- injector nozzles
- lift pump or tps sensor
- High Idle
- Anybody!
- 2002 vp44 on a 2000vp44
- 2001 cummins fast idle
- blown gear cover gasket
- new transmission, no overdrive and trans temp light on
- cruise control off, no engine brake
- Off Idle hesitation
- auto in 02
- STACKING WITH A ADR AND A POWER PUCK
- Codes
- Any ideas hp my truck
- oil press not workin
- Tachometer and Speedometer quit
- 99 dodge problems
- Starter Trouble
- Heater Problems
- New Paint and Wheels!
- Center Console/Bench
- Dead Pedal
- funny idle
- Still problems - starter?
- Valve Body Replacment
- another trans problem
- Boreing out the cylyinders?
- Cracked Block
- oil leak
- Headlights
- vp or not
- Tansmission help please
- new steering box problems
- engine runs but no power
- max vp44 rpms ??
- self help literature
- Loss of Power
- No 1st or OD only 2nd & 3rd.
- Oil in intercooler.
- new truck
- need quick advice on cummins trade
- infamous "53" block
- Good vibrations
- ABS Light on again.
- 01 cummins has no power
- How to adjust the idle?
- Oil pressure switch
- Abs light
- sick truck
- Injector nozzles
- new truck. needs work
- wipers
- Help! My automatic transmission is stuck in first gear!
- turbo temp, and boost Q's
- electrical issues
- What does this mean?
- surging boost
- New to the diesel world, and lookin for info.
- Help!! May have a big problem
- Do you guys think mytruck has injectors ?
- de-fueling issue after 1/2 hr running
- 47 re, 48 re question.
- How Much Smoke?
- The Unofficial, Official My Dash Cracked Thread
- have codes, 1492, 1693 and 0122
- got my gauges!
- Tubo help
- something is messed up and its wierd!!!
- vibration!!!
- Lift pump leaking
- Truck cutting out?
- Swapping blocks?/ Cracked mine
- Stutter
- ho or so
- gears?
- Suspected VP44 Failure-Would like verification
- 4500 to 5600 swap
- got a AC problem
- NEED HELP PS/HYDROBOOST
- Transmission Rebuild
- Cutting out / missing noise?
- Steering Question
- surging question
- Anyone else sick of auto transmissions?
- cummins hoodie
- 5 speed swap
- Steerin Box
- backspacing
- fuel transfer tube leak
- Recalls
- something weird
- code 1693!!!!!!
- need help
- tire size
- Stock Fuel Line, What Size?
- Rebuild Vacuum Shift Motor / 4wd Actuator
- Spicer 80 Limited Slip Question
- Clunk in front end when turning (once per turn direction)
- problem with wait to start?
- I have a question
- .093 injector tubes
- transfer case
- power
- brakes
- Need some information
- 02 Dodge Transfer case... BUSTED!!
- injectors
- smoke
- gauge ?
- APPS question
- oil filter and a lope
- fuel
- parallel or series
- weight
- Heater fan only works on high?????
- removing front engine cover
- Ohhhh she's a big runaway!
- vp44
- Lift Pump Going Bad or TPS?
- Filters and Gauges
- oil filters wich are bad and which are good
- TPS or APPS?
- Hick up in idle?
- 99 Cummins low oil pressure
- Down pipe bolt?
- 24v cummins pulsation
- Clutch on NV5600 won't release when cold
- Need help just blew radiator can some1 send me some directions on how to replace?!?
- crank sensor
- I NEED A VP44!
- my he351 install
- 1998.5 Having TPS problems I think can anyone help?!?
- stock fuel filter
- ball joint ?'s
- help!! auto tranny problem
- biodiesel
- Need Help TRAC BAR
- oil pan leak
- vp44 pump?
- waste gate
- pullin
- hx 50 or smaller
- whump in rearend when letting out clutch on right hand turns. What is it??
- speedometer & doorlocks & overhead mileage display quit working
- raptor rp 100
- Starting Problems
- 236 code
- Lift Pump
- 24 valve hard starts
- Trans upgrade
- replacing injectors
- Upgrades to a 6 speed manual??
- Cheap 4x4 fix?
- Vacuum sound
- this is what im workin on
- dodgecumminsapps.com?
- easy fix to vacuum pump?
- cummins hard to start
- No! Run!!
- Reflashing computer?
- map sensor
- SOCAL cheap diesel work or norcal
- Idle Stop Screw
- Dana 70 hub removal
- h2e turbo?
- Code 1693?
- Clutch
- 24 Valve Identification
- code p1682
- pcm interchangeability??
- pulling #5 and 6 injectors
- Codes?
- Black Grille for 01 cummins
- Help! Need info. on 99-01 NV5600 6 speed
- NV4500 issues
- trans problem?
- APPS TPS Okay to drive?
- Thoughts on a Magnaflow muffler
- Fuel Problems
- valve lash
- confusing?
- 5 and 6 speeds
- 99 to 01 motor swap
- HEAD STUDS price
- HX40
- Filter?
- New Project
- Sport Grill
- vacuum pump rebuild
- need advice on vp44
- 01 24 valve died no start
- hey
- hey
- Thought the old gal just bout died
- small mods?
- Axle Swap
- Front Gear Case Removal
- NV5600 parts situation?
- upgrades for truck with stock trans
- nozzels
- Remanufactured ECM help help help
- 99 dodge questions
- How to Polish turbo?
- lope ?
- Couple Questions
- vp44? apps? comp box? dead pedal? please help
- Oil filter
- Fuel filter 1999 5.9 cummins
- 4 wheel drive popping out?
- Vacuum Line Question
- POWER MIRROR CHEAT
- Truck cutting out at high speeds?
- One of Dodge's Inheirnt Problems
- NV5600
- power surge
- 99 dodge wont start
- Turbo Drain Line?
- ABS controller reprogram
- whats my truck worth
- 4x4 problems
- hey
- Brakes got air in them
- oil coming out the filler
- leaking some fuel
- block heater
- Any one on here run a BD towloc...
- TPS/APPS issues.
- rust solutions
- need ideas
- Staling problem
- truck rides really rough..
- Front Differential?
- Trans trouble.
- Need some help w/ this one . . .
- VP44 Rebuild Kit
- Tranny fluid
- VP44 install
- Injectors....choices choices choices
- Hard starts - Cold engine
- check out my new $2600 project
- stacks
- smarty question
- 4WD binding
- Engine Rebuild Kits?
- p0216 & p0121
- Truck misses/stutters when hot
- Taking 98 mirrors apart at the pivot?
- CEL/P1689 DTC (somewhat long to give accurate details)
- 165,000 On A VP44??
