Repalcing frost plugs
Old Apr 19, 2010 | 05:55 PM
Dallas Flywheels's Avatar
Question Repalcing frost plugs
Has anyone replaced the frost plugs behind the tappet cover on a 1996 Cummins 12 valve? Other than removing the fuel pump, any other ugly issues? I am getting coolant in the oil, I lose about a cup in 4000 miles. Milky residue on the dipstick, out the breather and under the valve covers. Had the head gasket replaced and head checked out at the machine shop. Cummins suspect a frost plug has a pin hole in it, as they have seen this before.
Old Apr 20, 2010 | 12:50 AM
1stGen1990's Avatar
I did them on my 1990, it aint that hard if the engine is out. with it out you can put the engine upside down and knock em into the block and then they fall out. Its hard to turn them little ones sideways and do it while the engine is still in. I suppose it wouldnt be to hard if youve done it before. The push rods may get in the way tho, same with injection pump.
Old Apr 20, 2010 | 12:53 AM
12vcummins96's Avatar
it is a pain in the truck out its easy
rkp209
Chevy/GMC Duramax 2011 LML
Jan 10, 2016 10:32 AM
GT_Eleanor
Sep 14, 2015 10:52 AM
1997silverado
Mar 12, 2015 07:40 PM
hardwired
8
Jan 23, 2015 04:30 PM
Dorian Gray
Oct 11, 2014 07:32 PM
