizer
  46. death wobble
  47. 01 ram 3500 heated seat
  48. fueling
  49. heater is not so hot
  50. LP Pressure
  51. Time to spend some money
  52. Problem with my over drive
  53. PPE Lift pump same as Edelbrock?
  54. got an airdog 150 had nothing but problems
  55. G56 in a 2nd. Gen.
  56. NV Manual Transmission Swap question
  57. Turbo Problems???
  58. New to the Diesel World
  59. 2001 with trans controller out
  60. Jet A/JP8 fuel use
  61. bleeding injectors
  62. broke something
  63. Changing gears Ratio.
  64. Stock valve springs
  65. 5 speed
  66. exhaust questions
  67. she runs a little funny, I think....
  68. Airdog 150 ?
  69. Shift kit
  70. I'm back! With a 24v question now...
  71. pop test injectors
  72. stuck in OD
  73. Dipricol Gauge
  74. funny feeling tranny
  75. injector line leak
  76. TQ Converter
  77. My first upgrade to my cummins
  78. trans question
  79. cab light leaks
  80. Lopping
  81. Been let down
  82. crank shaft position sensor
  83. lookin at an 01 2500 QC
  84. MPG question
  85. Need some help....Omaha, NE
  86. Wastegate Adjusting
  87. HOW MUCH HP A STOCK AUTO TRANY WILL HOLD
  88. Silencer Ring
  89. inctor conner tube ???
  90. Auto Transmission problem
  91. curious questions
  92. BEST PRICE ON VP44
  93. Three codes come up
  94. not shifting right....
  95. BHAF
  96. no brake lghts need help
  97. whats the best
  98. need to know info
  99. which way to hook gauges up?
  100. 2001 2500 Woes
  101. muffler vs straight
  102. 47re stuck in limp mode
  103. Hesitation problems got me puzzled
  104. Surges on highway, runs great under load
  105. 2001 Cummins Turbo Prob
  106. Surging Truck
  107. Exhaust manifold!
  108. stacking power
  109. h.o cummins
  110. trans not shifting out of 1st
  111. If you had the opportunity... Would you sell?
  112. wiring problem
  113. whats wrong???
  114. Transfer case pops out of gear
  115. P0216...But...
  116. Threads on Gear Shifter
  117. Quad cab door not opening!!
  118. apps troubles or something else?
  119. trans funny
  120. frozen hubs
  121. Whats it worth(i know another one of these threads)
  122. silencer ring
  123. What is wrong with my truck?
  124. Come and Gone Trouble Code... P0121 Ideas? Suggestions?
  125. power steering fluid all foamy
  126. hesitation @ 40mph
  127. Shuttering
  128. Broken NV4500 5th gear
  129. Intermittent Starting
  130. Dodge 3500 brakes shutter rear wheel hop
  131. 53 series block
  132. something wrong with my ac
  133. more power
  134. 2001 wont start
  135. advice on getting 02' diesel
  136. not running right
  137. transmission fluid etc
  138. Wiring Problem
  139. Long Cranking Before Starts
  140. How many quarts of tranny fluid
  141. Before I turn it on
  142. my friends fuel problem
  143. My Favorite !@#!&*! Yellow Lght
  144. Check engine light!!!!!!!!!!!!!!
  145. torque converter issue?
  146. Tranny or rear diff?
  147. Manual to Auto
  148. Brakes
  149. Rear differential leak?
  150. Poor mileage
  151. Whats the deal?
  152. 99 dodge codes? help please
  153. Hard start, VP is good, filter clean, new crank pos sensor, Im stumped.
  154. 47RE to 48RE Transmission in 99 Dodge 2500 CTD
  155. Fuel pressure
  156. NV5600
  157. Desperate to adjust throttle linkage
  158. Is 20mpg good???
  159. Fuel pressure question(Like every other 2nd gen)
  160. Why boost cqap at 28 psi
  161. 98.5 24v died. won't start.
  162. running rough missing when I get off the highway
  163. Clutch
  164. Flashing ECM
  165. 01 Cummins questions
  166. Leaking oil
  167. need some help on this one
  168. cruise control
  169. HO Motor
  170. weird smell
  171. 2002 Dodge Ram 24 Valve Engine Problem
  172. Bye Bye Tranny....
  173. Rear end identification
  174. New Dash
  175. NO FIRE
  176. vp-44 hiccup
  177. Torque Specs for your vehicle
  178. which fuel filter for 2001 CTD?
  179. Oil Change...
  180. Intermittent Low Power
  181. throttle
  182. exhaust brake
  183. need trans info
  184. APPS and lock up issues
  185. Battery Cables/Fuse Block
  186. Clicking Sound
  187. transmision leak fix ideas
  188. Leaks
  189. is this normal???
  190. Starter Rebuild Kit
  191. tranny
  192. Vp44 trouble
  193. tranny problems
  194. 47RE Tranny Temp
  195. Coolant temp variations!! Need help!!
  196. FUEL DEMANDS
  197. so whats everyone running on the adrenaline
  198. adrenaline finally came in but
  199. Question about ABS brakes and rear discs on an 02 2500
  200. transmission
  201. Fuel Filter
  202. warped converter?
  203. Power loss
  204. MAP senser unplugged
  205. want to buy a cummins
  206. Help!!!!
  207. Fuel line discussion
  208. A Big Thanks To Yall Diesel Bombers
  209. turbo question
  210. Questions
  211. power to lift pump problems
  212. Waste Motor Oil In A Second Gen?
  213. DiPricol gauge
  214. How does this plan sound?
  215. 24 valve turbo?
  216. Boost issues.... HELP
  217. Rocker Panels
  218. fuel problems!!!!!
  219. Oil Everywhere!!
  220. oil in radiator
  221. 7 or 8 inch stack to loud?
  222. Air Dog
  223. Upgrades for a daily driver/weekend heavy hauler?
  224. oil poll
  225. Too much fuel????
  226. I need a fuel pressure guage...
  227. How much psi is too much for the VP44???
  228. Uprgraded Fuel System.
  229. Leaking injector lines
  230. Might have bad news, P0216 code today, what do you think?
  231. wheel mounted sterio controls
  232. lookin at a truck
  233. compound turbo help!
  234. stock clutch
  235. Covered in grease, need quick answer Pleeeeeeease...
  236. 2 questions
  237. missing at idle
  238. can u drill out the injector connector tube
  239. missing piece on turbo
  240. oil dipstick
  241. exteem fuel pressure
  242. T56 to a Cummins
  243. trany problem
  244. NV5600 noise
  245. gasser out pulls cummins LMAO
  246. rv275
  247. EDM INJECTORS
  248. Gas milage - dually vs 4 wheels
  249. Airdog install gone bad!!!!!
  250. Cant start?
