PDA
View Full Version : 24 Valve 2nd Gen Dodge Cummins 98.5-02
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25 26 27 28
  1. trans input
  2. Injectors
  3. Normal?
  4. ecm pin locations
  5. White/Grey smoke??
  6. FML!
  7. 01 for sale
  8. 2000 Cummins up and died?
  9. SAFE FUEL PSI LEVELS ?
  10. fass platinum installed
  11. winter wanted
  12. TPPS adjust, now codes
  13. new fass platinum
  14. Misfire problem?
  15. Ppump conversion
  16. Boost Fooler?
  17. 2001 47RE Slipping in Left Hand Turns
  18. new lift pump in tank
  19. Clutch help
  20. Electrical Problems oh great! PLEASE HELP!!
  21. In need of suggestions!
  22. HELP!! with adrenaline
  23. Injectors are in....
  24. Rebuild VP 44 before it dies
  25. need rocker panel, maybe more
  26. Completely lost on this one
  27. 1999 2500 fuel pump or pumps?
  28. don't have much power help
  29. Best DTC reader
  30. Exhaust choice
  31. 5 codes and 16psi max boost?
  32. error codes and what do they mean
  33. my dodge 2500 trans problem
  34. Max Milage Chips.
  35. Key trick
  36. Winterizing Your Trucks
  37. 5.9 power loss at 50 mph+
  38. track bar
  39. 01 cummins electrical
  40. Fuel Pressure question
  41. Codes p0602,p1693
  42. carrier bearing issues
  43. weird fueling issue, with codes
  44. big electrical issue
  45. Changed Lift Pump, 2 days later, starts and idles way too high
  46. VP Died last night
  47. cutting out/bucking
  48. overboosting
  49. gauge cluster problem
  50. should i change tranny fluid?
  51. new onwer
  52. 01 24v reving
  53. Exhaust Temps
  54. 24v p-pump or 24v cr ?
  55. tranny problems!
  56. transmission issue...
  57. Miss fire on my 2001 24 valve cummins
  58. Fuel Pressure issue?
  59. turbo not spooling up
  60. Defrost or off
  61. back brakes locking up?
  62. vp dead need some advice
  63. exhaust manifold bolt
  64. routing service questions
  65. oil leak
  66. Got a MPG's question for you guys :p
  67. power steering pump.
  68. I need a clutch ASAP for a 99 5.9
  69. Radiator fluid is Red???
  70. IPVREX VP44 PUMP??
  71. I Need Help! First Timer
  72. overhead console removal
  73. Tranny trouble?
  74. Anybody have this?
  75. Poor mileage
  76. hx35/40 hybrid
  77. Steering brace/ Snowplow mount
  78. Radiator Leak next to drain valve area
  79. new to diesel forum
  80. looking to buy a hy35
  81. 5 speed in an 02??
  82. 1998 cummins won't go into 1st gear
  83. A/C Blower problems
  84. Has anyone ???
  85. 911 HELP
  86. no talkin to v44/fault code p1689?
  87. Nv4500 issues
  88. compound turbos
  89. Button Under Rear View Mirror
  90. 02 2500 rebuild project
  91. Transmission Filter & Fluid Change
  92. NV5600 Flywheel
  93. black smoke
  94. A few questions regarding 01
  95. Fuel Pressure Gauge
  96. 2002 chip
  97. Anybody Live In Indiana
  98. 99 24v heat issues
  99. 1999 dodge cummins overheating
  100. If You Just Bought Your First Diesel?
  101. EV2 fuel pressure gauge flutter
  102. CCD on overhead
  103. Just Bought a 02 Cummins, Need to make it fast
  104. need some help
  105. odometer not working very intermetant
  106. 01 dodge radio
  107. need help p0216
  108. Trannys Toast - Suncoast or Goerend?
  109. help me please
  110. 24 to 12v
  111. Best mods to start with
  112. Not getting fuel
  113. got performance parts
  114. HX35W for sale
  115. Front bumper info needed
  116. lift pump help
  117. Throwing codes 0753 and 1765
  118. Transmission overdrive
  119. My blinker went out (not as simple as it sounds)
  120. mpg blues
  121. Crank seal sources?
  122. I need help AGAIN
  123. Need help, new master and slave won't engage - Truck down
  124. Auto Tranny Question.
  125. 1999 wont start in warm weather??
  126. power pop up tow mirrors
  127. inj pump codes
  128. stickers
  129. why i love the dodge diesel
  130. 01 dodge diesell fuel gauge problems
  131. 2001 5spd Cummins
  132. injector lines leaking
  133. crank sensor location 01 24V cummins ?
  134. 02 front clip
  135. License Plate
  136. 99 Spitting and sputtering
  137. Help with VP44
  138. volvo smoke stack
  139. i need help!
  140. headlight switch, dash lights
  141. transmission problem
  142. head gasket question
  143. i need help
  144. Which Tire Brand
  145. Diff fluid question for 02 cummins
  146. diesel bomber stickers
  147. head lights
  148. fluid leak
  149. No speedo, ABS light on, replaced vss
  150. Running a little warm....
  151. any ideas on adding power
  152. Transmission and F/P question 01' ram
  153. intermitent no start
  154. dead vp44
  155. 2000 cummins, good deal?
  156. map sensor issues
  157. 2000 5.9 cummins needs help
  158. Transmission will not shift properly
  159. Need help troubleshooting!
  160. is this good for towing?
  161. New to site need a little help
  162. fuel pressure gauge is going up and down
  163. 1999 3500 Sport
  164. 2001 cummins Park/neutral switch problem??
  165. smoke switch
  166. Makin the rear end solid for a truckpull
  167. your opinions needed on trading my 01 gas 5.9 for a 01 cummins 5.9
  168. No power
  169. dodge front end rebuild kits $250
  170. 2001 tach problems
  171. Fuel Seperator
  172. best head gasket
  173. 24v Auto to Manual Swap
  174. Tranny replacement
  175. Cummins clothing
  176. 24V no start, Semi fixed need a solution.
  177. 01 24 valve cuttin out
  178. trying to find 53 block found numbers instead
  179. Have lift pump, need fuel pressure gauge?
  180. Help
  181. No Codes, Help
  182. 2002 24 valve Engine revving during normal driving
  183. part #s please
  184. Death wobble????
  185. Faulty fuel reading
  186. Need Some Serious Help
  187. need help quick!!
  188. wont go into reverse
  189. Lift Pump Leak
  190. SCT?
  191. intake elbow
  192. tranny rebuild or buy new crate?
  193. hi and help
  194. tow hooks on a 01
  195. trouble shifting outta 1st into 2nd?
  196. egt probe on edge going bad??
  197. no power
  198. injectors
  199. Heater Core
  200. only 4th gear
  201. iat sensor
  202. A/C stuck in defrost
  203. front end fun!
  204. EGT's
  205. lose of power
  206. rough idle
  207. overheating problem
  208. removing shifter knob
  209. Need help on buying a new transmission
  210. Nv4500 problems
  211. 5 spd shifter boot and trim
  212. boost problem
  213. A bad sticking problem
  214. help on buying items from classifieds!
  215. pullin
  216. Strange noise when put in reverse
  217. 24 vaulve running hot
  218. turbo selelction (I know, again?)
  219. a/c freeze up
  220. Lots and lots of work....I think it paid off
  221. Lift? or level?
  222. In gear but no go.
  223. Pullin
  224. fuel filter drain valve leaking
  225. Truck has no power till it warms up
  226. CPS Location
  227. Tow Mirrors
  228. New trans wont shift into OD
  229. need advice for truck pull this weekend
  230. 98 24v read codes
  231. wont shift out of 1st and rmps wont go over 2k
  232. Truck Pull Question
  233. Installing Intake mani gaskets
  234. Oil Leaks
  235. Lift Pump Dead at 71k Replacement vs In Tank Pump
  236. DownPipe
  237. Code 128
  238. vp 44
  239. rawwilliams
  240. Anybody have FTE diesels Manifold Gaskets?
  241. help dana 80 eating spider gears!!!!
  242. Seen this before?
  243. 98.5 cummins clutch
  244. HX35 wastegate
  245. 47RE issues
  246. edge comp
  247. egts
  248. no boost
  249. Oil pressure sender/switch install
  250. codes
