whats wrong with this truck.
Old Mar 25, 2010 | 10:36 PM
dan33klein's Avatar
Default whats wrong with this truck.
a guy in the local area wants me to look at his 94 12 valve. he just had new injectors put in it and the motor is stock. he said it just doesnt have the power. he said if he throws it in neutral and hammers it it kinda smokes bluish whitish and pops. its lacking pulling power.
im gunna check the timing and change the fuel filter tommorow. any other suggestions?
Old Mar 25, 2010 | 11:22 PM
ArizonaRedneck's Avatar
make sure and check fuel pressure could be bad lift pump or ofv
Old Mar 25, 2010 | 11:44 PM
BIG NIG's Avatar
new stock injectors or aftermarket? did it happen soon as he picked up the truck from having the injectors installed?
Old Mar 26, 2010 | 07:20 AM
dan33klein's Avatar
no there stock replacement bosch injectors from our local disel shop. and he said no. it has always kinda been a dog. he got the injectors a few months ago. but he said it wasnt really noticeable untill recently. im gunna check all the fuel. bump the timing to 15 degrees, and slide the stock plate and housing full forward. that give him a lil extra power
whats the easiest way to check fuel pressure?
Old Mar 26, 2010 | 10:05 AM
R&RDiesel's Avatar
FormerVendor
dont forget about the head gasket.
Old Mar 26, 2010 | 04:21 PM
monster12valve's Avatar
check fuel lines for leaks or seaping,
Old Mar 27, 2010 | 08:30 AM
cawhorses's Avatar
I'm in with everyone else, check the fuel lines and pressures. White, or Blue smoke means the fuel isn't being Atomized meaning that the pressure probably isn't right. Whether it be from one of the pumps not supplying the proper pressure, or the fuel filter being plugged. If you check those and everything seems good maybe give her about half to a quart of ATF (Automatic Tranny Fluid) That's a great detergent for Diesel Fuel systems. I use the cheapest stuff I can buy and put about a half a quart in 1 time a month or so, you can put it in every tank which I did with my old 98 12 V.
Old Mar 27, 2010 | 11:03 AM
dan33klein's Avatar
yeah he had new injectors put it in. and they all leak like crazy. hes taking it back to the shop on tuesday. then im gunna look at it again after that
Old Mar 27, 2010 | 11:05 AM
wes-cummins's Avatar
i wouldnt put the plate FF set it back a good 1/4" to keep the temps down since it is sombody elses truck,
set the timing and give her a good tune up,
Old Mar 27, 2010 | 11:08 AM
captain_stabbin's Avatar
keep us updated, im curious as to what the timings at now!!
