- ligts n' stuff
- 1st gen shackles n hangers/brackets
- Tach Question
- Seat Swap - outside the box
- replacement injection pump questions?
- my new 1st gen
- 6" Lift
- Suspension Questions
- 89 Dodge 12v 5.9 1 ton dually Mods?
- Ball joints?
- 89 dakota gas to diesel swap info needed
- In need of new injectors (LOOK S
- Speedo ratio box soure....here where to get the parts!
- What gearing would be Better?
- needs some info on turbo's
- my new 93
- Oil filter housing cracked?
- Power screw
- blown head gasket
- Adjusting star wheel on ve pump
- oil blowing out of overflow for rad
- Tourque converter recommendations
- 92 w250 budget build
- 350 Dually
- shift lever
- Fuel Shut off Solenoid
- My truck for this truck
- 1gen cummins grill
- Compression testing
- Overcharging
- Where to start first
- A few questions about my ve
- HELP!!! 1993 12VALVE LOSS OF POWER
- Injectors & stuff;
- Anyone in Texas?
- Dodge Seats
- fuel filters
- 92 cummins overhaul forgotten parts
- seat belt help
- how to diagnose a bad fuel shut off solinoid?
- injectors for P-Pump Swap
- HD Steel Bumper
- well got it up for sale
- Gov. Issues???
- Questions about basic mods and EGT
- should i get this cummins ~ ?
- 03 powerstroke replaced with a 93 cummins!!!!!
- tachometer?
- Front Chassis Question
- 727 TV cable ?'s
- Lift kit
- Strange issue when down shifting
- shortbed cummins swap in progress!
- Lift kit questions
- How can I tune my truck to ge the best MPG
- timing & cold start & block heater
- 91.5 cummins
- width of dually first gen
- what did i do wrong with my ve-pump?
- 1st gen buying guide
- traded my dodge cummins for a toyota pickup :)
- 1985 Dodge W250 wiring harness replacment?
- 1991.5/2004 swap testing interest
- what color should i paint my truck ?
- Cummins Won't Shut Off (Yep Another One)
- Air in fuel, and ve pump leak
- How many kilometers/miles do you get on a tank ?
- T-case/diff problems, need some help!
- New fuel pin install problem.
- Grid heater troubles
- Boost question...
- Which Tranny?
- Cold start concerns
- Rear end question
- top speed
- 93 12v in a 06 f350
- Question about an 89' 5.9 rebuild
- bench seat vs good buckets with console
- Suspension and Steering Replacement
- 92 cummins piston lift pump
- Photo of my new rig 1993W250
- Turbo/injectors, looking for opinions!!
- air intake setup
- Need Help with steering please
- My stock truck pyro gauge only goes to 600 ?
- Pyro gauge probe infront of the turbo
- Tranny patern
- How to make intake horn
- How do i read my Pyro gauge ?
- Got stuck! no more speedo or o/d
- Feel like giving up
- Opinions on Hx-40
- Dont you guys feel like beating the $hit
- Should I get a profesional to install my gauge ?
- new injectors
- I got a pyro gauge for 280 bucks , kinda pricey ?
- Electrical help needed
- parts truck !!!!
- Bumper to heavy ????
- 1993 Inline overdrive
- need help asap!!! have to bleed it every time i start it!!!
- Exhaust haze
- Pyro Gauge ?
- Marine parts? Will they work?
- smoke and breaking up
- Transfer Case
- 91 cummins smoke
- turbo seals?
- what gauges do i need ?
- 91 8 foot stepside?
- I ordered the DennyT fuelpin 2
- Dieserl Dan E
- Lift Help
- 1st gen lope
- Poor MPG with HX35
- fuel pin help ?
- RWAL issues
- update to last post about transmission swaps
- need some answers to transmission swap questions
- transmission rebuild ?'s
- Transmission issues
- half ton cummins swap????
- Odometer Repair Not Working
- Anybody got a ve pump there not using??? Really need a special part!
- rebuild 727 vs getrag swap
- Factory seats
- 3 inch downpipe to 4.5 exhaust
- 1st gen turbo
- Get rid of blocks
- Gov spring and fuel pin..truck wont start still!!
- 4 inch exhaust
- opinions on paint!!
- warm start issue
- 92 VE wont start Bought this way on the cheap!
- Gov spring and fuel pin...truck wont start
- 3200 gov spring.....please respond
- where to start for performance modifications
- looking for interior trim
- Power Steering Pump
- Honestly dont know where to start...
- TANK SEDNDER PROBLEM
- What do i need-holley black
- 85 crew cab build
- lookin for a W250
- trade my 2nd gen for a 1st gen?
- Speedo gear
- Turbo Silencer Ring
- Fuel screw caps...
- fuel pin and star wheel
- headache racks ?
- new front driveshaft
- 91 5.9 turn fuel up ? ve pump
- how to tell what ecm i have and what model i need?
- 1st gen with p7100 pump NO POWER
- white smoke
- leveling kit help
- power adjustments?
- where to find the proper positive battery cable?
- got a new 1st gen
- towing capacities for automatic non lockup
- truck shakes when ideling
- blue and white smoke on cold start
- Speedometer/Odometer ...
- Bleeding the brakes
- gauges
- D350 advice
- Performance Intake
- new truck leaking injection pump
- I almost bought this truck
- Egt's??
- 1st Gen B|ock Oi|ing System Type
- i wish somebody would've showed me these
- slight white smoke and miss
- Diesel bombers swag?
- Spooling or loping or...????
- oil return line questions
- VW fuel shut off solinoid model year?
- Muffler
- automatic trans swap from 2wd to 4wd
- piston style lift pump swap worth it?
- Really bad thick white/blue smoke
- Fender stack
- simple shift controller
- Axle swap
- Grille swap
- borgwarner s366
- 2nd gen seat
- wierd noise/knocking then goes away?
- 90 degree intercooler elbow
- Banks Replica Manifold for 1st Gen?
- Banks Manifold for 12 Valve?
- 5x.014 injectors.... Turbo?
- Stock injector nozzle mods
- what kinda mpgs
- VE Pump Timing Issue?
- Radiator cover
- Goose neck brand flat bed for sale or trade for regular dually bed
- How much HP???
- Oil LEAK!
- no power NO SMOKE
- Fuel pump?
- Too Much Timing Advance
- Artcitc camo wrap on 1st gen?
- Denny T vs M&H M5
- No power with full tank.
- check out this BAMF
- need help with what parts i need to rebuild my tranny.
- if it aint one thing its another
- Throwing some hp through a Getrag????
- Injection Pump recall... 1991-1993
- What 12v 6bt Cummins should I put in my Chevy
- timing injectors???
- mulitple questions
- air vents
- 1st gen
- prince of darkness injectors
- BUSHIN FOR THROTTLE LINKAGE
- injector?
- Indiana Diesel Clubs?!?
- NEED RIM HELP!!!
- new turbocharger
- Edmonton Alberta first gen members?
- 1st gen no power?
- NO Power
- Leaky injection pump... Opinions, please...
- wheel spacers
- anybody interested??!! LOOK!!
- DOORS LEAKING
- Smoked taillights?
- water in fuel sensor leak
- Transmission
- LEDs ?!?
- A518 Temp Sensor
- 1989 dodge cummins 300-400
- safe without gauges?
- first gen not much leg room.......?
- Duel tip exhuast for 1 gen any company's
- Hooks, Shackles, Clevises?
- cummins sparks?
- windsheild
- 1990 1 gen what it's worth
- 46re/h to manual conversion
- best for home brew
- Bio diesel
- transmission swap?
- Wiper motor turning counterclockwise
- Tie rod
- 215hp 2nd gen injectors on 1gen VE pump
- Need yalls opinion on a first gen
