- Need some help....
- ksb problem
- Transfer Case issue
- buying first gen
- 91.5 tranny-transfer case?
- fuel pressure loss PLEASE HELP
- is my tranny supposed to be like this?
- water/meth
- New, First post
- Tach Sensor 3 Wires What is What????
- what gauges do i use??
- 91 first gen overdrive help please!
- 90 12 Valve no start
- Need some advice on my tranmission
- Front wheel wells
- HELP 92 dodge cummins WHITE SMOKEIN
- My first post ever
- 1st gen 93 turbo wastegate mod
- 4" or 5" exhaust
- new guy with a question
- 4x4 donor question?
- Let's See Your Gauges
- EGT S
- 1st gen diesel
- Short throw shifter for the getrag?
- Electric lift pump
- Tach install on my 92
- TPS Throttle Position Sensor Question
- injector pump
- Pics inside fuel screw questions
- 1st gen restoration
- Where to tap in for boost gauge?
- Headlights are surging
- Getrag Shifter
- 1992 Brake pedal is real hard to push
- No heat, no fan.
- What is it?
- w350 drum leak
- I need to clean degreese my 1gen..Any tips on this?
- Fuel Return line
- 2 plastic lines
- KSB Leaking
- Tranny Question
- 1993 automatic
- nv4500 help
- Lets see those 2wds!
- 91 IC a little cold on startup.
- What air fliter are you guys running?
- 2 questions: fuel mileage and overdrive
- Nut bolt size
- On board air question??
- 1990 body panel
- 92 back up and runnin great!! Thanks MARK NIXON ,RSWORDS
- Where do i get this gasket???
- different harmonic damper?
- what size wrench for the fuel shut off on the injector pump?
- i broked my getrag lol
- I FOUND IT!!!
- New first gen added to the collection
- alternator question
- speedo acts like a tac
- paintjob for my 91 12vlve dually
- cummins wont run right
- Cummins Swap
- 47re 47rh 518a 727 to the 205
- P-Pump Swap
- Sharp turning?
- steering problem
- What to do about my clutch?
- replacement headliner??
- 92 dodge trans Problems
- Dang Getrag
- New paint on the w350
- tires an wheels
- 1st gen 2wd to 4wd
- help me!
- what to look for in a 1st gen
- 1st gen lovers are gonna like this
- 241 dhd to getrag
- Can anybody tell me my inj.pump timming.
- HELP wont start!!!!
- Where do i but the threaded rod on ve pump linkage.
- after market dually wheels?
- fuel lift pump Wiring
- Starter options?
- 1990 odometer dosent work?
- 1991 D350 suspension
- NEw turbo
- Stock ve pump setting
- ride height
- Lift Pump
- alternator no charge unless high RPM, guages flutter
- NO TURBO!!!!!!!!!!!
- Injector washers
- Block Heater question
- Info center on my truck does not work!!!
- Holley Black? Install parts?
- Help no heater
- oil pressure low
- Shut off solenoid
- wont run wortha crap
- Star Wheel and Full Power Adjustment
- NO POWER TO THE KSB SOLENOID
- Grid Heater??
- help me with my cablights
- Transmission swap
- Power Steering issue
- What govenor spring
- hx 35 turbo question
- 1993 727 swap for overdrive trans
- hx40 swap?
- Injector Pop Test
- Clogged Injectors?
- Need Rag part
- Gear Question
- hx 35 go? no go?
- Alternator died
- driving along at operating temp and then my temp gauge droped
- Bumper
- need help beefin up my truck
- Tranny Issue
- math problem
- No Power
- where can i buy first gen captains
- Injector pump leaking
- Turbo not spooling and missing
- Dana 80 questions
- head lights mess with gauges
- Stock injector size?
- exhaust manifolds
- 91 dodge diesel
- fuel screw wont turn in or out
- leak?
- fuelin top of pump?
- Injection Pump Leaking
- HE351VGT turbo on 91' intercooled
- 91 first gen 5 spd 4wd (jake brake)
- best way to make an intake? fuel economy?
- drag truck
- Trani swaps
- speedometer?
- ksb problem
- Reverse psychology?
- will this work?
- Should I
- Will a 47rh bolt up to a 93 engine?
- Deal or no Deal?
- lights pulse bright and dim while truck runnin?
- rear abs
- need help, rear axle problems!!!!
- wires to rear diff ?
- lookin for help (still)
- Repo truck
- Need rear wheel hub for '92 d250
- Grid Heater Problem??
- 93 cummins whine from center consol
- Jake brake came with new truck
- speedometer
- any one have compression specs
- New owner of a 1992 D250 Cummins
- Need Help. Cummins barely moves, unique circumstance
- Free Horsepower
- Input Shaft Bearing
- A/C not working
- bucket seat options for a single cab
- Diffuser?
- Banjo Bolt
- water/methanol kit on 1990 dodge w350?????
- HELP PLEASE
- Wait to start never comes on
- Heatercore replacement info
- some new mods to the 93
- help !!!!!!!!
- 1991 Ram Window Regulator Loose
- Paint???
- NEED TO SEE DUAL EXHAUST
- Getrad Tranny
- Want a 1st Gen.
- 7.3 i/c
- Coolant smell questions
- Raced an 04
- Hey Everyone, Tell Your Friends!
- nylon washer?
- a518 wont shift. help
- FASS, AIRDOG, OR HOLLEY????
- A bad computer?
- 2wd
- Fuel questions
- 92 cummings diesel ????
- heater core
- Fuel injectors...Help!!
- All of a sudden high idle HELP>
- Power screw
- First gen steer coupler ?
- KSB solenoid leaking fuel
- fuel pressure drop
- Gov Spring
- 1991 cummins
- lift pump guestion
- smoke
- Quick Question
- Replacing valve stem seals?
- rebuilding the getrag sticky
- New dyno results and video
- help
- crack in head?
- bad heater core
- new turbo, Hybrid 40
- Silencer Ring
- Harmonic Balancer Wobble
- Classic
- 1st gen with inner cooler
- Dual Exhaust
- Changing Balljoints
- Torque spec question
- To much weight up front?
- upgrade
- banjo bolt
- R my injectors bad??????
- 3rd gen rims scored
- help me please!!!!!!!!!!!!!!!!!!!!!!!!
- smoke and leak
- egr brakes for 1st gen
- Boost loss
- Which lift pump???
- please please please help! backfiring than killed
- help! clicking noises
- 5 speed swap
- Getrag Rebuild Tips
- Pyro/Trans Temp
- New to diesel bombers!!!
- Maximum afc pressure capability?
- First gen lift kit
- Trying to find a spare
- kinda cool
- Help with bench seat on reg. cab please!
- A518 limits.
- Good cheap exhaust system
- The coolant vacuum valve on the heater hose.
- injector lines
- Where can I find replacement parts?
- 91 where to get leaf spring bushings
- after market head lights for 1st gens ?
- injection pump questions again! :(
- Injector question
- injection tip protrusion
- Clutch question
- What pump???
- Bad Luck Wednesday
- Vacuum Pump trouble in my 1990 D350
