PDA
View Full Version : 24 Valve 2nd Gen Dodge Cummins 98.5-02
Pages : 1 [2] 3 4 5 6
  1. hub assembly
  2. Is $1,000.00 a good price for an oem VP44 pump? Not a reman
  3. Front axle bushing replacement
  4. J-Hook (aka Turnbuckle)
  5. dont want to bother yall but need some help
  6. need help, buyin a new truck
  7. uneven idle?
  8. fuel filter canister removal
  9. im lost
  10. Voltage gauge randomely drops to 8v (somewhat long post)
  11. APPS adjustment
  12. ABS and Brake Warning Lights
  13. hard start in morining only when parked at an incline is my IP BAD?
  14. truck starting hard
  15. FASS?
  16. a little help
  17. Valve cover gasket?
  18. i need help with my 4wheel drive
  19. Van Aaken Smartbox Model 'R'
  20. vp or p-pump?
  21. Dirty Injectors
  22. charging ?
  23. Rear end rebuild time?
  24. body lift
  25. Hi people I am a newbie that needs your help
  26. HX40
  27. AIR DOG 150 froze?
  28. Manual to Power doors?
  29. Should I be concerned with HIGH Fuel pressure?
  30. maybe ECM problem nor sure? HELP
  31. NV5600 Noise
  32. pto generators
  33. Warm up problems!
  34. High Idle ?'s
  35. you will never believe this!
  36. Tranny does not like 2nd gear???
  37. About clutch?
  38. 24 valve stumbling
  39. Front axle poping
  40. Temp guage
  41. Best place to buy a vp44 pump?
  42. its been sitting up for 6 years!
  43. 99 dodge idles but no go!!!
  44. Is it a waste of $$$ and time?
  45. Need Interior Parts
  46. heres one for ya guys any one know
  47. 2nd. gen auto to manual swap
  48. What does a map sensor do and what would be syptoms
  49. Advise on finding a good shop.
  50. somegood & somebad
  51. 02 cummins tps code but not problem
  52. Fuel Mileage question
  53. New here...
  54. Overhead console lights on an 02
  55. Overhead compass/temp readout
  56. Clamping off Wategate line on HX35?
  57. fuel usage
  58. Low Cab Heat
  59. dodge wont rev above 2000 RPM's w/ 6 speed
  60. Injector pump
  61. Trans.. won't move until..
  62. About vp44?
  63. Hard to start below 30.
  64. Silencer ring
  65. touchy Throttle?
  66. MPG Drop
  67. 6th gear and reverse givin me fits
  68. Air Dog question
  69. trans issues? or just the nature of the TC
  70. wheels
  71. What is this part? Trying to chase down an oil leaK
  72. charging problems
  73. need a GOOD trans shop in eastern Pa.
  74. Misfire?
  75. Stacks
  76. how many miles
  77. 01.5 24v Questions
  78. Will an Edge Juice from a 2000 dodge fit a 2001?
  79. popping is constent
  80. 2002 Dodge Ram 2500 Diesel
  81. KDP Jig Kit????
  82. Rpm Idle???
  83. code scanner
  84. got a couple questions
  85. need your help
  86. 30 lb boost??
  87. NV5600 oil
  88. single stack problem
  89. blue smoke at start up
  90. erratic shifting 98 24v cummins Auto Transmission
  91. need help badly
  92. 2 Stroke in the Fuel
  93. 4WD dash light keeps going on and off
  94. idleing problems
  95. apps adj
  96. Hx or Hy turbo
  97. Shaking like Hell
  98. New question
  99. Shuttering about 70-75 MPH. Is it a lift pump?
  100. Battery Corrison
  101. heater core
  102. Transmission Cost?
  103. oil leaking from crank case breather tube.
  104. Wastegate
  105. Has anyone had a Injection pump death code 216 and sill have a good pump?
  106. Turbo leaks oil to intercooler. Can I replace a seal or rebuild turbo?
  107. Advice Needed
  108. need help bad please
  109. difficult to drive
  110. More problems with my Truck
  111. Voltmeter fluctuating
  112. Front Axle and 4X4 light Problem
  113. NV241 HD transfer case question
  114. Smoking too much?
  115. turbo was sqwuelling
  116. Need to know about VP44's
  117. Quick module question, DiabloSport vs. Quadzilla
  118. turbo?s
  119. Can I Stack Chips on my 01 24v
  120. 1999 auto tran
  121. Bit the Bullet
  122. Might have to sell
  123. power ?
  124. ecm location
  125. factory chevy 8 luggers
  126. questions about fuel filter canister?
  127. apps symptoms
  128. cabin filter
  129. manual trans swap
  130. New VP vs. Old VP
  131. Truck has been surging any solutions.
  132. Turbo shaft play help!!!
  133. Cummins won't start when hot
  134. Engine Trouble (fuel issue?)
  135. Need help from the VP guys
  136. whats thediff. and how can you tell
  137. question about idle?
  138. IAT and MAP cleaning
  139. Speakers size?
  140. So Who Can Solve This Mystery
  141. Who's E-Brake actually works with bigger tires?
  142. question about quadzilla xzt
  143. Ext oil coolers?
  144. a couple of questions
  145. hx40 turbo
  146. Injector Lines
  147. What do ABS+Brake+Speedometer+Parking break....,
  148. quadzilla stop the defuel?
  149. 1999 Dodge Fault code
  150. attintion all ladies and gents
  151. LP questions
  152. chip
  153. what do i do or use to fix this
  154. Headache Rack?
  155. batteries
  156. 53 block Crack repair
  157. Reman Kits
  158. Death Wobble?
  159. need help guys big problem
  160. Banjo bolt thread size
  161. Problems with Gates Rad hose
  162. 99 3500 auto trans trouble
  163. Honestly?
  164. Front driveline anybody...?
  165. Truck gettin a little hot while in traffic and around town.
  166. Intercooler
  167. push rods bent
  168. quadzilla addr. fuel press questions
  169. Taking a part the front axle
  170. Truck Popin On Acceleration with Edge in 5,4,3
  171. Had temp fluctuations... checked and noticed coolant is brown and muddy
  172. Need help with my trans
  173. to sack or not to stack
  174. Break in period for rebuild
  175. K & N Air Filter Cleaner
  176. Fuel Systems
  177. Quadzilla Adrenaline
  178. who makes it?
  179. FP questions
  180. Alarm Troubles
  181. which is safer?quadzilla adrenaline or Edge juice
  182. tow mirrors
  183. Trade your 3:73 dual rear for my 4:10 dual Rear? Or should I just Get Huge Tires?
  184. Rear Main Seal leak
  185. Pressure testing intake system.
  186. Cruse Control Quits.
  187. 2002 Cummins 24V Valve Adjustment Video
  188. kickdown cable adjustment
  189. Quadzilla tunes and limits
  190. 300000 km service
  191. I think I need to replace the lift pump
  192. quad adr w/pulse
  193. wheels
  194. P codes
  195. A Documented Rebuild?
  196. Single Disk or Triple
  197. next best mod??
  198. 24 valve rebuid
  199. Cooling system
  200. "Damaged" VP44
  201. How hot is too hot?
  202. Headlights Flicker at Idle
  203. Know of any preferred diesel mechanics around N Alabama
  204. Cleaning Sensors
  205. fueled for power
  206. turbo
  207. Specs for 01 and 02 engine and turbo
  208. fuel pump
  209. valve body or torque converter???
  210. Vp44
  211. injection noise
  212. Time to winterize
  213. The raptor LP
  214. DOES ANY ONE
  215. Fitting size on 01 Fuel Filter assembly?
  216. need help
  217. Rear Drum/Disc Conversion 2001 Dodge
  218. what does fuel pressure need to be on vp44?
  219. 2002 ram idling problem
  220. exhaust brake
  221. head studs needed for quadzilla adrenaline w/ pulse? if not, than what?
  222. more questions
  223. head studs and waste gate tubo fooler needed with quadzilla adrenaline?
  224. dead miss and deal pedal... ive tried everything
  225. cracked manifold
  226. Bd or suncoast??
  227. Clicking in front end in 4X4...
  228. Any easy engine upgrades, tweaks, or swaps for a 98.5 24v?
  229. boost leak???
  230. quadzilla help
  231. Need stock control arms specs
  232. Just lookin for ideas
  233. valves
  234. What aftermarket radio head unit will fit?
  235. vp44 bracket
  236. 47re valve body ?????s'
  237. what mods needed for 4k?
  238. I NEED HELP PLEASE About this TURBO
  239. gear puller?
  240. Injectors
  241. need some info
  242. Airsep Kit for crank case breather spray worth it? any home made alternatives?
  243. New 99 ram owner needs some 911oil leak need help!
  244. fuel injector removal
  245. Doors keep unlocking!
  246. Transmission Ideas
  247. I cant figure it out
  248. help please
  249. new guy with a major problem
  250. 01 Dodge 3500 Auto Tranny Problems
