- Hood Stack on a '92 truck to play around (opinions needed)
- Tranny
- 1989 Dodge Cummins Commercial
- K&N air filters
- non-ic injectors ID
- Installed HX35w 12cm. Where is the shove in seat?
- converting from ve to p7100
- Fuel pressure guages.
- VE full load screw
- Put pot in my 91 and still no OD
- Oil Leak
- HX35 vrs stock head gasket?
- vehicle speed sensor question
- fuel inlet
- injector pump timming
- Little help for a fellow bomber
- 91 cummins for sale
- 4x4
- fuel system
- cold = dead battery?
- transmission
- getrag
- Christmas came early!!!
- Its video time again
- 91 D-350 has no od
- airdog II question
- killer pin
- starter
- non IC hp over IC injectors?
- Fuel Pin Question
- timing question
- Just bought a hx35! install Q.
- Ahhh winter.
- Injectors and fuel pin
- Injection pump problem
- got new injectors!
- Inj. pump mods make no change
- Electrical Probelm HELP!
- what gauges do i need
- Killer Dowel Pin question with a pic
- HX35 turbo
- Looking For Some Better Spool Up, M&H M2 Fuel Pin?
- Injector #3 NOT COMING OUT!
- need new injection pump, any advice
- First gen 12v NON-IC injector o-ring kit
- Air dog fuel pump.
- anyone know what this is?
- were to get
- Adjustment Screw Questioni
- 1989 12v pump
- to charge or not to charge, thats what my gauge cant decide
- Turbo question.
- 12 valve cooling question
- 6 spd tran swap
- injector install
- What it rag or getrag?
- rear end
- How much boost?
- idle
- new fuel system questions.
- no start
- Automatic Transmission Manual
- operating temperature
- help with wiring problems
- Trying to plan out my twin turbo setup!
- 4wd part
- Rear end clunking
- How can i get 450HP out of a VE pump?
- Pump problems - HELP
- 1st gen exhaust manifold
- boost line
- choosing injectors
- hard starts
- grinding noise after start
- pump spring 3200 or 4000 rpm
- Air Dog 100
- lift pump
- M&H M4 fuel pin
- what I learned from a stock clutch
- Help!!!!!!
- '92 with no charge from the alternator
- oh
- 93 dodge dually
- Some misc questions.
- 1st gen fan
- tps
- runnin like crap
- jake break
- Rear Axle?
- 2wd to 4wd
- Transmission Wiring Problems On 93
- Interior project
- My 93 dyno numbers.
- injectors
- How do I remove the ABS
- Well, Found The Limits Of The 727 Tranny
- New guy needs turbo upgrade
- peobryant or thomas.harris22
- Combinding mods.
- Cold start timing advance?
- fan
- Clean Out Your HVAC Box
- 1st Gen Sticky
- holset hx-40
- The Bosch VE Pump And You
- My New Toy--93 Dodge Cummins
- '92 W250 Skyjacker 6" lift question
- Coined dually wheel explanation please!!
- polished 12v valve covers
- my 91 dodge cummins started losing power
- M2 fuel pin update
- transmission leak?
- garret turbo
- 91 Cummins Upgrade Advice
- finally p pump conversion
- getrag
- more fuel at WOT
- fuel shut off solenoid
- calling all tranny gurus
- intake grid heater question
- NEED AN EXPERT!
- That time of year
- found a 1st gen, is it worth it?
- Auto Tranny help
- ARP STUD WTF??
- turbo ?
- I got 20s tell me what you think!
- clutch
- tires
- wheel/tire combo's & leveling on 2WD 1ton SRW??
- TV cable problems
- 46rh shift linkage question
- smoke?
- just got a 1991 12v what is the best first mod?
- FASS fuel system help
- no 5th gear
- Turbo
- help! cooling system left me stranded
- Injector's
- New to Dodge diesels
- Purchased my first real diesel
- wiring 89 cummins 6bt to 1989 jeep grand wagoneer
- KDP fix
- Straight Axle Conversion
- Dually tire sizes.
- Bench seat in rear of Ext cab? Anyone try it?
- Looking for 1 Gen Info
- New Truck
- tractin bars
- 12 valve help
- 93 cummins Advancing Timing
- 93 cummins with auto trans - need help with trans cooler lines
- intercoolers on 1st gens?
- Best place to get rims for 1st gens
- Does anyone have VE pump Schematic?
- HELP! Throttle linkage washer size
- mechanical lift pump to fuel pump
- 4" exhaust
- trade 400ex for cummins
- transmission hiccup
- 8.5 liter turbo on a first gen?
- INJECTORS
- question about automatics transmission
- Queer Steer
- Denny T fuel pin ?'s
- Captain's Chair tilt feature: broken
- lowered 1st gen cummins???
- AIr Bags on 1st gen
- 1990 2wd 1ton
- 5 speed
- M&H fuel pin
- band ajustment
- need a tach
- Speedometer grief
- idle is too high
- s300 or hx 40
- Trans swap advice
- Air Dog Install
- Fuel Pin Stuck?
- Fuel preasure guage install
- Shifting problems
- it'd figure...
- school bus
- ARP stud torque specs please
- turbo questions.
- nv 5600 retrofit
- ats turbo's
- Dodge power steering woes.
- 47rh conversion
- head gasket
- run time
- 89-93 body parts... interchangable???
- got my cummins smokin!!!
- waste gating?
- Intake?
- Boost installation
- Whitney Houston we have a Problem!
- turbo talk
- first time takin rojo to the tracks
- 1989 questions
- Help a Newbie !!
- Hey all you 1st genners...
- injectors
- What's wrong with my truck?
- A518 to NV?
- A518 to 5 Speed
- Fuel tank size.
- lookin to buy 1st gen cummins
- Dually Disk Brake Kits Now Available....
- 62/65/12 S300
- steering gear seal
- lower egt's brainstorming
- Coal Train Diesel
- Rearend I.D. - 92 Dodge
- Dodge Cummins! I Need help
- need a turbo
- MARINE PARTS
- injector
- rutrow shaggy.
- where are they
- death wobble
- what torque converter?
- What did I do???
- Splicer gearbox
- Q's about HX35 install
- transmission upgrades
- Need Help?
- need some help
- front suspension sagging
- 1st Gen Steering Systems
- FIRST GENERATION CUMMINS
- HOT ENGINE TEMPS
- hot egt's
- wierd boost numbers
- adapters
- head gasket
- downpipe
- Gauge Mount ?'s
- Alternator
- LOOKING FOR AN IDEA
- NV4500 clutch kaput...dual or single?
- Just bought
- Best exhaust
- 98 duramax turbo on a 1st gen
- AFC boost tube fix
- 1992 D250 Dually Conversion
- Which generation model is best for my application?
- Clutch Recommendations’
- I love my new governor spring!!
- Wanting a 5" stack.
