I think I'm screwed, big time.
Old Mar 15, 2010 | 03:43 PM
12valvetater's Avatar
Default I think I'm screwed, big time.
Well I think I may be cursed with driving this truck up to school. I was headed up today cruising about 65 at 2200 and all of a sudden I felt a bunch of vibration coming up through my shifter. I thought at first that 5th gear was coming loose again and down shifted into 4th. The vibration I was feeling turned out to be a heavy knock coming from the engine. I looked in the mirror and could see a bunch of blue/black smoke. Pulled over along I-81. Still had good oil pressure engine temp was around 190F. Checked the oil and it was a little bit low maybe a quart under the add mark. Oil looked and smelled good. Check coolant it was perfect. Put a gallon of oil in and the level is now a quart over full. Started the engine again still had a horrible knock and heavy smoke that is a dark grey color without hardly any throttle input.
What do you guys think? I'm scared I might of spun a bearing, dropped a valve, or maybe blew the tip off an injector because of the heavy smoke.
Old Mar 15, 2010 | 03:54 PM
Cbum's Avatar
Leaning towards injector issue.
Old Mar 15, 2010 | 03:59 PM
dshane62's Avatar
maybe a injector went south you can loosen each injector fuel line one at a time till you
find what cylinder it is then pull that injector out and see what it looks like. but if its a heavy knock its likley lower end,
i had a delivery valve holder break off just inside the pump and it smoked and knocked to.
Old Mar 15, 2010 | 04:04 PM
I'm not starting the engine again until I know more. When I get home on friday I will pull all the injectors and check each one. These are stock 215 injectors.
Old Mar 20, 2010 | 03:30 PM
I cracked each injection line at the injectors and it made no difference.
Old Mar 20, 2010 | 05:29 PM
therealpuller's Avatar
Check timing on pump might have slipped the gear a little.
Old Mar 20, 2010 | 10:22 PM
I doubt that slipped timing would sound like a rod knocking.
Old Mar 21, 2010 | 10:15 AM
wes-cummins's Avatar
you sure its a rod knocking? i would check the timing just to be sure
Old Mar 21, 2010 | 02:32 PM
Problem found #4 injector was blown off.
Old Mar 21, 2010 | 02:52 PM
ArizonaRedneck's Avatar
thats better than a rod knocking the tip was completely gone and where did it go
