12 valve stalling
Old May 1, 2010 | 09:04 PM
timsgsx's Avatar
Default 12 valve stalling
my buddys 96 12 valve 2wd dually keeps stalling out.if you come to a complete stop with the truck in drive or reverse, it stalls. if you put it in neutral it stays running.once you get away from a stop it runs fine.i got an idea or 2 about the issue what do you guys think?
Old May 1, 2010 | 09:08 PM
captain_stabbin's Avatar
bad tps sensor?
Old May 2, 2010 | 08:26 AM
daveO's Avatar
Sounds like maybe the idle speed is set too low. What kind of RPMs is he seeing? Should be around 750-800 with the truck in drive and the a/c on.
Old May 2, 2010 | 10:00 AM
Diesel Nut's Avatar
Idle speed, Governor springs may be too loose, or he may have a failing torque converter.
Old May 2, 2010 | 10:39 AM
Sounds like idle speed to me.
The fix - Ram Diesel Problems
RA113024
Mar 13, 2016 07:42 PM
Andyhc1
Mar 16, 2015 12:00 PM
LTreis702
Feb 14, 2015 12:52 PM
bonestock
Feb 1, 2015 08:41 PM
behrendt1061
Dec 4, 2014 05:49 PM
