- What to use?
- strange idle in the cold
- finally got my truck on the road today!
- Real motivational!
- custom interior
- BUYING
- about to beat my against a wall
- how much pressure should a piston lift pump have?
- getting started in a 91 ctd n/i...
- 518 over getrag
- no blower help!
- inj. pump leak
- 46rh valvebody
- 3200rpm fuel pin
- Super HX40/16 and 14mm pump head
- a518 question
- fuel in fuel pin hole...
- I need backup light sockets for my 90!!! WHERE CAN I GET"M
- Sending unit
- cheap parts
- fuel pin
- first gen truck parts
- More A518 questions?
- hx80
- A518 and 47rh
- Bucket seats
- power steering question
- p pump motor swap
- Fixing Your KDP On The Cheap
- 1st gen auto
- Turbo rebuild
- gauges
- Turns on the pump
- injector lines
- getrag
- 1st gen chassis splice
- Trim Holes? how to fill?
- tach
- over drive
- What to look for?
- 1st gen motor
- hx40 questions
- tv81 turbo
- 1st gen speed sensor
- 1st gen. pulsing voltage problem
- Prices of VE pumps?????
- Timing bump?
- turn key and no start
- Auto problems... First loud whirring, then no movement.
- Switch on ve pump
- front end hops
- 2wd getrag VS 4wd getrag
- do i qualify?
- whats the best clutch
- G360 to NV4500?
- Harmonic balancer installation Q?????
- for all you guys with s300's and hx40's needing a 4" downpipe for a 1st gen truck
- dodge w350 will not go over 35
- Pump swap
- Help little bro put 87 oct in my diesel what to do?
- Hx35 and 12cm
- BD Valve Body
- Best Source for Compressor Wheel...?
- top speed?
- wastegate question
- Ranch style bumpers
- TRUCK WONT TURN OVER!!!
- POD's
- Tranny Problem
- Ok. Tomorrow the motor is going to be on the ground.
- lift pump robbing power?
- good idea or just plain stupid?
- spacer for piston pump?
- bronze shavings in the tank
- Replace Your Camshaft, Lifters 'n Stuff . . . .
- 1st gen questions???
- heat grid
- Timing Advance
- mega problems
- denny t
- getrag shift tower all jacked up
- Getrag woes...
- fuel lines
- rear brakes
- 1st gen 1ton wheel cyl
- needing some new shine
- Cummins B5.9 repair & troubleshooting manual pdf download
- classifieds not much there!
- hx35 housing the same as hx40?
- front brake backing plates
- air dog II
- Cab Lights
- What turbo is this?
- Use cruise servo as idle control/hand throttle?
- grille guard
- vacuum 4x4 motor
- hc1 on one ton?
- Arm Rest 93 Dodge
- block heater
- No Lights please Help
- body work
- Happy New Year
- Pump swap
- Twins Finally Installed!
- Injectors yey!
- clutch problem
- South Bend clutch install
- Retorqueing head bolts?
- solvent, oil?
- Wait To Start?
- Turbo for 5x.014s
- Installed new shutoff solenoid, now have power problems...
- How tall of tires for 2wd?
- Stripped Bolt HELP ASAP
- 24v power steering pump on a 12 valve?
- Help,broken cooling fan!
- Shift kit suggestions
- Getrag Grinding
- Sticky Articles and Casino Cash
- harmonic balancer problem
- 5-sp shifting issues
- Check Engine Light Trouble Codes For 92-93 1st Gens
- Anybody got a 1st gen sittin around? I need a part bad
- Need some opinions!
- Motor Maintaince
- Howdy Guys!!!
- Locker for Dana 61
- Bouncing speedo
- turbo Question
- 3rd gen intercooler in a 1st gen.
- Brakes don't seem to be power
- Best Exhaust Housing for Damon... :)
- Cool Down?
- power steering????
- Speed sensor pics
- Vehicle speed sensor
- gauge
- pod injectors
- fenders? Rust?
- turbo questions
- w350 mpg's
- AFE Air filter
- Fixing the ride of my 1st gen (or at least making it better)
- Aftermarket Speedometer
- looking for a diagnosis ??
- lost power
- Cruise Blues
- In Need of Bed for 1st gen
- tranny problems
- Need some advice.
- 370's and 435's
- hx40 exhuast housing question
- Stock boost?
- ...progress...
- NHC 250 needs a turbo ?
- Troubleshooting
- suspension
- FUEL ECONOMY
- Smoke from flange on turbo????
- wont stay in 5th gear
- Anyone towing??
- smoke
- THROTTLE POSITION SWITCH PROBLEMS
- bigtime problem
- 6bt exhaust flange
- governor problem???
- manual locks and windows to electric?
- Getrag Shift Kit?
- power steering fluid foaming and expanding
- napa clutch or southbend clutch?
- Problem Fixed
- 81 Dodge Crew Cab Cummins project
- voltage regulator woes
- Lowering?
- Shift kits?
- spare 12v cummins
- hx35w v-band flange????
- nv4500 rattle (forks or throwout)
- getrag
- No Charge From The Alternator.
- 4 gear ?
- what turbo should i upgrade to?
- I am curious
- Lights problem
- boost screw on pump
- Hx35w
- Overfill?
- CD player
- Gears
- driveshaft length
- Turbo upgrade Sugestions
- Insulation?
- First gen cummins No spedeometer or wait to start light
- how to beef up a getrag
- No spedometer or wait to start light in 91 cummins
- Transmission cooler with fan under box
- rebuilding injectors
- Which Fuel Pin
- plastic trim parts for a First Gen
- Plastic trim for wheel wells
- Front Drive Shaft
- Hey Smokem
- cab mount bolts
- New Member with a new truck and a question
- 93 dodge trans cooler/under bed??
- Intercooling my 91.0
- How much is it worth?
- shut off solenoid
- shaving stock fuel pin
- My 93 on the rollers
- 14cm Turbo housing and 60mm housing
- Hood stack
- Seats
- switch from auto trans to getrag
- Intake manifold
- need some input
- 14cm turbo housing
- new here with a turbo question. need help asap
- Finally got one
- Primer
- tachometer
- turbo
- Fuel pin pics
- cummins 855 turbo
- exhaust
- Well Im pretty sure my torque converter took a $#!@ today...
- Virgin pump?
- TPS
- the inside of the getrag
- Auto OD question
- Gauge pods
- Transmission Swap
- Fuel Pin Videos
- 4" exhaust system for cheap?
- Crazy Fuel Pump
- Billet Adapter Plate?
- Stock truck with bottomed out star wheel?????
- gov spring 3200?
- GDS 60mm upgrade vs hx35
- replaced inj. pump
- Fuel pins
- Truck Value
- Adding Boost?
- How far did you guys go before losing MPG?
- looking at buying a 1990 Dodge
- Clutch assembly
- help with pump timming
- Wiring wierdness Or How Many regulators does it take to ......
- Hood Stack on a '92 truck to play around (opinions needed)
- Tranny
