PDA
View Full Version : 1st Generation Dodge Cummins 89-93
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18
  1. DIY Upgrades?
  2. Governor Spring swap problems
  3. What you got for shifters guys?
  4. volt gauge and lights
  5. Leveling kit
  6. my first post i want 350hp
  7. he351 vs hx35
  8. slipped timing???
  9. 12 Valve lope..?
  10. kdp advice
  11. Runs away for what reason???
  12. where to find a getrag 360 speedo wire
  13. 95 dana 70 into a first gen
  14. nv5600 install
  15. cruis control wiring?
  16. trans temp port
  17. S300
  18. No start
  19. Opinions on Twins
  20. Newbie gear question...
  21. running out of options
  22. Value of an HT3B???
  23. ve to p-pump conversion
  24. Powersteering pump...
  25. Electronic add-ons
  26. Injectors
  27. Air Bags
  28. 1991 I/C 5.9L Head gasket failure?
  29. 1989 6bt piston ring gap???
  30. Manual trans swap
  31. Tires
  32. What do you guys think? Good deal?
  33. building with fuel economy
  34. cab mounts on 91
  35. 2WD to a 4WD how hard???
  36. GDS 60mm with Stage 3 DDP's?
  37. 727 grind
  38. Tires and Rims?
  39. 1992 W350 Rebuild
  40. braking problems
  41. Oil Filler
  42. Dual Exhaust
  43. boost question
  44. dr side door
  45. Can I? or Should I?
  46. Windshield Wiper Electrial Issue Please Help
  47. what is the best suspension to buy
  48. no 1st or second gear.. Bent shift forks down???
  49. Injection pump problems
  50. Injection pump problems
  51. Door Rattle
  52. cruise control question
  53. white smoke
  54. Waste Gate Question
  55. piston lift pump
  56. The seventh gauge
  57. clearance between radiator and fan
  58. How much is an hx 40 worth
  59. How To: Advance Timing on VE Pump
  60. 12v Cav IP to VE IP
  61. horse power/torque estimate
  62. Bolt pattern help
  63. Achieving 250 hp.
  64. 1st gen questions
  65. ATS Anybody
  66. So i was sittin around and thinkin
  67. Clicking
  68. show me the homeade bumpers
  69. BIG PROBLEM.................
  70. Pyro Wiring
  71. bigger injector lines
  72. 12v exhaust question......
  73. rear brakes make high pitch sound
  74. Leaky VE pump question
  75. The plan for my tow vehicle
  76. Bad news....
  77. First Gen Twin Turbo Kit?
  78. Idles a little rougher when cold now
  79. dash wiring issues
  80. pro parts pods
  81. Its not diesel fuel in my diesel....
  82. turbo advise
  83. 1993 cummins temp question
  84. Changed tranny and motor mounts -- shakes like crazy!
  85. New work truck
  86. electrical help needed
  87. sump verses draw straw
  88. p pump on a 1st gen?
  89. problems
  90. Turbo upgrade.
  91. Power Windows not working.
  92. jus got new truck, 92 cummins single cab single wheel 5speed 161000k no hitches
  93. Need help! Cam questions
  94. VE Pump Idle Adjustment Tricks?
  95. NEED HELP TRUCK WONT START NO FUEL
  96. questions about wheels
  97. couple questions
  98. reverse lights
  99. Air/Fuel Separation System
  100. can someone help me with my truck
  101. Adjusting the factory steering box
  102. radiator blues
  103. How to lope???
  104. steering shaft
  105. 1st Gen Dead-No start
  106. h1c question?
  107. Coolant temperature fluctuating
  108. Found a suprise on my engine
  109. intercooler
  110. will a transfer case swap
  111. new 1st gen owner
  112. Cost of P-Pump conversion?
  113. h1c turbo ?
  114. Injectors
  115. 89-91 NON I/C motor valve adjustment question
  116. Disc Brake Conversion
  117. ZF
  118. Our new winter project..
  119. Lets see the 1st gen flatbed's.
  120. Stuck ve injector pump gear
  121. Lets see under your hood!
  122. What's this electrical component?
  123. 1st Gen ARE fiberglass bed cap
  124. 1993 cummins problem
  125. Injector pump freak out
  126. Lifting a first gen
  127. How many miles is on your 1st gen?
  128. Transmissions
  129. In Tank Fuel Pump
  130. bearings for getrag?
  131. How to Instal 3200 rpm gov spring in VE pump?
  132. BIG PROBLEM
  133. 91 cummins fuel screw
  134. first gen 12v injector Q?s
  135. No cruise and the tach won't work
  136. 1991 2wd dually FRONT LEVELING KIT???
  137. Truck wont start
  138. Heater problem
  139. Lets see some 1st gen sled puller, drag racer pics!
  140. Lets see pics of your 1st gens in the mud or snow or both.
  141. What did you do to your truck today?
  142. Lets see pics of everybodys wheels and tires and lifts
  143. What made you want to buy a 1st gen and how much did you get it for?
  144. H1C TURBO QUESTIONS
  145. low oil pressure
  146. New to site with auto trans problems.
  147. weird ticking under acceleration
  148. from ata to wta intercooler question
  149. Oil in radiator/loss of oil pressure I/C'd motor
  150. electrical problems. help!
  151. 1993 Dodge W250
  152. check out my new stack
  153. 1993 Dodge W250
  154. tranny swap
  155. Supercharged 1st gen?
  156. need help building a air intake
  157. Turbo
  158. VE Injection Pump leak
  159. need some input on installing a stack
  160. Oil in my intake, Leaking injectors, and exhaust leak!!!!?
  161. Triple Pillar Gauge Pods???
  162. manual transmission question
  163. need some input on what to do. HELP
  164. turbo problems
  165. Swapping my stock turbo for an HX35? any input?
  166. Grid heaters
  167. OEM Mirrors?
  168. will race for food (broke college kid)
  169. where do i get rear brake lines
  170. Any effect?
  171. Another NV4500 Swap
  172. Rear bench seat in ex cab
  173. 1993 W250 Stacks!!!
  174. vents not switching to defrost
  175. Best Gears for W50?
  176. Cummins Expert
  177. Injection pump recalls??
  178. timing gear alinement HELP, HELP
  179. annother many issues thread :(
  180. Transmission Suggestions?
  181. Bosch 230 Injectors
  182. Garrett GT3271 Turbo ?'s
  183. brakes locked up now have no pedal
  184. ATS Trans ?
  185. INJECTION PUMP TIMMING
  186. Fuel Heater?
  187. help
  188. Transmission Issues
  189. truck parts
  190. need input from anybody running a dual stack set-up
  191. Please help need advise on water meth setup.
  192. another wiring problem
  193. Another 'what's it worth' thread
  194. Transfer Case
  195. possible new turbo
  196. what you guys got for lights?
  197. Custom Boost Reference Line
  198. 2nd gen 4'' down pipe on a first gen?
  199. 2wd to 4wd conversion
  200. 93 cummins wont charge
  201. 2nd Gen dual exhaust on a 1st gen???
  202. Torque Converter
  203. Input shaft removal on a getrag
  204. Chevy NV4500 in a first gen?
  205. Injector questions
  206. 5.9 CTD frt & rear seal vendors
  207. over head
  208. White Face Gauges
  209. 1990 Cummins Value
  210. help me find a first gen
  211. headliner
  212. cab AC interchangability
  213. Anyone whos had a torqure converter problem or converted to A518 tranny help?
  214. Thermostat Housing
  215. TDC and valve lash
  216. 1993 ext cab jump seats
  217. need some advise.
  218. injection pump leak
  219. Not Electrifying
  220. Lifting 90 w250 4"
  221. electric fans question
  222. intercooler
  223. Motor Mount Torque Spec
  224. Grey - white smoke
  225. Possibility of a Reg Cab Short Bed w250 Cummins..?
  226. Leaf Spring Swap W350 to W150 Springs
  227. windshield wiper arm
  228. fuel tank
  229. head bolt problem
  230. strange ticking noise at back of engine
  231. injectors!
  232. Elec. problems...
  233. '92 W250, Possible?
  234. 91 W250... Should I buy it?
  235. fuel treatment
  236. Help fuel leak at vent
  237. what kind of bucket seats do you guys have
  238. MPG penalty with wide tires
  239. Intake Manifold Swap
  240. need body help
  241. BAD 12 VALVE
  242. new injectors big problem
  243. ole shakey
  244. First gen questions
  245. building a 1992 w250- takes two to make one
  246. Many questions needing many answers!!!! Help!
  247. 1993 Dodge Diesel - high reving
  248. My Baby Got Cut Apart...
  249. lets see those bumpers!
  250. turbo,injectors,and squeaking?
