Whats Too Much /Starwheel
Old Apr 21, 2010 | 03:45 AM
az coil roller's Avatar
Default Whats Too Much /Starwheel
What's to much on the starwheel and how's the best way to do it myself anything will help
Old Apr 21, 2010 | 03:58 AM
coyropin's Avatar
Here are some good reads for you
https://www.dieselbombers.com/5-9l-1...-12-valve.html
https://www.dieselbombers.com/5-9l-1...ning-mods.html
Old Apr 21, 2010 | 05:00 AM
94 12valve's Avatar
too much is massive clouds of black smoke. The starwheel adjusts the springs press on the afc foot. If you loosen it up there will be tons of preboost fuel, tighten it up and there will be less preboost fuel.
To adjust the starwheel you need an allen wrench and a screwdriver.
Old Apr 21, 2010 | 06:03 AM
wes-cummins's Avatar
pretty much depends on how much smoke you want, if the smoke is excessive when you floor it, back off on the star wheel
Old Apr 21, 2010 | 09:43 AM
joey's Avatar
A smoking truck isnt the fastest truck all smoke is is unburned diesel.
Old Apr 21, 2010 | 09:53 AM
85_305's Avatar
Being Evaluated
So in order to decrease lots of smoke when it's initially floored, which direction do you turn the star wheel?
Old Apr 21, 2010 | 11:49 AM
tltruckparts's Avatar
you bring it up, i believe its counter clockwise
Old Apr 21, 2010 | 01:06 PM
Threesixty's Avatar
Depends on how much you want to resemble those city trucks that spray for mosquitos....
Old Apr 21, 2010 | 02:37 PM
guhfluh's Avatar
From the top toward the driver side to lessen fuel and smoke, correct?
I have to tune mine some more and lessen the preboost fuel, but the smoke screw and moving the whole afc back should fix mine. The rate of fuel once the turbo spools is fine.
Old Apr 21, 2010 | 03:10 PM
yes if it clears up as soon as the turbo lights you might want to just back off on the smoke screw and pull the housing back, b4 my afc was gutted i had the smoke screw backed way off and the afc housing half way and it ran pretty good,
