how much timing
Old May 6, 2010 | 10:11 PM
tltruckparts's Avatar
Default how much timing
ok well i got a p pump on now and ill be setting my timing tomorrow.
i got 5x.014 sdx injectors, 131dv's, phat shaft turbo.
i only want to time it once i dont want to mess with all the time. in the next 2 weeks its going to get 191 dv's, 4kgsk, 60 lb valve springs.
so i want to set the timing to what will work with those settings. i was thinking about 20*.
does that sound about right or do i need more or less?
Old May 6, 2010 | 10:20 PM
94 12valve's Avatar
Do you have studs? it you do 20* is fine.
Old May 6, 2010 | 10:57 PM
no but i plan on doing them in the very near future
Old May 7, 2010 | 08:24 AM
Shea@L&N Performance's Avatar
FormerVendor
20 sounds good as long as you get those studs in
Old May 7, 2010 | 12:29 PM
oglejust's Avatar
damn.. now u guys r makin me want to put mine to 20!
Old May 7, 2010 | 12:32 PM
12vcummins96's Avatar
17 to 20 anywhere in that region
Old May 7, 2010 | 06:24 PM
well money got a little tighter today so studs wont be as soon as id like so im probably going to go to 18 and stay there until i do studs
Old May 7, 2010 | 06:33 PM
monster12valve's Avatar
16.5* is as high as i would go with out studs.. imo.. but i am not a gambling man!
Old May 7, 2010 | 10:24 PM
so what is the difference in 16.5* as compared to 20* from the studs standpoint? will give more boost or what makes it worse without studs?
Old May 7, 2010 | 11:12 PM
lodal cummins's Avatar
the big increase in cylinder pressure will stretch your stock bolts and cause your head gasket to go to crap.
