PDA
View Full Version : 24 Valve 2nd Gen Dodge Cummins 98.5-02
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 24 25 26 27 28
  1. VP44, electrical, torque converter, or tranny?
  2. Automatic trans
  3. fuel pressure gauge
  4. Would a hx35 hybrid be better than my 35
  5. Would a hx35 hybrid be better than my 35
  6. Torque converter just stopped locking
  7. short bed dually build.
  8. what next?
  9. Weird alarm issue...
  10. Limp Mode
  11. Factory lift pump dead. Which do you suggest.
  12. after airdog 165 install
  13. p0252 check engine light issue help!
  14. exhaust
  15. Vacuum Problem
  16. diesel kleen or 2 sroke oil?
  17. Runnin out of fuel under hard acceleration?
  18. Bad Injectors
  19. Was looking to buy first 24v, test drove truck and accelerator pedal kept cutting out
  20. looks like my truck may get totaled out.
  21. need some advice
  22. Can someone explain to me the turbo differences
  23. No power to lift pump
  24. 99 cummins buy it or walk????
  25. pop pressure
  26. new pump
  27. for sale
  28. Cruise Control Problem
  29. P0217
  30. starting problem
  31. Power Steering Help???
  32. edge comp install
  33. i have some problems...
  34. i need some major help with my 01 cummins.....
  35. four wheel drive vacuum won't disconnect
  36. upgrade the fuel system
  37. manual tranny problems
  38. tire suggestion
  39. Worried about high egt's
  40. clutch
  41. WTF! Please, Help.
  42. what next?
  43. Rust Repair
  44. Ideal Towing Mods?
  45. Dana 80 Locker ?s
  46. boost leak?
  47. 98.5 cummins charging problem?
  48. What vp pump?
  49. clutch
  50. PUFF and blue smoke on start up
  51. 5 speed or 6 speed?
  52. i need help
  53. Pics - alternative gauge mounts?
  54. Gauges???
  55. A few ?s since im new.
  56. 02 dodge
  57. 2001 cummins questions
  58. Rough idle after 200 hp injectors
  59. vulcan big line kit
  60. tps or clutch
  61. Dead pedal when cold
  62. wet floor
  63. Dealer diag
  64. Which one should I get? air dog lift pump.
  65. few quastions about a 99
  66. pump ?'s
  67. power lock mystery
  68. price on 24v im looking at
  69. Dead batteries
  70. trading my 12v for a 24v got ?
  71. Loss of power, high EGT
  72. Steering components on a 2000
  73. 47RE
  74. 4x4
  75. 2000 cummins 4x4 5speed.
  76. Tow mirror fix
  77. borg werner airwerks
  78. Heater Core.
  79. Dash cracking?
  80. Vacuum on fuel filter
  81. power steering??????
  82. towing with my cummins
  83. Grid heater issue
  84. Fuel Pressure
  85. wont start after fuel filter change
  86. clutch
  87. Intake Heater Grid Question
  88. how to install the edge fuel pressure sensor with airdog 150
  89. 98 24 valve spitting & sputtering
  90. Cracked oem rims (with pics)
  91. vacuum pump
  92. Cruse Control won't turn on
  93. tps
  94. Newbie With Some Questions
  95. Auto tranny upgrades
  96. lift pump suggestion
  97. Grid Heater killing batteries
  98. my auto for your handshaker
  99. Fuel Pressure Gauge Suggestions
  100. part identify
  101. Oil in exhaust pipe
  102. Injection pump problems
  103. Tired of Adrenaline surge; any suggestions to replace?
  104. She is doggin bad
  105. Injector feed tubes
  106. steering upgrades
  107. Steering Box
  108. MAP sensor
  109. steel bumpers
  110. My Dream Truck
  111. best chip/programmer for fuel milage
  112. fault code po2509
  113. what turbo should i run???
  114. will it hold
  115. 24v Hard start hot
  116. trannys starting to go..... i think
  117. Fuel mileage
  118. Class action lawsuit.. 98.5-01 ISB 53 block
  119. 01 Cummins, de-fueling problem! HELP PLEASE!
  120. compression tester and numbers
  121. Maybe I'm just blind
  122. pcm question
  123. Stock injectors?
  124. So I'm having some problems with my new 99...
  125. scary steering
  126. strange noise
  127. front end question
  128. gov trans pressure
  129. CREW CAB
  130. scanner?
  131. edge problems brings on check engine light
  132. voltage drop repeatedly
  133. took edge box off no power
  134. bright lights
  135. Lift Pump, sump, programmer
  136. your thoughts
  137. 2001ram2500 srw to drw dually conversion help
  138. 5 speed swap!!
  139. HY35 TO HX40
  140. need help please
  141. 8.8 volts at fuel pump
  142. what axles interchange 1999 3500 drw
  143. edge compbox
  144. makeing er smoke, but not all the time
  145. Best single turbo?
  146. sending unit for fuel guage
  147. Smarty High Idle
  148. Fuel Guage 01 cummins
  149. TPS
  150. fuel leak..
  151. heated mirrors????
  152. Door Speakers?
  153. thinking about getting high idle/3cyl idle
  154. exhaust
  155. brake controller problems
  156. Need help Need to know if I should do a trade or not
  157. smarty pros and cons
  158. electric fan?
  159. is this a good deal?
  160. 01 2500 2x4
  161. Fresh 24v cummins
  162. bully dog outlook problems
  163. oil cap?
  164. Shock Absorbers ?
  165. Need PPE install kit!
  166. Need help???
  167. rev problem
  168. 2 questions
  169. Marker lights
  170. 1999 dodge 3500 cummis dually
  171. grid heater question
  172. brake and abs light
  173. batteries
  174. Synthetic ATF
  175. e.j.w.a.
  176. Horrible mileage!!
  177. Quick shifting auto
  178. Lift pump suggestions???
  179. looking for a cummins
  180. 2001 Cummins No Start
  181. Good Deal?
  182. First 24 valve
  183. texas
  184. loss of power an poor fuel mileage
  185. is it my vp?
  186. Bogging down at 70% throttle, PLEASE HELP
  187. Cutting out/ No Codes
  188. rear end problems help please
  189. build it or buy it?
  190. Lift pump question
  191. Front Suspension Parts ?
  192. EGT & PSI
  193. electric mirror switch
  194. edge jwa data link adapter
  195. whats next
  196. tow mirrors
  197. sub box
  198. overboost
  199. Is it a Cam Shaft Sensor problem??
  200. compatable turbos
  201. Bogs down and misses
  202. Hard starting when warm.
  203. suspension parts
  204. Engine Oil
  205. chip or programmer trade
  206. diffrence in motors
  207. fuel pump assembly.
  208. build 47re or swap for nv4500?
  209. BHAF
  210. differential lockers?
  211. Best rear end oil
  212. is p-pump conversion worth it
  213. 01 with no power at mid range
  214. price for diesel bombers stickers
  215. Brake Problems
  216. Another Starter Question
  217. Grid heater issue?
  218. nv4500 solid truck for 3k..should i?
  219. fuel guage broke
  220. 2wd 5 speed I would like to swap for an automatic overdrive
  221. J Hook
  222. Badges or No Badges
  223. new turbo
  224. Wanting new headlights need direction
  225. 01 2500 Cummins starter dragging and stuck
  226. Fleetguard Crankcase Ventilaltion
  227. Truck won't start or turn over
  228. Block heater idea?
  229. diesel dawgs
  230. only idling
  231. VP44 injector inlet fuel pressure 8 PSI
  232. 99 5.9 starter problems
  233. need a new APPS
  234. s300
  235. Tranny bucking
  236. Auto to manual swap, parts?
  237. 5 minute, $5 throttle cable fix
  238. adjusting a fass
  239. hx40 turbo for sale or trade
  240. Turbo Problems ?
  241. Good seat covers?
  242. Brakes???
  243. Hunting For Gears
  244. I think my turbo is going??
  245. Exhaust
  246. Twin Turbos
  247. stuck in 2nd gear
  248. No real power till 1,500 rpm
  249. Question
  250. carrier bearing??
