PDA
View Full Version : 1st Generation Dodge Cummins 89-93
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18
  1. NEW headache rack and pipe !!! pics
  2. electrical problems I think
  3. water in fuel tank?
  4. Fellas......
  5. what else is needed?
  6. no power. ve pump issue? HELP!
  7. 1990 cummins wont crank
  8. torque convertor question??!
  9. Brake problems
  10. external voltage regulator issues HELP!
  11. TPS Question
  12. AFC cap ?
  13. Tow mirror build on 1st gen
  14. Fixing a fuel shut off solenoid.
  15. Seat swap trouble!!!
  16. What will a straight pipe change
  17. Getrag to nv4500?
  18. what gears should i use to make my gears longer
  19. Fuel Screw....
  20. White Smoke ?
  21. What would it take?
  22. What size IC is big enought?
  23. W350 1-Ton Cummins stalls
  24. tranny decisiom
  25. Quick Question !!! please respond
  26. need to know what the internal componets of the pcm on my truck are
  27. Fuel delivery problems- need some help
  28. Gauge install
  29. exhaust
  30. newb help
  31. How can I make a 5 inch tip for my pipe ?
  32. Fan bolt size for idler pulley
  33. 3200 gov spring installed truck wont run!
  34. Fuel sending unit...
  35. odd sound from my 1990 motor
  36. Strokin the I6
  37. Yet another seat swap thread...
  38. TIMING PIN
  39. Electrical headaches.
  40. What kind of transmission do I have????
  41. To gear vendor or not to gear vendor???.?.
  42. Making Straight Pipe
  43. what would happen if.....
  44. ideals for welding rig
  45. To swap engines or not to that is the question?
  46. Steering Box Help..Please!
  47. what mark do you set index on ve pump?
  48. Upper Radiator Hose Question
  49. cutting muffler ?
  50. Waste Oil
  51. Diesel Additive Help ? !
  52. Real HP with 1st Gens
  53. Front Oil Seal Install Questions
  54. 46RH Problems/Questions
  55. Do the intake horn shapes make a difference if it is IC'ed or not?
  56. P-pump conversion slash engine swap.
  57. Repaired my Gearshift the other day.
  58. loudest straight pipe kit for first gen?
  59. Tach Install
  60. Economy
  61. Hood emblem ?
  62. Fan Clutch Removal Woes....
  63. needs some some help!!! pulling my my hair out
  64. Horn Relay?
  65. Is this low mileage 1st gen a good deal?
  66. Is bigger better? 3" - 4" - 5"
  67. Metal Shavings in Diff
  68. Engine level Left - Right
  69. Let's play name the cause of the leaking on my injector pump!
  70. Overheating on long grades
  71. Abs and staring issues
  72. truck will idle for awhile and than go to full throttle by itself?
  73. Looking at buying a 1st Gen and just looking for knowledge
  74. Advice on suspension lift decisions....
  75. Notes to the PO
  76. tank straps? anyone make or know were to find em
  77. 1993 dodge cummins won't roll coal
  78. Lift Pump suggestions
  79. Turning a single wheel bed into dually bed... Any advise?
  80. Rear main seal
  81. changing synchros in getrag?
  82. All parts or some parts.
  83. WHAT DO YOU GUYS SUGGEST FOR A FUEL PRESSURE GAUGE AND WHERE TO INSTALL IT ON 93 D250
  84. 1990 Dodge Cummins (looking @ buying)
  85. Need Wiring Diagram for 89 Cummins
  86. 727 tranny fluid capacity
  87. SoundSystem
  88. W350 Custom wiring
  89. 1992 dodge cummins charging system problems
  90. Cold Air Intakes for First Gens
  91. Sluggish start from stop
  92. 1993 Cummins 4x4
  93. blocking off waste gate
  94. HEAD GASKET BLOWN?
  95. Killer Dowel Pin...
  96. 91 W250 need tires and wheels (Tulsa)
  97. turbo
  98. 1997 Ford Cummins Swap
  99. Looking for Getrag 360 upgrade parts.
  100. LOOKING AT A 1993 Cummins 5 speed. PLEASE HELP
  101. head work
  102. NV4500 swap from a 727
  103. TUNE-UP
  104. oil pressure? is this too low??
  105. when starting engine occationally goes to full throttle.
  106. low idle problems really need help!!!
  107. what would you do frame up restore?
  108. cooooooool air
  109. H1C to HX35 turbo swap
  110. first gen cummins dually finder
  111. getrag input shaft upgrade question
  112. Aux trans
  113. Installed water/methanol today
  114. What to do next?
  115. POD injectors for 1992 intercooled D350
  116. H1C Turbo Charger (Stock) How to Wastgate?
  117. Defroster in a 91.5 ???
  118. Selling my 1st gen
  119. rebuild
  120. Odometer won't work
  121. turbo
  122. issues with my electrical
  123. dodge 1st gen lighting problem
  124. Getrag trans removal questions/internal questions
  125. New to me 1992 D350 Extended Cab Cummins
  126. More Boost?
  127. tire rub and drag link issue
  128. new to diesel world and need help
  129. Need 1991.5+ Radiator Pics!
  130. found a 1992 cummins
  131. How to make 450/500hp?
  132. o/d kicking in and out
  133. Brought my new 980 pound toy home today.
  134. Transmission options
  135. Hey guys get on the wagon
  136. Aftermarket injector nozzles
  137. To stack or not to stack?
  138. Lifting a 92 cummins
  139. pillar pod
  140. lookin to mod my 92 HELP!
  141. Hx35 upgrade
  142. big project.. would appreciate your input
  143. Smoke switch
  144. Rotary Pump dumping fuel between the pump and timing case!!!!
  145. Door Locks?
  146. intake mani
  147. Transmission install
  148. What mods first for my first gen
  149. 1992 trans swap
  150. Alt not charging!!
  151. AFC banjo bolt washer....
  152. speedo only works in reverse?
  153. more charging problems..
  154. upgrade turbo to HX35W?
  155. vibration
  156. 93 w250 worth the effort?
  157. HP Estimation?
  158. cummins teardown
  159. NV4500 vs Getrag, pump timing and any other help...
  160. 1991 Cummins 4X4 Wiring Issues
  161. 1993 charging issue
  162. Transmission toughness?
  163. 91 d350 wiring/plug
  164. KDP Kit
  165. innercooler questions (duramax)?
  166. Grid heater help!!
  167. Turbo housing horsepower gains
  168. 3200 govener spring
  169. Exhaust sputters!!!!!
  170. plasti dip?
  171. Upgrades for truck
  172. 93 not charging, no speedo, more?
  173. VE Delivery Valve Question
  174. Radiator may be no good.
  175. power steering fluidleaking into my engine
  176. 1990 w250 running but won't stay running
  177. Steering gear
  178. and more brake problems...
  179. This ever happen to anyone? Wheel problems
  180. Speedo problems
  181. Fuel Sending Unit
  182. how much life does this truck have left?
  183. Wanna know what stacks on a D250 looks like
  184. Lets see your 1st generations
  185. Best way to paint 1st generations??? HELP
  186. Transmission slipping
  187. K&N air filter for 93 D250
  188. Wiring Issues
  189. Mounting a pillar gauges.
  190. SERIOUS mod list help?
  191. 1st annual ATCO raceway diesel nationals in new jersey
  192. Leveling Kit?
  193. Throttle pin/fuel pin
  194. betrag 360 issue
  195. 1989 Dodge t.v cable
  196. Trans Trouble....Help!?!?
  197. Governor spring installation
  198. 1st gen vs 2nd vs 3rd
  199. Wiring problem.
  200. Truck wouldn't start in loading bay
  201. Finding More From the VE
  202. Fuel pin problems
  203. shuts off when going in reverse
  204. 89 dodge project
  205. Perfect Pillar Pod for First Gen
  206. Fuel Shutoff solenoid....no voltage.
  207. 1st Gen overcharging
  208. Transmission Lugging Motor Down AGAIN!!! HELP!!!
  209. looking for a part....
  210. Dual Filter Setup
  211. 12V to a 24V Head Swap???
  212. Hose from turbo to waste gate canister
  213. hood stack opinions/pics?
  214. Keep the 24v, or get the 12v?
  215. where to find the original dash mount tach for 1st gens??
  216. "universal" intercooler
  217. 22.5 rims on 1st gen?
  218. Engine sometimes stalls on inclines
  219. Need new bed
  220. 94 tilt column in a 93
  221. towing
  222. tow set up
  223. odo vs speedo
  224. warm weather issues
  225. Fuel plate?
  226. Anybody know what this is under the dash
  227. alternator and overdrive
  228. 518 Trans Build.... Best Parts???
  229. 1993 W350 & 5th Wheel?
  230. 79 crew coversion help
  231. HE351CW 1st Gen unclocked
  232. No power; turbo / fuel, need help
  233. Help fuel problems again frustrated
  234. 89 reg cab gasser into 92 cummins xcab parts swap
  235. New Emblems
  236. TPS and Cruise
  237. New Truck Project
  238. Possible Damage due to EGT
  239. Worth it?
  240. HELP!!!! I tried to manually ground my O/D and might have fried ECM?
  241. 6.7L into 1st Gen How Hard???
  242. Voltage question for a 46rh
  243. no reverse after rebuild
  244. Clunk when braking
  245. Transmission
  246. Anyone selling?
  247. Lookin at a 1st Gen. What do you guys think?
  248. Need help!!! Rearend problems
  249. boost problem
  250. Trying to get ahold of a rep from SDX
