PDA
View Full Version : 1st Generation Dodge Cummins 89-93
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18]
  1. A/C Blower Motor And Or Switch
  2. Parts Help
  3. Dually Tire Question
  4. Truck Engines Used As Industrial Engines
  5. Fuel Pressure Question
  6. NP 205
  7. You May Have Seen This Truck In The TDR Calendar
  8. Part Numbers For Lift Pump
  9. Whats Kind Of HP Numbers Are You Guys Getting With A Rotary
  10. New To Site
  11. THE VE PUMP AND YOU.......
  12. Shifter Assembly
  13. Step By Step Injection Pump Install
  14. Heater Problems
  15. More 1st Gen Part Numbers.....
  16. Dana 61 Info
  17. Where To Buy
  18. Head Gasket Under Boost
  19. Fuel Pressure Problem
  20. Battery/Volt Guage
  21. Cleaning Injectors
  22. 1st Gen Rearends
  23. IIIINNTRODUUUUUCINGGG......
  24. Need Some Advice
  25. Lift Pumps
  26. 16x12 Or 15x14 Steel Wheels
  27. How Long Will It Last
  28. New Injectors, I Think?
  29. Trans. Temp Gauge
  30. Reflective Rear Window
  31. Fuel Economy
  32. Killer Dowel Pin...In 1st Gens.
  33. Jumpy Speedo
  34. Hotrod VE
  35. Veg Oil
  36. Tranny Fluid Change
  37. Door Panel Clips
  38. Where Are All The 1st Genners???
  39. Grid heater?
  40. Help needed near S.A. tweaking a VE pump
  41. Headlight Rewire With Relays
  42. How Are Water Pumps controlled?
  43. VE Pump
  44. what is up with this thing
  45. Online Manual
  46. What Turbo Is This?
  47. Overdrive Systems for the 727
  48. What Guage Pod is this?
  49. Need bigger exhaust
  50. Selectro Hubs
  51. I NEED A DRIVERS SIDE DOOR
  52. HELP! Truck rides like a rock
  53. spacer and trac-bar ???
  54. Fuse Box Pics Please
  55. Need some advice
  56. Which Exhaust Housing Do I Have?
  57. Cruise control
  58. red seats
  59. What brand of ATF
  60. So, my neighbor has this 89.......
  61. I See Some Familiar Faces Here!
  62. another place to talk first gens
  63. Smoke/Performance
  64. The Other Forums???
  65. Show Us Your First Gen
