PDA
View Full Version : 24 Valve 2nd Gen Dodge Cummins 98.5-02
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28
  1. Truck just quit running
  2. edge juice with attitude harness question
  3. Well, my lift pump finally died
  4. no start, new vp, new ckp
  5. questions about airdog 100
  6. Quadzilla power
  7. Turbo talk?
  8. A/C blows cold, then just air..intermittently
  9. 2002 qclb 212k 6spd yay or nay
  10. HELP! truck died
  11. Battery/alternator problem
  12. new to forum
  13. Question about Powermax tst
  14. throttle position sensor
  15. Covering radiator
  16. Fummins Edge question
  17. Wrong ECM
  18. Any Central Alberta guys want to help a fellow out?
  19. shootin sparks!!!!! need help ASAP!!!
  20. who knows speakers?
  21. Dana 80 35 or 37 splines?
  22. Popping noise when braking/turning.
  23. sandy got my rig
  24. H&S performance
  25. truck won't start
  26. Interior Pillar Trim??
  27. O boy think i broke something not sure what!!
  28. truck not charging when on
  29. no start
  30. 01 cummins/no power when cold
  31. No more shift tower boots?
  32. trans questions
  33. VP44 or apps?
  34. nv4500 shift tower
  35. New to site had a question.
  36. How to figure out if i have early or late 2002?
  37. time for some body parts
  38. i finally got her goin
  39. Bolt snapped in my crank...
  40. pretty sure my trans let go
  41. Dead as Fried Chicken!!!
  42. Horrible MPG!
  43. Bad vp or what??
  44. liftin my dodge
  45. how much boost
  46. no wait to start light
  47. VP44 Warranty Issues
  48. $$What would you pay?$$
  49. Opinions on this truck...
  50. Turbo getting some play what do you think?
  51. Help Bad Vibration From 60mph and up
  52. 2001 24 valve wont start
  53. Rims
  54. What to do next?
  55. what fuel system to run ??
  56. Vote 2012
  57. Shout out to Luke
  58. oil pan gasket ultra gray routing
  59. Urgent please help
  60. Bigger lines and tubes
  61. grid heater plus remote start ????
  62. Giving Props to a transmission Shop....
  63. Fuel pressure fluctuating between 0-12 psi
  64. grill cover
  65. winter oil
  66. Speedo Recalibrate
  67. MAIN SEAL LEAK!!!
  68. New VP44, Dead Pedal!!! Why?
  69. looking for some advice for better fuel mileage
  70. Voltage jumping around at highway speeds
  71. sound clip of mbrp turn down exhaust
  72. vp44 time
  73. What is it?
  74. vp44 connector
  75. 3 Piece Manifold Opinions
  76. WHICH 5" MBRP TURBO.BACK.STYSTEM
  77. First post and Oil Pressure question
  78. CODES
  79. CCD
  80. dumb question
  81. My trans is driving me CRAZY!!!
  82. loud clicking when engine and heating system are on
  83. leather seat replacement?
  84. hx35/40 supercharger sound
  85. Small Diesel engine question.
  86. Need quick info on dual disc clutch
  87. BLUE SMOKE
  88. what would you pay?
  89. 98.5 3500 What mods first?
  90. annoying hissing sound
  91. Tranny
  92. Performance issues???
  93. PLEASE HELP!!! CPS
  94. What vp44 should I go with???
  95. cylinder head
  96. Please Help Tranny????
  97. cracked valve seats
  98. Truck died after FASS fuel filter/water seperator change help!
  99. Starting issues
  100. Gauge Problem
  101. Trying to find the right turbo
  102. brake light question
  103. CPS!!!
  104. Block heater cord removal!
  105. Why cummins thermostat?
  106. Injection pump
  107. Oil Line????
  108. Manual Tow Mirrors
  109. What it Worth
  110. gears
  111. 4x4 not working
  112. Cooling system flush 24 valve procedure
  113. rotors?
  114. quick fluid questions guys
  115. Hot Rod VP44?
  116. Shocks for a 2wd
  117. About an older post.....
  118. auto trans upgrades?
  119. will a 2000 motor go in my 1998.5 help asap
  120. front end questions
  121. air dog fuel issues
  122. What is going on?
  123. swapping welded diff for ls/open diff
  124. surgeing
  125. body lift without steering extension
  126. Starter or batteries???
  127. Dim headlights
  128. Corner Lights Not Working..
  129. Injector Info Appreciated
  130. Custom Grilles
  131. need help loosing power at steady speed
  132. Winter wheels!
  133. what front bumper and fenders interchange with 99?
  134. Custom Dodge grille 2nd gen
  135. Reasonable RPM's?
  136. Have I been "HAD"?
  137. Fun
  138. Tranny
  139. stuck on floor
  140. upper and lower ball joints torque.
  141. VP44 Fried?
  142. Fuel Pressure sensor location??
  143. low voltage from ecm
  144. High idle switch needed
  145. Rocker Panel Treatment
  146. LOW engine temp
  147. 1999 dodge 24v warped head !! help
  148. auto trans cooler lines
  149. ranch hands
  150. anyone else, or am i just a dumbass?? towing mirrors..
  151. How to get more boost?
  152. Looking to purchase a L.S.D.. not the drugs!!
  153. Dodge crappin out...
  154. re torque stock head?
  155. Transmission catastrophe
  156. p0230!
  157. Ring and Pinion
  158. Oil Pressure went to 0 at idle
  159. 3 cylinder high idle
  160. Lacking Power Help!!
  161. Re-tread tires
  162. ABS/Brake Speedo Works?
  163. Help with rough start
  164. turbo
  165. right below bein smart
  166. 2001 lost some power need help
  167. injection pump rebuild shops
  168. u-joint issues
  169. Need info on oil and filters
  170. No low end power
  171. any advice?
  172. best settings on a smarty
  173. 99 cummins stalling when stop
  174. Transmission Temp Idiot Light?
  175. low voltage to govonor pressure sensor
  176. Bosh injection pump ID number
  177. tire sizes
  178. de fueling?
  179. bumper bolts
  180. 47re ?'s
  181. What engine temperature are you guys running?
  182. Auto Trans
  183. 2001 6spd with intermident power loss
  184. 04 turbo?
  185. 01 HO Knock with video any ideas ?
  186. AirDogII 165 dropping 7psi ??
  187. NV5600 double click?
  188. Fuel milage driving/programmers
  189. fuel pump ?
  190. Quick Trans Fluid Question
  191. Trailer Break Wiring harness
  192. 4x4 question
  193. exhaust
  194. 4wd cable lock
  195. whats my truck worth?
  196. Does anyone know?
  197. What Tuner Now!
  198. shakes when turning off. problem?
  199. smarty questions
  200. limb/dead pedal
  201. got my meth lol
  202. Question about programmers!
  203. Fuel Guage Calibration
  204. tranny upgrades
  205. PCM or VP44 or Apps?
  206. brake help
  207. slow window
  208. Power window help!?!?!? please
  209. Truck won't shut off
  210. Lose of power at crusing speed
  211. Stalling out!!!
  212. did my 5th gear nut let go?????
  213. "New to me" repair thread.
  214. need help bad!
  215. Control arm bushings!!!
  216. Low
  217. Cup Holder Broke anyone have one!
  218. Valiar makes Duralast
  219. What would it take to hit 600hp?
  220. 02 lock up switch
  221. pressure of pump?????
  222. wait to start light
  223. s400 quick question
  224. upgrades
  225. what do i need
  226. Good feeling.....
  227. Turbo Tuning?
  228. hx35/40 boost #?
  229. No throttle until fuel feturn restricted
  230. Help vp44 issues
  231. Turbo rebuild
  232. 2 tone paint job pics
  233. 3 inch lift
  234. Torque converter question
  235. looking at buying a 2002 2500 cummins
  236. i think i found my no bus problem!!!!
  237. brakes
  238. 24v crack block?
  239. Slipping out of overdrive?
  240. wait to start light
  241. Heat Exchanger
  242. a/c questions
  243. Street Truck Pics
  244. Heavy duty front bumper / snow plow
  245. Can i ask this here?
  246. reverse lights
  247. 6th gear slip
  248. looking for a turbo!
  249. all locked up
  250. Can you??
