- rebuild kit
- Roaring noise while driving, not from front end
- Body Control Module ?
- #53 hard block ?'s
- wat year ecm's will work
- 22.5
- nv4500 rebuild kit
- Just b4 disaster
- 2002 ram 3500 cab and chassis rearend
- electronic issues help!
- Looking for a place to get a switch box or panel
- LOOKING FOR MOD IDEAS...
- Looking at buying 02 cummins and NEED HELP !
- recommendation on antifreeze
- exhaust wont seal
- 98.5 cummins upgrade????
- tc lockup?
- Second Cummins 24V 1999
- want to get my first dodge with cummins!
- big problem!
- Newbie What's up 2nd Gen
- APPs Or No??
- clutch install
- Driving habits while towing?
- RPM's all over the place
- Torque Converter Random Unlocking,47RE
- 275k
- what kind of chip
- Hard starting issue
- Reman VP44's
- EGT are not normal
- 1999 24 valve Transmission oil leak
- Intermintent starting problems
- What boost PSI should I be seeing.
- power issue
- fuel cannister '00-02
- apps sensor mess
- Heater
- Quadzilla Adrenaline erratic throttle response
- 1999 Dodge 2500 24valve
- overdrive slipping
- park and dash lights?
- white smoke
- no power on hills
- Ouch that's gonna cost me
- Heater
- Superchips flashpaq
- Best lift pump and programmer
- 99 dodge leans to the right
- Good deal or not?
- Truck repaired by dodge, now more issues, help!!!
- Convince me to do cab lights
- PCM and ECM upgrades?
- fuel filter housing
- Cleaning dirty motor?
- map sensor?
- Curiosity's got the better of me on VP44's?
- Front end problems!!!
- multiple trucks 1 smarty programer
- need a nv4500
- Oil drain plug
- Restoring my 98.5 suspension question
- Troubles starting in the morning.
- strange issue?
- truck wont shut off when i turn the key off
- 99 dodge motor swap
- Fuel Tank Heater
- bad apps?
- 2000 dodge cummins 4x4 tranny rebuild cost?
- nv4500 rebuild project
- 24v lift pump issues
- death wobble
- PureFlow and FRRP
- 2000 Dodge Ram WON'T START....
- buying my first cummins! good deal?
- dtech 64/65/14
- starter contacts
- Instaling Edge juice with atitude ???
- Engine surge and fluttering while cruising.
- Cummins blow by
- cutting out at startup
- Install instructions please.
- my first diesel!!! finally
- rough at idle, white smoke, lack of power
- Is this correct for my truck?
- 1998.5 ladder bars
- TC lock up?
- fluid on transfer case seal
- fuel filter canister
- knocking/ticking HELP!
- Air Dog FRRP or FASS DDRP
- Charging issues
- 4x4 stuck in 4-low
- gauges?
- Need some advice
- Check engine light??? Got me baffled
- atf+4 questions
- low voltage
- Cant get truck to prime back?
- What programer to get??
- replaced rear diff, quick e-brake question
- oil under the block and pourning out the exhaust
- weird exhaust rattle
- Check Engine Light
- truck acting up on start up
- ChecK engine light with Code P1693
- Crank case breather
- zero power?
- Starting issues
- camshaft cover
- limp mode?
- turbo wastegate qustion
- Upgrading ideas?
- truck died, vp44??
- Boost P.S.I.??
- potentiometer on 24v?
- Truck Died on corner
- Loseing fuel presure
- Trans line sanded down?
- clunk in steering column
- PLEASE HELP!!....where to start??
- Starting issues
- new vp44 still getting p1689 code..help
- Help truck won't rev out and want to go home for Xmas
- ecm intermitantly not turning on lift pump
- dash gauges dont work
- I stripped the fillter drain screws , apparently
- losing it prime
- pre lift pump strainer
- 02 cummins codes p1693 p0122 p1475 HELP
- Valve body recommendations???
- Headlight Switch
- 2001 24v missing, loping, white smoke...HELPPPP!
- cat filtration
- truck has a mind of it own!
- No more after market?
- HX35
- replacing vp44!!!!
- smokin white and leakin fuel like crazy
- s.o. or h.o. vp44 on h.o. truck?
- Just broke down.
- lift pump
- '02 Fuel sender/gauge issue
- uh oh...head gasket time
- tps?
- Another leak
- tires rubbin
- how to get good fuel milleage
- codes codes codes
- new to dodge and now big issue.
- Wipers
- vp44 key
- need factory lug nuts bad
- low on power? 1689 code
- torque converter
- dually tire help
- Beginners Guide Input!
- 53 Block ID Locations & Info (Pics)
- Wheels and Tires
- Won't Start
- Lift pump question.
- Rebuilding my 6-speed nv5600. HELP!!
- TPS problem
- Alternate Oil Pressure Sensor Location??
- What do I need to install fass.
- shuts off at operating tempature
- New cummins. Got some ideas. Need input
- Dumb Question??
- 2002 dana 80 questions
- blow by?
- pyro probe placement
- tell me what you think!
- High idle and 3 cyl idle
- how do i get the shifter knob of a manual tranny
- dodge surging
- Guardian Angel
- Headlight upgrade?
- Cracked injector nozzle tip
- tappet cover leak?
- Rings are bad?
- BD-Power Sway Bar End Links
- Oil leak part duce
- Lift Pump Voltage????
- clutch problems can anybody help
- Voltage drop , surging and tons of codes !!
- 99 diesel
- Stolen 01 Dodge in central Alberta
- Nv 4500 problem
- BAD MPG AND CANT PULL!? HELP
- Blow by i think?
- what happened to sdx
- Grid Heater
- Adding cab lights to 2500
- Fuel pressure gauge
- Stock rim width
- Edge Fuel Pressure
- help: 01 6spd with codes
- lift pumps
- need a wiring schematic?
- whats the benefits of a 4inch down pipe
- water/methanol questions
- Play in steering
- LINK TO T/C LOCKUP THREAD??
- Shredded belt...
- No Power to 12v outlet??
- Erratic Dead Pedal
- Banks Smog Legal?
- want more power!!!!
- recommendation on replacement heavy duty front end parts
- New dd clutch just dont seem right
- turn signals, rear brake lights, and hazards dont work? HELLP!!
- Thermostat
- 02 powerless when pulling trailer?
- No Smoke
- tranny cooler
- Quad Adren Surging
- Installed Gauges, Truck will not Start now
- nv4500 trans stuck in 4th between 5th and rev.
- P0462 - fuel level sending unit volts too low
- HID Headlights
- 24 valve programmer
- Cab Clearance Lights
- BHAF
- 2001 24v high fuel pressure
- Best price for limited slip clutches
- crank case oil cannister...maybe leaking
- Injectors or nozzles
- hi there new to here quick question
- Battery question
- Simple Oil Change Question
- mbrp turn down series help
- RV 275 Question
- flatbed install
- clutch install
- 24 valve fuel economy
- Need help with problem of idling.
- converting my 24v to 12
- Which Fuel Lines To Get?
- dead vp
- Oil Pan Gasket
- high beam light stays on when truck is off
- 2001 dodge cummins dies after i floor it
- First diesel, any tips/tricks/do's and donts?
- Mounting Traction bars
- INJECTION PUMP!!!
- Brake light wiring
- tire time
- Where to go next with my truck?
