PDA
View Full Version : 24 Valve 2nd Gen Dodge Cummins 98.5-02
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [21] 22 23 24 25 26 27 28
  1. Need your Input
  2. mystery
  3. code216
  4. Cold start blues
  5. weird start?
  6. what clutch should i use?
  7. Truck Rear Too High
  8. PMSING dodge!!!
  9. VP, lift pump help!!!
  10. white grey smoke under boost
  11. Knock Knock Knock......
  12. old ram is gone
  13. hard start
  14. white grey smoke??
  15. intermittent miss
  16. low voltage
  17. bad vp pump
  18. FPCM question
  19. loss of boost
  20. Wastegate plugging
  21. boost press senser reading low.
  22. 01 24v auto-want to build up tranny
  23. heater core replacment
  24. APPS stutter but not
  25. Turbo oil drain tube gasket?
  26. 48RE Cooler prob...
  27. Auto- 5speed ??
  28. hard start and cutting out while wot
  29. 2000 sarting problem and other issues
  30. buddy with a 2000 electrical problem
  31. fuel problems
  32. Pump issues
  33. Torque Converter not locking up.
  34. Trouble codes help
  35. Rocker Arm Inspection
  36. need help with torque specs pleaseeeee
  37. Head Bolts
  38. tap broke in manifold!
  39. tranny swap
  40. who makes this tc
  41. Truck Problems
  42. Dim Headlights????
  43. '99dodge ram 5.9 cummins diesel-truck won't start
  44. VP44 / BD lift pump. issues
  45. Steering and fuel canister question 2001 QC 4x4
  46. 12v turbo on 24v
  47. BREATHER
  48. 47re cooler check valves
  49. A/C compressor clutch squealing
  50. crazy situation fuel related ?
  51. HELP!!!!!!!!!!!!! 01 cummins "no bus"
  52. 47RE Transmission price??
  53. brakes / steering issues
  54. what size bolt is needed for turbo flange
  55. Engine Knock Help ASAP!
  56. VP RIP
  57. Great 24V info
  58. air conditioner just died
  59. help on injection pump
  60. question about 47re and 47rh??? help
  61. squealing when shifting
  62. Turning up the line pressure in the 47re trans?
  63. removing 47re from an 01 cummins
  64. crankcase breather
  65. Lockup in OD, cant make up its mind.
  66. Fuel Guage Issues
  67. stainless steel tranny cooler lines
  68. auto to manual tranny swap?
  69. starter
  70. Truck wont start
  71. Wastegate on 02 3500 auto tranny
  72. Headlight issues
  73. new clutch
  74. 5spd... slave cylinder junk?
  75. Do not know what is wrong with truck..Any ideas?
  76. leme know what u think plz
  77. Lights intermittently dim and display CCd.. ???
  78. before i take her to the shop?
  79. Advice on my hopefully soon to be first diesel
  80. Machining Head After Blown Gasket??
  81. Rear axle bearings?
  82. 02 Cummins acts like it is not geting fuel when pedal is pressed
  83. just installed my cab lights!!
  84. hard to start.
  85. 98 auto trans problem in overdrive
  86. PPE lift pump
  87. Fuel pump( fass) relay voltage from ECM
  88. Leveling Kits
  89. On board air
  90. Brakes locking up
  91. Just a lil more smoke?
  92. Brake lights and blinkers
  93. 01 2500 Tranny issue?
  94. hx-55
  95. turn signal wire color
  96. Power Steering & Vacuum Pump Seals
  97. muffler time...
  98. ho swap vp
  99. finally !!!
  100. OBD II
  101. Which Sport Headlights Did You Use?
  102. i got a miss at low rpms
  103. feels like brakes are on
  104. Home Maid Stack Opinion
  105. 12valve or 24valve, what do you prefer?
  106. Auto Trans Slippage Question?
  107. Need help with codes and "no bus" code
  108. quad updates
  109. truck missing at idel when warmed up
  110. intake manifold
  111. lift pump and filter
  112. Going to buy 2001 cummins 4x4. ALL STOCK
  113. Turbo question
  114. Need some smoke
  115. 99 cummins, rpm spikes to 3200, then won't rev past 1200rpms
  116. Remote Keyless Entry (RKE) Programming Help
  117. Think TPS Finally Died
  118. HID headlights
  119. will a 04 nv5600 work
  120. Cab lights
  121. trans problems
  122. starter clicks
  123. tranny change?
  124. Erratic Boost / Tranny Shutter
  125. Turbo Whistle
  126. need help asap
  127. Vin Number
  128. BullyDog Watchdog Economy Monitor
  129. truck quit need help mybe 44 pump not sure
  130. Need help with datalink
  131. Need a new VP44?
  132. boost fooler loading up
  133. anyone interested in swaping my manual for your auto?
  134. 2001 dodge tranns issues
  135. 99 issue oil leak
  136. I talked to Dodge today about Fuel Pump
  137. turbo/oil problem need input please
  138. DAP Injectors whos runnin them.....
  139. tranny advice please!
  140. alternator?
  141. well i finally checked my fuel press.
  142. '01 Clutch Pedal falls to floor
  143. Water leak after 24 valve rebuild
  144. 13:1 Compression Ratio VP44
  145. won't crank
  146. 01 Dodge Ram 2500 Waste Gate Problem
  147. 2000 24 valve cummins tps location
  148. FT. LBS to INCH LBS on trani adjustments
  149. airdog...truck not runnin great
  150. gauge mounting help
  151. 98.5 5.9 CUMMINS WILL NOT START
  152. 47re trouble
  153. Throttle Bump
  154. 1998 24v code p1389 help
  155. NV5600 question
  156. torque converter?
  157. slave cylinder
  158. Transmission questions...
  159. Sport Bumper Conversion?
  160. gonna put some electrics in the valve body of my 01 cummins
  161. 47re to nv4500
  162. 01 cummins auto tranny issue
  163. The 53 Block cracked . . .
  164. code dodge
  165. Blower Fan Issues
  166. Fuel in oil
  167. allison for a cummins ????
  168. No start, no start. Ok, it started.
  169. Looking at a 2002
  170. Diesel Fuel Compatible Thread Sealer
  171. adjusting valves
  172. 99 cummins
  173. NV4500 transmision issues jumping out of gear
  174. Hard Start
  175. truck missing at idle?
  176. should bands be adjusted?
  177. adjusting my wastegate
  178. 16mm turbo housing from 93 onto a 2001??
  179. trouble interpreting codes: P0216...
  180. trucks getting warm.
  181. Tranny and suspension question- help please...
  182. head bolt torque
  183. Another VP44 death?
  184. issue ?????
  185. auto tranny
  186. bad computer, still runs?
  187. Clutch!! help!!
  188. looking for 1st gen wheels
  189. VP-44 Ram Air
  190. drain problems?
  191. rearend
  192. v10 to cummins swap
  193. fuel gauge problem
  194. How do you like your Sport headlights?
  195. In tank fuel pump?
  196. Wastegate stuck closed.
  197. 53 question
  198. No tach/alt...won't start unless you
  199. 98.5 24 Valve. Help me out...
  200. Oil Pressure & Fuel Pressure
  201. Turbo
  202. injector pump PO216
  203. wait to start light 98.5
  204. Advice on fuel tank module repair
  205. is this a good deal or not on a 24v? advice please
  206. soundproofing
  207. 02 dually need advice
  208. starter contacts
  209. Electrical Problems Still
  210. KDP Question?
  211. Truck heater cycling when hot?
  212. Oil Pressure Switch FAIL... Holy Expensive! Help?
  213. What is a Fuel Plate
  214. VP-44?
  215. guess my fuel milage
  216. hot wire
  217. thinking about doing a side exhaust
  218. bad injector?
  219. lowered cummins
  220. not running well
  221. what to look for....
  222. about to switch to cummins
  223. a REAL 24v jake brake :)
  224. shocks
  225. how to measure vacumm
  226. duct system problem
  227. no fuel millage
  228. changing factory fuel filter
  229. fass fuel filters???
  230. dodge wiring >:(
  231. 1 of 8 lol
  232. how fast?
  233. surging idle please help
  234. wireing fuel pressure guage
  235. Tranny has No Passing Gear
  236. anyone for governor?
  237. 01 cummins injector cores?
  238. 98 Ram 2500 Blown Head Gasket?
  239. Final Follow up on new lift pump with my rebuilt vp44
  240. PCM reflash
  241. Smoke rolling from drivers rear tire
  242. removing the bed
  243. Tow Mirrors Help
  244. Tranny not slipping... more like down shifting
  245. help choosing
  246. TPS died again
  247. Fog Light Restore!!!
  248. Compitition Forum?
  249. 2 turbos in 2 weeks
  250. Headliner?
